Old 02-23-2004, 05:19 PM   #1
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Default STI 6spd wiring
Ok, ive got my swap just about done. Both the engine and tranny are in the car and waiting to be wired up.
I have one question regarding the STI tranny. I have a new one from the v.8 JDM STI with the DCCD. This has 6 wires coming from the tranny rather then the normal 4 wires that are on the wrx 5spd.
2 of those wires run to the DCCD, and I have figured out which wires they are etc and labeled them.
My question is in regards to the final 4 wires. They need to be hard wired to the 4 original wrx wires. Which colors go to wich wires. Anybody have the schematics on this, or know it off the top of there head?
Thanks for any help,
-John
LIQUIDSK8S is online now   Reply With Quote
Old 02-23-2004, 08:10 PM   #2
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
2 are for the reverse lights , 2 are for the neutral switch.
Ver.III is offline   Reply With Quote
Old 02-23-2004, 10:01 PM   #3
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Thats a start.
Now, which colors are which, and which color on the WRX harness do they connect too.
Thanks,
-John
Old 02-26-2004, 01:44 AM   #4
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Bump
Old 02-26-2004, 09:27 PM   #5
alex_umn
Member#: 11874
1992 SVX 6MT
Claret
Not sure about the colors, but the neutral sensor is on the top of the tranny more towards the back, at least on my non-suretrac JDM unit.
Here's a picture: http://www.subaru-svx.net/photos/fil..._umn/15329.JPG
Hope this helps...
alex_umn is offline   Reply With Quote
Old 09-02-2008, 07:39 PM   #6
Turbovan
Member#: 168654
2005 WRX
some form of black
This thread is only 4 years old, but I am also looking for info on the 4 wires that need to be spliced in for the neutral safety switch and backup lights. What colors for which; both STI and wrx
Turbovan is offline   Reply With Quote
Old 09-02-2008, 07:47 PM   #7
silentt
Member#: 119995
2004 Outback XT
Peachy
http://smg.photobucket.com/albums/v144/cdallyn/sti/
Has almost every single wire I soldered (engine and tranny) and you can see the colors on all of the wires. PMing you the guest password.
silentt is offline   Reply With Quote
Old 09-03-2008, 12:03 AM   #8
Turbovan
Member#: 168654
2005 WRX
some form of black
nevermind, actually looking at the wires i had to splice answered this mind boggler; green/white spliced to....green/white. Go figure.
thanks for the info silentt
Old 09-09-2008, 02:31 PM   #9
rallycol
Member#: 179712
Default Speedo wires
Any idea which wires do what on the speedo sensor on the box 3 mainly green ones thanks
rallycol is offline   Reply With Quote
Old 09-09-2008, 03:21 PM   #10
Complacent_One
Member#: 163633
2002 RIP '02 Wagon
If you are talking about the connector that plugs into the tranny extension harness (speedo sensor) Then they should be:
Pin 3 (Green/Black Stripe) Fuse Box (Fuse 18)
Pin 2 (Black/Red Stripe) Not Sure...exactly
Pin 1 (Green/Yellow Stripe) Input for Microcomputer in Gauge Cluster (Speedo)
Hope this helps a bit!!
Complacent_One is offline   Reply With Quote
Old 09-10-2008, 11:37 AM   #11
bugeye-brawler
Member#: 182337
1997 Impreza Outback
Sport -- White
haha you weren't kinding you got them all down don't you
bugeye-brawler is offline   Reply With Quote
Old 09-10-2008, 02:46 PM   #12
rallycol
Member#: 179712
Thanks should help,pin 3 must be the feed (positive) pin 1 pulse to dash,pin 2 maybe earth?
JDM my03 STi 6spd vs. USDM my05 6spd 06STi Transmission (AT/MT) & Driveline 3 12-24-2009 05:35 PM
FS: 05 STi 6spd Trans and 6spd Parts Mooneyes13 Mid West Subaru Owners Club Forum -- MWSOC 2 11-21-2008 10:02 AM
DCCD wiring on a 04 sti 6spd mcu81 Transmission (AT/MT) & Driveline 15 06-05-2008 12:08 AM
Go Fast Parts: STi EJ257 w/CP pistons, STi 6spd, TXS FMIC, UR Inj, EWG, Big MAF, etc. LatentWagen Tri-State Area Private Classifieds 36 02-12-2006 09:34 PM
Go Fast Parts: STi EJ257 w/CP pistons, STi 6spd, TXS FMIC, UR Inj, EWG, Big MAF, etc. LatentWagen Private 'For Sale' Classifieds 63 01-30-2006 03:15 PM
Message Board Statistics All times are GMT -4. The time now is 10:55 AM.
