Old 02-24-2004, 12:48 AM   #1
ESTCOASTSUPORTER
Member#: 34254
2003 WRX
WHITE
Default Hooking up a shift light to a Utec
Is it possible to hook a motec multi stage shift light into the UTEC.
ESTCOASTSUPORTER is offline   Reply With Quote
Old 02-24-2004, 02:13 AM   #2
eightballrj
Member#: 18520
2005 L GT Limited
.... why not just use the integrated utec shift light?? I think that the motec one might just use tach signal. So, it probably has nothing to do with the UTEC. Just find the wire that comes off the ECU that contains the tach signal and T into it. But, instead of spending money on that shift light... unless you want to... just wire up some LEDs to the utec and use them.
Richard
eightballrj is offline   Reply With Quote
Old 02-24-2004, 03:16 PM   #3
ESTCOASTSUPORTER
Member#: 34254
2003 WRX
WHITE
i have the motec shift light sitting around so i figured i would use it but im confused hook to hook it up
Old 02-24-2004, 03:42 PM   #4
03WRXMA
Member#: 35081
2012 WRX
Tap into the tach signal wire, and some power for as mentioned above, its not hard.
And its def. not engine managment and tuning, try the electrical forum
03WRXMA is offline   Reply With Quote
Old 02-25-2004, 01:12 AM   #5
ESTCOASTSUPORTER
Member#: 34254
2003 WRX
WHITE
well since i was asking about it tapping into UTEC this would the place to ask that.
Old 02-25-2004, 11:40 PM   #6
500hpwrxsti
Member#: 22459
2002 WRX GT40R
700AWHP but whos counting
Im guessing his question is if anyone knows exactualy which wire to tap into for that signal for the light to work properly, wheather it be the utec wire or the factory ECU wire.
500hpwrxsti is offline   Reply With Quote
how to hook up a 12V source to LED strip light? starcraft227 Electrical & Lighting 2 05-31-2009 12:14 AM
Help me hook up my Tuner-Bosch to UTEC Peeblesmx445 UTEC 13 03-14-2006 12:33 PM
Is there any way to wire up a shift light? YourMother'sLover Texas Impreza Club Forum -- TXIC 25 07-02-2005 02:15 PM
Hooking up STI intercooler spray to UTEC? Stiguy247 Mid Atlantic Impreza Club -- MAIC 6 05-19-2005 06:30 PM
How to hook up shift light to utec? dman918 Engine Management & Tuning 5 04-28-2003 08:51 PM
