Old 02-23-2004, 06:24 PM   #1
deyoungc
Member#: 55211
1999 Legacy Outback
Default spark plug wear
I just changed my spark plug/wires in my '99 Legacy Outback. It was the first time changed (60k miles). I noticed that cylinders 1 and 3 had a considerably higher amount of wear than those from 2 and 4 (1 and 3 had rounded center electrodes, where 2 and 4 still had a noticable point...the plugs were NGK double platinum). Is this common, or is there a problem with cylinders 1 and 3?
Any help or advice would be appreciated.
Thanks, Chad
deyoungc is offline   Reply With Quote
Old 02-25-2004, 01:19 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Somebody may have been lazy and just changed the 2 on one side......
Old 02-25-2004, 02:59 AM   #3
xxtwowheelfiendxx
Member#: 47597
1997 ///M3
'93 Impreza
also might not of been gapped correctly. Did you gap the new ones you put in?
xxtwowheelfiendxx is offline   Reply With Quote
Old 02-25-2004, 02:20 PM   #4
deyoungc
Member#: 55211
1999 Legacy Outback
I didn't ask for the mechanics to change my spark plugs on my 30k check-up. So I would assume that they didn't touch the plugs.
As for gapping. I checked all the gaps in my new plugs and they were all pre-gapped at .041, which is in the middle of the recommended gap (.038-.043).
Spark Plug FAQ: Read if you want spark plug information! Unabomber Service & Maintenance 708 06-22-2016 10:58 AM
Replacing Spark Plugs - What else Compliments Spark Plug replacements? FIlters? jungleman Service & Maintenance 2 02-09-2009 03:45 PM
NEED: Plug/Clip that plugs into WRX spark plug coil BeBop86 Private 'Wanted' Classifieds 16 07-16-2008 03:05 AM
Help! Sparks between distributor cap and spark plug wires! Stickee Normally Aspirated Powertrain 13 04-23-2003 11:23 AM
Ignitions, spark plugs & plug wires? scubaracer Normally Aspirated Powertrain 8 03-19-2002 04:17 AM
