Old 02-23-2004, 11:44 PM   #1
BoostdBoxer
Member#: 53163
Question About Stock O2 Sensor
i am not too savy on oxy sensors so what I am going to ask is simple:
Can you get a wideband Oxy Sensor aftermarket for the WRX or /WRX STI, and if so what brand would be the one to go with. I already have Greddy emanage running like a champion thanks to the awsome support of Dan From Godspeed (Vendor) but i want to be able to more in depth tune my engine by having better a/f readings.
thankyou
BoostdBoxer is offline   Reply With Quote
Old 02-24-2004, 03:13 AM   #2
Delicious Tuning
Member#: 1990
You can get one, though you should nto be replacing the stock Wide Band O2, as it is designed to be used with the stock ECU. Though you can get an aftermarket one from say Innovative, and have a bung welded in and then check your readings through that.
Cheers,
Bill Knose
Tuner I-Speed USA
Delicious Tuning is offline   Reply With Quote
Question about front O2 sensor. AudiobahnSTI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 24 03-02-2006 11:21 AM
Question about front O2 sensor??? AudiobahnSTI Electrical & Lighting 1 02-28-2006 08:30 AM
Question about rear O2 sensor BHodges3 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 08-11-2005 05:04 PM
Question about cleaning o2 sensors DreddRS25 Service & Maintenance 2 03-29-2005 01:05 PM
Question about rear O2 sensor Speedy02wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-29-2003 06:01 AM
