Old 02-23-2004, 03:18 PM   #1
racewagon
Member#: 36574
2003 WRX Wagon
WR Blue
Default cheap reliable gauges
i am in the market for some gauges and i like the price of autometer but some say some of their lines are not to accurate. if someone could point me in the right direction as to which are accurate or another direction all together but without breaking the bank, im in college.
racewagon is offline   Reply With Quote
Old 02-23-2004, 03:21 PM   #2
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Autometer electric gauges should be fine for you. They are about as cheap as electrics get. Mechanical gauges will be even cheaper but you can run into issues.
mbiker97 is offline   Reply With Quote
Old 02-23-2004, 05:18 PM   #3
03WRXMA
Member#: 35081
2012 WRX
What gauges are you looking for? boost is a must! But what else do you want?
I have boost, egt, and oil psi.
Omori makes a GREAT gauge and they arent that expensive.
Greddy also has some low cost options that wont break the bank.
03WRXMA is offline   Reply With Quote
Old 02-23-2004, 05:58 PM   #4
racewagon
Member#: 36574
2003 WRX Wagon
WR Blue
i was looking for just boost right now, then in the summer i will get egt and oil
so basically im lookin for just electic gauges now, if i understand correctly? the mechanicals are more prone to less accuracy?
Old 02-23-2004, 05:58 PM   #5
fogdor
Member#: 45726
2007 Mazdaspeed3
Cosmic Blue
I have decided to go with VDO for the boost and oil temp. If I can't find this mysterious "fast" thermocouple for their EGT, I will probably just get the Omori EGT.
fogdor is offline   Reply With Quote
Old 02-23-2004, 05:59 PM   #6
industrial
Member#: 7250
2017 WRX
I run autometer egt and boost. The boost guage is mechanical and works perfect. The egt reads a bit slow but you can buy faster probes if your so inclined.
edit: saw additional posts. The autometer guage reads exactly the same as my old stock guage and both their numbers correspond exactly to the numbers my ecu is seeing. Dyno verified.
-Bernard
industrial is offline   Reply With Quote
Old 02-23-2004, 06:41 PM   #7
racewagon
Member#: 36574
2003 WRX Wagon
WR Blue
thanks for all the help guys, i think im gonna go with some cheap autometer mechanicals because i can get a discount. when the time comes for actually tuning ill get some nicer ones but this is just so i dont overboost too much, i dont mind some fluctuation within a half lb for less than 50 bucks
Old 02-23-2004, 06:49 PM   #8
03WRXMA
Member#: 35081
2012 WRX
Eh, its your money! But why spend more in the long run just to save a buck now
Old 02-23-2004, 07:04 PM   #9
Macabre
Member#: 3841
2004 WRX Wagon
UTEC+VF22+WI
VDO gauge + westach probe ($35)
Macabre is offline   Reply With Quote
Old 02-23-2004, 07:08 PM   #10
fogdor
Member#: 45726
2007 Mazdaspeed3
Cosmic Blue
You got a link or a part number for the westach EGT probe?
Old 02-23-2004, 08:08 PM   #11
Macabre
Member#: 3841
2004 WRX Wagon
UTEC+VF22+WI
The one I used was the 712-4D4K probe (you can buy direct, westach.com but you'll need to call them. Also chiefaircraft.com and aircraft-spruce.com sell several westachs but not the specific one I bought, apparently it's an uncommon size). The probe to get depends on the threads on the bung you use. That one is 1/4" NPT which matches the bung that the VDO kit comes with. You can also do a search here, several other people are running westach probes with great success.
Old 02-23-2004, 08:10 PM   #12
Tur1smoWRX
Member#: 35006
2003 WRX
HOT PINK
If you get the Autometer mechanical boost gauge you should go to home depo or some place like it and get some rubber hose line. The white plastec line in the autometer can crack or crink resulting in your gauge not working and a vac leak.
Tur1smoWRX is offline   Reply With Quote
Old 02-23-2004, 10:59 PM   #13
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
if you want reliable, inexpensive, and great-looking gauges (meaning ones you don't have to strain to see the illumination) get VDO Vision Series gauges. They are available from www.summitracing.com among other places. The illumination looks a LOT like stock WRX lighting.
nhluhr is offline   Reply With Quote
Old 02-24-2004, 12:33 PM   #14
racewagon
Member#: 36574
2003 WRX Wagon
WR Blue
im going to look into those vdo's i had them in an old bmw i used to have and they did work well. thanks
Old 02-24-2004, 07:27 PM   #15
industrial
Member#: 7250
2017 WRX
VDO vision series is über. Illuminated needle and with the green condom matches very well. The autometers are hard to see at night. Just fyi.
Old 02-26-2004, 10:29 AM   #16
MRC1
Member#: 41025
06 WRX TR w/VF39
Rally Blue
I second that. The VDO gauges with the green bulb slip on are almost an exact match with the gauges in my 04 WRX. That and the price (I paid a 100 bucks delivered for oil temp w/sender and boost gauge) Summit is a good source for them.
Mike
MRC1 is offline   Reply With Quote
Old 02-26-2004, 05:47 PM   #17
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
A #168 bulb in the autometer gauge(Sport Comp anyway), colored with a green sharpie, and tapped off the spare plug on the radio harness matches the stock gauges in illumination real nice
Old 02-27-2004, 01:51 AM   #18
industrial
Member#: 7250
2017 WRX
Green Sharpie Hmmmm.....I'll try that this weekend.
Old 02-27-2004, 10:21 PM   #19
Bankie
Member#: 37785
OT hates your car
It don't see a VDO EGT gauge that reads over 1600. What one are you guys using?
Bankie is offline   Reply With Quote
Old 02-27-2004, 10:33 PM   #20
industrial
Member#: 7250
2017 WRX
Old 02-27-2004, 10:47 PM   #21
Bankie
Member#: 37785
OT hates your car
I was under the impression that the exhaust temps of the WRX would be higher than 1600 and therefore you'd need a gauge that read at least 2000.
Old 02-27-2004, 11:10 PM   #22
Uncle Scotty
Member#: 16200
OK buy Nates beans
If you peg that gauge, you have serious engine problems, or will very soon.
1550°F should really be considered a MAX EGT and nothing over 1500°F sustained or your tune is bad.
Old 02-27-2004, 11:11 PM   #23
Fijimunkii
Member#: 52834
2004 WRX Java Black
Wing, Koji, SPT CBE
I can't find an electrict VDO boost gauge, can anyone help me out? These are pretty cool
Fijimunkii is offline   Reply With Quote
Old 02-27-2004, 11:26 PM   #24
Macabre
Member#: 3841
2004 WRX Wagon
UTEC+VF22+WI
I don't believe VDO makes an electric boost gauge.
Old 02-27-2004, 11:37 PM   #25
Uncle Scotty
Member#: 16200
OK buy Nates beans
An electric boost gauge is a huge waste.
Cheap reliable import MPOWERD Private 'Wanted' Classifieds 2 08-29-2003 11:29 PM
((Midwest))WTB Cheap reliable import MPOWERD Mid West Subaru Owners Club Forum -- MWSOC 1 08-29-2003 02:57 PM
WTB: Cheap, reliable car local (DC, MD, VA) jmaluso Mid Atlantic Impreza Club -- MAIC 3 07-10-2003 01:47 PM
Cheap reliable source for front clear side markers? cmb Interior & Exterior Modification 14 10-15-2001 12:50 PM
