Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 02-23-2004, 09:42 AM   #1
infulleffect
Member#: 34054
Question Utec Boost Map???
BOOST MAP
Okay here is a map I picked up online...I am new to using the Utec but the boost map seems off the chart...am I wrong in thinking this?
THanks
infulleffect is offline   Reply With Quote
Old 02-23-2004, 10:59 AM   #2
powbmps
Member#: 27543
Default boost
What Stage are you running? I had boost values that high on my Stage 2 setup. If you are nervous about it, reduce all of the boost values by the same amount and work your way up from there until you get to the desired boost level.
Chris
powbmps is offline   Reply With Quote
Old 02-23-2004, 11:59 AM   #3
infulleffect
Member#: 34054
Thanks...I am running a stage2 map these are supposedly for a stage2 map...but they did not mention having to be in open or closed loop...that is the only difference I can see.
Old 02-23-2004, 12:08 PM   #4
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
If the boost values are above 100 you must be in CLB.
cdvma is offline   Reply With Quote
Old 02-23-2004, 12:31 PM   #5
MustGoFast
Member#: 33370
2002 Impreza WRX
Blue now w/ 6 fun flavors
must be CLB and remember that higher or lower values can be just a twist of the ABC away... 2 people can easily achieve the same boost w/ different boost map numbers by adjusting the ABC.. the more important thing is where it does what it does to get your turbo to spool quickly w/ out overboosting.
MustGoFast is offline   Reply With Quote
Old 02-23-2004, 12:58 PM   #6
hippy
Member#: 36528
2002 Impreza Wrx
Closed loop boost will end up giving you more boost earlier in more gears, it's pretty easy to tune, and it's less weather dependent then open loop boost control. This is why most people use closed loop boost control while tuning using utec boost control. Remember that you have to change the boost value in the special preferences to 0 instead of 1 for closed loop boost control when you use a closed loop boost map(because of the different numbers). There is no reason to use someone elses closed loop boost map because it really doesn't take long to get a boost map close to where you want it. If you read the utec manual about boost, micks guide, and look through a few posts about closed loop boost control, you shouldn't have many problems.
peace
Old 02-23-2004, 01:44 PM   #7
infulleffect
Member#: 34054
I downloaded Micks Guide today, but the work PC doesn't have adobe so I am out until I can get home errrrr...thanks
Old 02-23-2004, 06:01 PM   #8
03WRXMA
Member#: 35081
2012 WRX
BUT they SHOULD just have the ABC out two turns, and adjust the boost via the map.
03WRXMA is offline   Reply With Quote
Old 02-24-2004, 12:01 AM   #9
MustGoFast
Member#: 33370
2002 Impreza WRX
blah.. you tune the ABC as needed to achieve your desired boost.
Utec Boost map 5 for N20 mycal Engine Management & Tuning 24 12-27-2005 08:48 AM
UTEC, boost tuning, boost gauge vs map psi SJWWRX Engine Management & Tuning 2 07-09-2004 11:22 AM
utec boost map question bstoehr83 Engine Management & Tuning 1 05-05-2004 12:41 AM
Utec boost map ???'s GRoceryTurbo Engine Management & Tuning 3 05-05-2003 06:40 PM
Open Loop vs Closed Loop UTEC boost map. Example? mav1c Engine Management & Tuning 3 02-01-2003 11:58 PM
