Old 02-23-2004, 04:58 PM   #1
Fubaru
Member#: 6046
'08 Prius
Default Replacing rear oxygen sensor
Looks like I need to replace the rear O2 sensor on my MY02 WRX
Local dealer wants $207 to do it.
How much labor is it to replace this thing? Is it plug & play with the existing wiring?
Fubaru is offline   Reply With Quote
Old 02-23-2004, 05:10 PM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
You can get a new sensor for $117 from www.subaruparts.com. It's easy to replace, just disconnect the plug and unscrew it and replace. If you want to save the $90 then do it yourself.
Calvin
cnk is offline   Reply With Quote
Old 02-23-2004, 10:26 PM   #3
Fubaru
Member#: 6046
'08 Prius
Thanks for the info...
I found these part numbers at that website:
22690 SENSOR ASSEMBLY-OXYGEN 22690AA501
22690 SENSOR ASSEMBLY-OXYGEN 22690AA490
22690 SENSOR ASSEMBLY-OXYGEN 22690AA540
22690 SENSOR ASSEMBLY-OXYGEN 22690AA420
They appear to be the same part. Does anybody know if this is indeed the rear oxygen sensor on the 2002 WRX ?
Old 02-24-2004, 09:23 AM   #4
Kartoffel
Member#: 12976
grocery getter
Rear O2 sensor..... what's that?
Kartoffel is offline   Reply With Quote
Old 02-24-2004, 10:28 AM   #5
cnk
Member#: 10757
If you look to the right of the line items on the site, it tells you what it fits. http://www.subaruparts.com/diag/?mod...category=440-1 If you have a manual, then get the MT.205 part. If you have auto, then get the WRX.AT.205. The one for 251 is for a 2.5 liter engine either in the 2.5RS or STi.
Calvin
Old 02-24-2004, 11:03 AM   #6
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Check your warranty; it might be covered by the emmissions control warranty.
Mike Wevrick is offline   Reply With Quote
Old 02-24-2004, 12:15 PM   #7
Hayes
Member#: 11808
The O2 sensors are part of the emissions control and should be covered to~80,000 miles. Check your owners manual. Ed Hayes
Hayes is offline   Reply With Quote
Old 02-24-2004, 03:39 PM   #8
Fubaru
Member#: 6046
'08 Prius
I will check into the warranty coverage.
I might be out of luck since I have replaced the entire exhaust except for the muffler - uppipe, downpipe, midpipe.
The rear O2 sensor that apparently went bad on my car is on a Godspeed downpipe.
Old 11-01-2005, 09:49 PM   #9
FourStar
Member#: 87042
i called a subaru dealer in my area today and they said the o2 sensors are only covered under the 36000 mile warranty (might be 30000 i forget). im out of luck too because my rear 02 just went out yesterday.
FourStar is offline   Reply With Quote
Old 11-01-2005, 10:02 PM   #10
cnk
Member#: 10757
You do realize that this post is almost 2 years old right?
Calvin
Old 11-02-2005, 10:52 PM   #11
cnk
Member#: 10757
Originally Posted by Samurai Jack
Maybe, but it answered the warranty question.
One would assume that after 2 years, the OP would have already found the answer to the question.
Calvin
Old 11-02-2005, 11:15 PM   #12
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Samurai Jack is offline   Reply With Quote
Old 11-03-2005, 12:00 AM   #13
FourStar
Member#: 87042
nope sorry i didn't read the date. but yep the question is now answered
Time to replace the rear oxygen sensor BlkTS02 Normally Aspirated Powertrain 4 06-18-2009 11:15 AM
2007 STi Rear Oxygen Sensor ( O2 Sensor ) Nitro Don Engine/Power/Exhaust 3 02-19-2009 11:49 AM
Replacing front Oxygen Sensor mstein Normally Aspirated Powertrain 10 05-18-2007 09:55 PM
Rear Oxygen Sensor for Link? cpu77 Normally Aspirated with bolt-on Forced Induction Powertrain 15 04-11-2003 09:49 AM
P0139 Rear oxygen sensor circuit slow response slin02 Mid West Subaru Owners Club Forum -- MWSOC 3 05-11-2002 02:32 AM
Message Board Statistics All times are GMT -4. The time now is 04:46 AM.
