Old 02-23-2004, 01:24 PM   #1
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Question Picture of Oil crank seal?
This little (insert word here) Is causing me to have to check my oil every other day... From what I heard it's a real cheap part..
My engine only leaks oil when it's running.. it really started as I was coming back from Canada, and stopped at a rest stop in Vermont.. oil leaked on the piping under the car and started smoking really bad.. It does not leak on their much anymore.. But still drips..
SubaruImpreza_power is offline   Reply With Quote
Old 02-24-2004, 06:11 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
its a small inexpesive part, but there is a alot of labor involved in changing it.
its behind the crank gear for the timing belt.
Jay
Old 02-26-2004, 06:13 AM   #3
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Which end? Front or rear seal? The front is not too bad, the rear is almost doing a clutch since the clutch and flywheel need to be removed to do the seal.
Old 02-26-2004, 08:47 AM   #4
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
The Front...
lol and why do people allways asume you have a 5MT
The only part that was hard was removing the Crank pully and Timing belt? Are their marks on the Timing pulleys?
drain oil for cam/crank seals? 98tredsvt Factory 2.0L Turbo Powertrain 1 11-01-2009 05:40 PM
Oil leak - crank seal aldebaraan 'Old School' Subaru Forum 8 02-07-2009 05:40 PM
How bad is a leaky front crank seal or oil pump? garface Factory 2.0L Turbo Powertrain 6 01-03-2007 11:24 PM
Picture of a picture of a picture of a picture of a picture of a picture of a pic OT! Asinine Off-Topic 35 09-13-2006 12:32 PM
Timing belt change and crank seal with oil leak fdupny Service & Maintenance 1 11-10-2004 05:18 PM
Message Board Statistics All times are GMT -4. The time now is 03:09 AM.
