View Poll Results: Which should i add next?
Turbo (VF)/Injectors/Fuel Pump 9 33.33%
Link/UTEC ECU 18 66.67%
FMIC or Upgraded TMIC 0 0%
Header/Injectors/Fuel Pump 0 0%
Voters: 27. You may not vote on this poll
Old 02-23-2004, 12:39 AM   #1
jarelee
Member#: 31506
05 Tacoma on TE37'
Default Need your input on what to do next...stuck on a few choices.
Hey guys. I have about $900 to spend on my next mod or so, and i wanted to hear your input and opinion. I know this probably has been asked a million times, and i've searched and read, but i'm still stuck on a few choices. I would like to upgrade a few things right now and of course the rest later.
I currently have:
Gruppe-S Uppipe
HKS Downpipe
Cobb Cat-back
Blitz SBC-ID
Power wise, i'm looking for a good gain, but nothing extreme right now.
I was thinking about upgrading the Turbo to a VF34 or 22 and of course do Injectors and Fuel Pump and run it with my SBC-ID for now.
OR Upgrade my TMIC to a FMIC and run it with the stock turbo (Some would say against that about the lag and such, and others say you gain, only one way to find out)
OR Sell the SBC-ID and upgrade to a LINK or a UTEC and dyno-tune it for what i have.
OR Add Headers, Injectors and Fuel Pump (So i have all the supporting mods except for IC for a Turbo)
What are your good opinions. Thanks.
jarelee is offline   Reply With Quote
Old 02-23-2004, 12:49 AM   #2
blackie
Member#: 42979
03 wrx
blizzzack stage IV
sell the boost controller, then get a reflash and header. that set up will be good for 220-230hp at the wheels, then save up for a vf-34 and injectors and pump, then you can have 270-280whp.
blackie is offline   Reply With Quote
Old 02-23-2004, 12:57 AM   #3
jarelee
Member#: 31506
05 Tacoma on TE37'
Oh ya...BTW, I Dyno'd my car with the set-up that i have right now, and i dyno'd 221 HP/ 195 TQ.
I kinda don't want to get a Reflash, i prefer something programmable. Something that i can tune myself or on a Dyno. But i know Reflashes are good, oh ya....and i can't really do without my car for more then a day or so.
Old 02-23-2004, 09:58 AM   #4
vile
Member#: 32371
'02 t-rex wagon
platinum
UTEC, all the other stuff will be tuned using it
vile is offline   Reply With Quote
Old 02-23-2004, 10:00 AM   #5
GeoffM
Member#: 30252
2005 996GT3,'15 3500
04 Ducati 749R #249
cobb access port......
GeoffM is offline   Reply With Quote
Old 02-23-2004, 10:26 AM   #6
slowmike
Member#: 24890
2002 Jackwagon
WRB GG
Reflash is worth every penny.
slowmike is offline   Reply With Quote
Old 02-23-2004, 06:07 PM   #7
jarelee
Member#: 31506
05 Tacoma on TE37'
Thanks guys....keeep the opinions coming.
Old 02-23-2004, 06:18 PM   #8
Sports Wagon
Member#: 43081
Sell the boost controler. +$300
Get the Access Port. -$600
Puts you at 285HP.
That leaves you with $600, half way to a VF-34 combo($1239)
Now you have 320HP
http://www.cobbtuning.com/flyer-accessport-std.pdf
Sports Wagon is offline   Reply With Quote
Old 02-23-2004, 06:43 PM   #9
jarelee
Member#: 31506
05 Tacoma on TE37'
If i were to buy the Accessport, I would still have to purchase the Cobb AECU right? *NM FOUND THAT IT INCLUDES THE REFLASH
The reason why I kinda lean towards Link or Utec or Emanage (forgot to add that choice) is because my friend at Brainstorm and the owner there are great at tuning Link and can do it right.
But the Accessport seems like a good idea.
Old 02-23-2004, 06:51 PM   #10
Sports Wagon
Member#: 43081
No, once you buy the Accessport it will marry or flash it's self to your ECU and your ECU only. From there you will be able to upload and change the Cobb maps as you upgrade or see fit.
The unit will hold up to 10 separate maps, ie. valet, anti-theft, stock, and 87,89,91,93 octane maps and many others to come.
Also if Cobb upgrades the unit you'll only have to pay the difference to upgrade.
If you have time you can read through the 14 or so pages of FAQ's
http://www.wrxforum.com/cgi-bin/ulti...;f=11;t=000001
Old 02-24-2004, 12:50 AM   #11
jarelee
Member#: 31506
05 Tacoma on TE37'
thanks for the info sports wagon
TTT
Old 02-24-2004, 01:04 AM   #12
Member#: 22294
2003 WRX MBP
COBB STG II
accessport or some kind of engine management
WRB is offline   Reply With Quote
Old 02-24-2004, 01:20 AM   #13
Hit Man X
Member#: 27787
'02 WRX Sedan
Since you are running an '02, ever thought about a used TXS Unichip setup? That's what I'm running and am pleased with its performance/dollar ratio.
Run that for a while with the Stg 2 map until you decide your next move.
With any of the mods you have suggested, you'll need a dyno tune to max the benefits...well other than a Stg 3 which is basically an added TMIC.
What's a Blitz SBC-ID? If you can sell that for a good bit then I'd scoop up a used UTEC then. You can mix+match bits and pieces then. Like add the larger injectors early if you wish...
Hit Man X is offline   Reply With Quote
Old 02-24-2004, 02:39 AM   #14
jarelee
Member#: 31506
05 Tacoma on TE37'
A Blitz SBC-ID is a Electronic Boost Controller. Its a good unit and has done me well so far.
I did think about the Unichip, but i kinda want something where its just about fully programmable like Link/Utec and also able to have different maps for different settings. Those cost more then the Unichip but i'll probably be using that for ALONG time to come.
Old 02-24-2004, 03:00 AM   #15
Hit Man X
Member#: 27787
'02 WRX Sedan
Ah, okay. Thanks for giving me the scoop on it.
Old 02-24-2004, 10:06 AM   #16
jbogli
Member#: 26006
2002 Impreza WRX
Default Em
Get EM and then you can tune for all your parts that you add from there on out. Mods are much better when you tune for them.
Justin
jbogli is offline   Reply With Quote
Old 02-24-2004, 04:09 PM   #17
jarelee
Member#: 31506
05 Tacoma on TE37'
good point jbogli. I can tune it now for what i have, and just keep tuning for everything else i add on, AND the Engine Management part is taken care of too.
Anyone else?
Old 02-24-2004, 11:47 PM   #18
garie
Member#: 26607
2002 wrx wagon
ecu or cobb accessport
garie is offline   Reply With Quote
Old 02-25-2004, 04:30 AM   #19
jarelee
Member#: 31506
05 Tacoma on TE37'
Need opinions on what to do next. 07ImprezaMB Normally Aspirated Powertrain 12 02-01-2010 05:16 PM
OT Officers Of the Law: Need advice on what to do next. sc00by4life Off-Topic 47 10-15-2006 02:43 AM
need advice on what to do next t3ch9 Engine Management & Tuning 1 06-24-2005 04:18 PM
So you got your car keyd, what to do next vapore0n New England Impreza Club Forum -- NESIC 11 05-19-2004 06:27 AM
Need some advice about what to do next (WRX or RS-T) imprezzed General Community 8 06-03-2003 09:53 PM
