Old 02-22-2004, 11:49 PM   #1
BANG4BOOST
Member#: 49963
420 impreza
Default CEL, does really matter??
hey guys, i always thought that if u had a check engine light on.. that meant ur ecu will make ur car run inefficiently.. like if your under 3000rpm u will waste gas inefficiently.. but wen u gun it the ecu goes into a safe mode or something and lets the car go all out... which makes the car perform top notch for that moment...
but my friend kept insisting that the cel doesnt matter at all.. i want to clarify this.. please i need expert facts.. thanks..
BANG4BOOST is offline   Reply With Quote
Old 02-22-2004, 11:56 PM   #2
z&cobb
Member#: 12344
2002 2JC
blue
It depends on the why the CE light is on. You have to read the code. For example a code P0420 is a common code that will not affect the operation. But you don't know what it is until you get it read.
In general, a blinking or flashing CEL is more serious than a steady CEL.
z&cobb is offline   Reply With Quote
Old 02-23-2004, 12:08 AM   #3
Andrew Bacon
Member#: 2267
00RS
rutherforddesign.com
Yep
Andrew Bacon is offline   Reply With Quote
Old 02-23-2004, 12:26 AM   #4
BANG4BOOST
Member#: 49963
420 impreza
well watever code it is... cel will come on if u are running a catless downpipe... does that code effect operation?
Old 02-23-2004, 10:57 AM   #5
z&cobb
Member#: 12344
2002 2JC
blue
Nope, but it is annoying, and the car would fail an OBD-2 type emissions test. I have heard of some people putting a piece of black tape over the light.
Other options are:
A resistor/capacitor fix
A treaded extension on the sensor fix
An erase after identifying fix
A battery ground disconnect plus brake pedal depress fix.
Old 02-23-2004, 11:29 AM   #6
MustGoFast
Member#: 33370
2002 Impreza WRX
Blue now w/ 6 fun flavors
That would be the P0420 code.
MustGoFast is offline   Reply With Quote
LCD TV's - does brand really matter? RaceCarRiot Off-Topic 11 11-28-2005 11:00 PM
How much does heat wrapping a downpipe really matter? ImprezaWRXFan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 12-09-2004 12:16 AM
WOMEN- Does size really matter??? wrxman555 Off-Topic 17 11-25-2004 01:49 AM
Does the Wastegate spring really matter? drdeuce Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 08-26-2004 07:35 PM
does octane really matter? terpWRX Mid Atlantic Impreza Club -- MAIC 14 08-03-2003 02:18 AM
