Old 02-23-2004, 06:58 PM   #1
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
Default Does the odometer work without the ecu plugged in?
I just got my WRX set up to the tow vehicle behind my rv and was wondering if the miles will show up if I tow it with the ECU unplugged.
LiquidForce is offline   Reply With Quote
Old 02-23-2004, 07:21 PM   #2
03WRXMA
Member#: 35081
2012 WRX
I dont think it would even with the ECU plugged in as long as you were in Neutral, which you will be Id hope
Also it wont work if the Battery is unhooked, no power = no reading.
-Dave
edit: the guys in the electrical and lighting forum may know better...
03WRXMA is offline   Reply With Quote
Old 02-23-2004, 07:55 PM   #3
GMTarkin
Member#: 9237
2008 Saab Turbo X
400+ lbft
make sure you put a cover over your car, i've seen alot of cars pulled by RV's with the bumpers uncovered and what not, thats just asking for a chipped up windshield, hood, and front bumper
GMTarkin is offline   Reply With Quote
Old 02-23-2004, 10:28 PM   #4
Kha0S
Member#: 8808
2011 WRX
DGM 5D
You can also just unplug the speed sensor harness from the sensor where it goes into the side of the gearbox (next to the downpipe on the passenger side of the tranny)... just throw a piece of duct tape over the contacts on the sensor to keep it from getting gummed up from road grime.
/Andrew
Kha0S is offline   Reply With Quote
Old 02-24-2004, 07:54 AM   #5
LiquidForce
Member#: 12811
2002 2.5l Wrx
I was thinking of getting on of those clear film bras on the front and installing on of those rock guards on the back of the rv.
I am going to post over in the electical forum. It would be nice to not have to go under the car to disable it.
thanks
Mike K
Old 02-24-2004, 02:24 PM   #6
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
I replaced my ecu in my car with a Link+ wire-in. The odometer still operates.
Drac9 is offline   Reply With Quote
Old 02-24-2004, 04:19 PM   #7
jeep_kevin
Member#: 47945
2004 Forester XT
/Andrew
I would like to do the same on my forester, is this the white cable that connects to the tranmission on the pasenger side, that is the only one I could find but it appears to be connected to the gear selector aswell.
Thanks
Kevin
jeep_kevin is offline   Reply With Quote
Old 02-26-2004, 10:47 AM   #8
jeep_kevin
Member#: 47945
2004 Forester XT
Thanks
Kevin
Anyone? Bueler? Anyone? - seriously if anyone can answer this it would be great, planning a trip in May.
2004 STI Turbo XS Utec ECU plug in Scoobey03 Engine/Power/Exhaust 2 08-23-2009 09:01 PM
I want to be able to turn the headlights on without the key in the ignition bomber991 Electrical & Lighting 4 10-22-2008 11:40 AM
How does the antilag work on the Hydra? Crazykev Other Engine Management 2 10-15-2005 07:11 PM
When the mouth works without consulting the brain... Asinine Off-Topic 21 07-06-2005 02:53 PM
does the resistor work on the 04 wrx devin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-21-2003 07:29 PM
