Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 02-23-2004, 05:30 PM   #1
LB2.5rs
Member#: 41107
2003 Toyota Tundra
1987 cbr600 teh Hurricane
Default Cols: Will anyone help me install?
Alright well I was going to buy a ver 5 spoiler, but then I learned im going to hilton head, and I get to drive. One small prob...MY ari/fuel sucks bizzalls! I'm pretty much getting horrible gas mileage and I dont want to stop very offten. So im buying a proecm or torque chip to get my air/fuel back online. I was wondering if anyone wants to help me install it, or has experience installing it. If I get on the ball and buy it soon, I'm not sure when it will be in. I might not have it this weekend, and bowling is the weekend after that. So can anyone help?
LB2.5rs is offline   Reply With Quote
Old 02-23-2004, 05:33 PM   #2
WRX02WRB
Member#: 36240
2015 STi
NO!!! ... i didnt even read you thread
I read it and still wont help
WRX02WRB is offline   Reply With Quote
Old 02-23-2004, 05:35 PM   #3
CheezeWeezle
Member#: 17187
2009 Braun Entervan
Gimpy White
What he said!!!! ...What do you want??
CheezeWeezle is offline   Reply With Quote
Old 02-23-2004, 06:08 PM   #4
ellisnc
Member#: 4229
2003 S2000
Did someone say track day
Default Re: Cols: Will anyone help me install?
Why is your mixture messed up? Do you have different injectors or a turbo or something?
ellisnc is offline   Reply With Quote
Old 02-23-2004, 06:14 PM   #5
LB2.5rs
Member#: 41107
2003 Toyota Tundra
noo, just intake exhaust and headers. Thats why I was confused too!! But hey atleast ill make a extra 4 hp and 7ftlb of torque! It use to be I was on the verge between lean and mixed, but at high rpms it would be lean. But after my headers now all i get is lean the entire time.
Trent n jesse...lick em
Old 02-23-2004, 08:05 PM   #6
WRX02WRB
Member#: 36240
2015 STi
how do you know?? what brings you to this conclusion young grasshopper ?!?!
Old 02-23-2004, 08:07 PM   #7
LB2.5rs
Member#: 41107
2003 Toyota Tundra
I have a air/fuel guage... Sucks though cause it only works at 5% throttle and wot
Old 02-23-2004, 08:25 PM   #8
WRX02WRB
Member#: 36240
2015 STi
its more likley you gague being off than a horrible A/F ratio .... i dont know about your car but the Rex it has to be in the right place to get a correct reading and even then it is not exact w/o a wideband ....correct me if im wrong Old wise ones
Old 02-23-2004, 09:07 PM   #9
LB2.5rs
Member#: 41107
2003 Toyota Tundra
Grrr yer right. But I have been getting horrible gas mileage. I mean I would still kind of like a tiny bit more power than show. And after this "performance" mod im offically done with stuff to make my car go faster. Then ill just wait for you, Jesse, to total your car, then ill buy your engine!!
Old 02-23-2004, 09:10 PM   #10
WRX02WRB
Member#: 36240
2015 STi
dont even say that ... i allready wrecked it once
Old 02-23-2004, 09:28 PM   #11
LB2.5rs
Member#: 41107
2003 Toyota Tundra
really? Was it a bad wreck?
Old 02-23-2004, 09:38 PM   #12
mbeach
Member#: 39807
Vishnu Stage 2+ !SOLD!
Luke,
When was the last time you pulled and inspected your sparkplugs?
mbeach is offline   Reply With Quote
Old 02-23-2004, 09:48 PM   #13
LB2.5rs
Member#: 41107
2003 Toyota Tundra
I had them replaced like 5 months ago.
Old 02-23-2004, 09:56 PM   #14
ellisnc
Member#: 4229
2003 S2000
The strange thing is that if it's any of the engine control sensors, if it's malfunctioning in any way the MIL should indicate something unless the Subaru code isn't meeting regulation.
The ECU should compensate to an extent for the freed up exhaust over time. Your A/F meter is worthless. The way the Subaru management is setup you don't need a wideband O2 sensor to get proper fueling like Honda uses since most of them have an airflow meter. The only thing your O2 sensor is reading is the area around complete combustion.
Anyway, getting a new ECU or chip or whatever you're talking about will not fix your fuel economy problems. I'd probably go with some sort of ignition breakdown theory at the moment since like I said before any problem with most other engine parts that have to do with proper fueling should be detected by the ECU.
Old 02-24-2004, 12:00 AM   #15
LB2.5rs
Member#: 41107
2003 Toyota Tundra
what do you mean? You think it has something with my ignition? I hope not Haha and yeah I know my stupid air/fuel is useless, I just figured maybe it was doing a little bit of its job, since i seem to be getting horrible fuel mileage. Could I possibly need to run a little bit better fuel? Like right now I just use regular. Also whats the MIL?? Ive been gettin a cel ever since my headers...so i figured it was associated with those, I couldnt be something else could it?
I think im going to go ahead and still buy the proecm since it sounds like a good thing to have, even if it doesnt fix my air/fuel. Gets rid of that dang rev limiter and speed limiter(not that I got anywhere near max speed ) Plus 4hp and 7ftlb trq. Then its time to start on my suspension!!
Old 02-24-2004, 09:05 AM   #16
mbeach
Member#: 39807
I could pull your code real quick next time we run into each other. I keep an Actron scanner in the car 24/7.
I asked about the plugs because they are like little "dipsticks" for your cylinders. If you're running rich or lean they'll tell you -with a good degree more reliability than your A/F guage.
I was thinking ignition as well, but I was waiting on your plug response.
Barring driving around with your parking brake on, I have found that sudden excessive fuel consumption is nearly 100% ignition related. Likely to be something simple, and easily remedied by a tune-up.
Old 02-24-2004, 11:43 AM   #17
LB2.5rs
Member#: 41107
2003 Toyota Tundra
Tune up as in what? Do you think I could use new plugs? When I bought the car the guy had already ordered new wires and plugs from subaru. They shouldnt go bad in like 8 months should they?
Old 02-24-2004, 03:10 PM   #18
mbeach
Member#: 39807
Are you sure they were new? Did he give you the old plugs/wires?
I say pull the plugs for inspection. Only on rare occasions will you need to do any more than clean them up. At least you will know whether you're running rich or not.
Old 02-24-2004, 03:15 PM   #19
LB2.5rs
Member#: 41107
2003 Toyota Tundra
Yeah I bought the car before they arrived to the dealership. His mom lives down here and she delieverd them, and we had our mechanic install them. Is it easy to pull the plugs? I heard they were hard to get to on out engines.
Old 02-24-2004, 06:49 PM   #20
CheezeWeezle
Member#: 17187
2009 Braun Entervan
Gimpy White
Whenever he gets his plugs pulled I want to be there so you can pull my plugs...I'm over the 30k mark...
Old 02-24-2004, 07:42 PM   #21
LB2.5rs
Member#: 41107
2003 Toyota Tundra
Trent I thought your wife pulls your plugs We could check em sat...my proecm will be in friday
Old 02-24-2004, 08:18 PM   #22
CheezeWeezle
Member#: 17187
2009 Braun Entervan
Gimpy White
I had plugs? I never knew I had em'....She never tells me anything!
Old 02-24-2004, 10:12 PM   #23
WRX02WRB
Member#: 36240
2015 STi
Why do your posts allways go completly off the topic ... it must be a n00b thing
Old 02-24-2004, 10:18 PM   #24
LB2.5rs
Member#: 41107
2003 Toyota Tundra
Hey atleast I havent screwed my engine!!!nOOb driver!! Sat would be a perfect day to do stuff...since its suppose to be like 58
Old 02-24-2004, 10:30 PM   #25
WRX02WRB
Member#: 36240
2015 STi
Remind me to smack you the next time i see you .... thats like saying "your momma's going to Die" not cool .... i know you joking but still .....
Edit: Now that i look at those 2 quotes together ... you sir are teh n00b
Will anyone help me do my springs this week? morph1n3 New England Impreza Club Forum -- NESIC 16 04-14-2008 04:15 PM
ATX - anyone willing to help me install GregsWRX Texas Impreza Club Forum -- TXIC 2 12-08-2007 07:59 PM
Would any gurus in SE MI be willing to help me install JDM HID headlights? Jackie Mid West Subaru Owners Club Forum -- MWSOC 1 07-07-2007 10:50 PM
If I buy a UTEC will anyone help me tune it??? 02bump'nWRX Canada Region Forum 8 06-04-2003 11:10 AM
Anyone have a nice warm garage will to help me install a skidplate? snowbrdrfromnh New England Impreza Club Forum -- NESIC 1 02-01-2001 04:48 PM
