Old 02-24-2004, 02:01 AM   #1
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
Default standalone people:how do you know when a sensor is bad
im just sitting here reading debates over fuel temp and that theres a temp sensor in the gas tank...how would u know if that thing ever went wrong? or any sensor for that matter, is there like a general que of all sensors?
im just asking because im going to be installing my link plus within the next month and am just thinking
thanks
alex
Old 02-24-2004, 03:19 AM   #2
Aaron'sWRX
Member#: 34150
02 WRX
Post
edited: Because the ? makes sense now...
Aaron'sWRX is offline   Reply With Quote
Old 02-24-2004, 03:36 AM   #3
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Old 02-24-2004, 04:21 AM   #4
Delicious Tuning
Member#: 1990
Do you have a check engine light? If you have the stock ECU, it shoudl tell you what is working and what is not. If you have no CEL's my bet is it is working. The stock ECU is quite smart.
Cheers,
Bill Knose
Tuner I-Speed USA
Delicious Tuning is offline   Reply With Quote
Old 02-24-2004, 11:02 AM   #5
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
doesnt standalone overwrite the ecu?
Old 02-24-2004, 02:00 PM   #6
Delicious Tuning
Member#: 1990
Standalone does not write over the ECU. Standalone does not communicate with the stock ECU in any way, that si why it is called Standalone.
A Standalone works by itself and does not require the aid of another ECU to run the engine and car. Examples of NON-Standalones are the Xede, UTEC, Unichip, AFC, ITC, Boost Controllers, ETC...
The Stock ECU will not be overwritten, in fact nothing will change on it at all.
Cheers,
Bill Knose
Tuner I-Speed USA
how do you know when stock suspension is gone? subieHED2005 Brakes, Steering & Suspension 5 02-26-2009 07:14 PM
how do you know a stock BOV is bad? chadlee Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-15-2005 01:46 PM
How do you know when the Turbo is shot. eatwrx Engine Management & Tuning 5 10-06-2004 01:35 AM
How do you know when EGT gauge is going bad? Jsunn Interior & Exterior Modification 1 07-16-2003 10:21 AM
When do you know when a Subaru is really SAFE to go go all out Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 7 12-17-2001 10:46 PM
