Old 02-24-2004, 12:02 AM   #1
xxtwowheelfiendxx
Member#: 47597
1997 ///M3
'93 Impreza
Unhappy The Guess where my oil is leaking from game!!! *pic*
so yeah its coming from somwhere, and when i drive it flys back on my exaust and smokes like a banshee. My oil filter WAS loose, like 1/2 a turn and i thought that was it, but it keeps leaking
and it allways beads up in those two spots after its sits for the night
xxtwowheelfiendxx is offline   Reply With Quote
Old 02-24-2004, 03:03 AM   #2
555bat
Member#: 53464
98 impreza
white
crank seal
555bat is offline   Reply With Quote
Old 02-24-2004, 10:29 AM   #3
outback_97
Member#: 30874
0897 OUTBACKS
and 2003 TS wagon
My '97 Legacy (2.5l DOHC) leaked from the oil pump gasket, causing this, it looks kinda like yours:
Steve
outback_97 is offline   Reply With Quote
Old 02-24-2004, 10:31 AM   #4
vvk
Member#: 6436
1998 Impreza 2.5RS
BDP
Take care of this right away. A timing belt contaminated with oil will not last very long.
vvk is offline   Reply With Quote
Old 02-24-2004, 10:50 AM   #5
xxtwowheelfiendxx
Member#: 47597
1997 ///M3
'93 Impreza
so what can i do to fix it?! and approx how much will it cost?
Old 02-24-2004, 02:25 PM   #6
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
What can you do to fix it? Replace the seals . If you can turn nuts/bolts, you can do it yourself. Pull your timing covers off, and you'll see the beast you are up against. The parts are fairly cheap- the cost of the repair is labor time.
Brian
Old 02-24-2004, 09:35 PM   #7
xxtwowheelfiendxx
Member#: 47597
1997 ///M3
'93 Impreza
Brian
So you think its the crank seal? i figured you had to take the crank out to replace that baby. lol like on a Harley :P
well ill take that baby off this weekend and see what it looks like. Should i buy a manual so i can time it again?
Old 02-24-2004, 10:35 PM   #8
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
It's likely the crank seal, and if not that, the oil pump to engine block seal. They are both very easy to replace once you have the timing covers off, and they are both very cheap parts. No highly specialized tools necessary, and no need to dismantle the engine to get at them . You'll need an 806733030 and an 10991AA000 or 806919050 (either will work, though the 806919050 is meant for your car and is about $0.50 more) to get the job done, and you might consider picking up some RTV and resealing the oil pump for good measure while you're in there.
Brian
Old 02-24-2004, 10:47 PM   #9
xxtwowheelfiendxx
Member#: 47597
1997 ///M3
'93 Impreza
Brian
Thanks alot man, appreaciate it. and what is RVT? will HondaBond work?
and i find it hard to believe i can get to the crank seal without taking the timing belts off we'll see i guess
Old 02-26-2004, 06:11 AM   #10
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
***?, there was no comment about NOT having to remove the timing belt, just no need to disassemble the engine.
You need to pull ALL the belts, crank pulley, timing belt cover and timing belt.
The rest is easy.
Old 02-26-2004, 11:10 AM   #11
xxtwowheelfiendxx
Member#: 47597
1997 ///M3
'93 Impreza
i think i might have to pick up a manual for this one
thanks for the heads up
The rest is easy.
Old 02-26-2004, 11:54 AM   #12
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
Hondabond = Fujibond = RTV
You will need to remove the Tbelt to do this, yes.
Brian
Old 02-27-2004, 07:24 PM   #13
granteeton
Member#: 53529
that doesn't look like a crank seal, it looks like an oil pump leak. reseal the oil pump and replace the oil pump o-ring.
granteeton is offline   Reply With Quote
Old 03-04-2004, 01:07 PM   #14
shields102
Member#: 9598
02 wrx
white
Yeah, I gotta say that is deffinatly the o-ring on the oil pump. Super common.
shields102 is offline   Reply With Quote
Old 03-04-2004, 04:35 PM   #15
hawksoob
Member#: 51978
1996 Legacy Outback
Red
Just had this done. Oil pump seal/O-ring. Crank seal for good measure. New T-belt, for same said measure.
Stealer was to charge $800. Local guy did it for $375.
hawksoob is offline   Reply With Quote
Old 03-04-2004, 06:02 PM   #16
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
Um, the front crank seal goes through the center of the oil pump, and as for the rest
No real need to restate the solutions that he already has
Brian
Oh damn! i think i found out where all my oil is going. blackie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 04-16-2005 03:56 PM
so my car is leaking a lot of oil... how to clean? Keith Off-Topic 13 06-01-2004 06:47 PM
My car is leaking..which dealer I should bring in to ?? PKduck Bay Area Impreza Club Forum -- BAIC 7 01-29-2002 04:03 PM
My uppipe is leaking and i have to do it again. I a have a few ?? WRBLUEWAGON Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 01-16-2002 01:16 PM
('93-'01) HELP! My Cooling is leaking! LarryMak Impreza Forum 16 05-10-2001 05:32 AM
