Old 02-23-2004, 07:12 PM   #1
03WRX83
Member#: 30246
0394 WRX/Supra
WRB/White
Default Idle Fluctuation?
It seems when my car idles that it fluctuates, but not alot. You cant visually see it with the tach. But the exhaust note and engine make it seem like it is slightly going up and down(very slightly).
Is this normal.
My set up is cobb stage 2, catless, uppipe, gfb bov, kn filter.
03WRX83 is offline   Reply With Quote
Old 02-23-2004, 10:10 PM   #2
Don Arm
Member#: 17520
2002 Impreza WRX
Midnight
Mine has been doing the same thing recently. I really didn't notice the problem at first.
Probably the best thing to do is let Cobb know, which is what I'll be doing if it doesn't settle down over the next few weeks.
Don
Don Arm is offline   Reply With Quote
Old 02-23-2004, 11:26 PM   #3
03WRX83
Member#: 30246
0394 WRX/Supra
WRB/White
yeah i will notify them also.. you notice how slight it is though, you can't really tell unless you really concentrate on it.
Old 02-24-2004, 12:45 AM   #4
BoostdBoxer
Member#: 53163
seems like a/f ratios are going haywire and your Computer is trying to compensate harshly. Did the same thing to me when I was venting to the atmosphere
BoostdBoxer is offline   Reply With Quote
Old 02-24-2004, 04:12 AM   #5
Delicious Tuning
Member#: 1990
Well I have seen this with many cars that are Catless or have an aftermarket BOV.
The stock BOV works a little differently then all the aftermarket ones. So more than likely it might be a combination of the two. try switching the stock one back on and see what happens. if it is not that, then more than likley not haveing the backpressure the car is expecting a little bit, will also cause a slight fluctuation.
Cheers,
Bill Knose
Tuner I-Speed USA
Delicious Tuning is offline   Reply With Quote
Old 02-24-2004, 02:19 PM   #6
03WRX83
Member#: 30246
0394 WRX/Supra
WRB/White
so is it okay for it to be doing this. Its so slight that no one else can tell. Or i just might be imagining things.
Old 02-24-2004, 04:44 PM   #7
03WRXMA
Member#: 35081
2012 WRX
Its the nature of the beast, nothing to be worried about.
FWIW it prob. did it when it was stock, you just couldnt hear it.
03WRXMA is offline   Reply With Quote
Old 02-24-2004, 05:54 PM   #8
Angulimala
Member#: 43814
2004 WRX Wagon
Silver, SPT exhaust
I'm thinking 03WRXMA hit it on the head...
My wagon's idle fluctuates a bit ... but i didn't notice until I got the SPT exhaust installed.
Angulimala is offline   Reply With Quote
Old 02-25-2004, 05:31 AM   #9
Delicious Tuning
Member#: 1990
I know my RS back in 99 was so quiet I couldn't even tell it was running. As the years went buy it got rougher and rougher. Things wear out and like 03WRXMA said, it is the nature of the beast. Nothing to worry about.
idle fluctuation on 05 wrx Hard Body Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-17-2009 06:40 PM
89 XT GL Wild Idle fluctuation myxtgl 'Old School' Subaru Forum 4 11-19-2008 12:42 PM
Fluctuating Idle? JerryDodrill Normally Aspirated Powertrain 17 05-22-2008 07:10 AM
Idle fluctuating at startup and at a roll! Fuel cutoff at 5k.. joelikewhoa Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 02-28-2008 05:51 PM
idle fluctuations wil06STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 10-03-2007 10:35 PM
