Old 02-24-2004, 02:58 AM   #1
mofoporn
Member#: 4766
2001 2.5 RS
BRP
Default Car starts but wont stay on... need help
Heres the problem on my brothers 2000 2.5RS. This problem all started one night when he was driving home and it sputtered and died. He started it againd drove it and then it died again. Now it wont stay on... it will start but die right away. Sparkplugs are good, wires are good, getting plenty of spark. Now, we think it is something to due with fuel. We took the fuel filter off and there wasn't that much pressure in the line (this is right after starting it so there should have been plenty of pressure). Then with the fuel filter off, we started it and there was no fuel coming out of the line. It should have been spraying out right?? So... fuel pump problems? We are going to look at that tomorrow. There is a 1/4 tank of gas and no engine codes. Any help will be greatly appreciated.
Thanks
Kurt
mofoporn is offline   Reply With Quote
Old 02-24-2004, 12:22 PM   #2
Hayes
Member#: 11808
First check fuel pump fuse and then the connections on top of the pump. Ed Hayes
Hayes is offline   Reply With Quote
Old 02-24-2004, 12:36 PM   #3
vile
Member#: 32371
'02 t-rex wagon
platinum
i think u've just diagnose your problem. it's most likely the fuel pump. that, or maybe it's an electrical connection to your fuel pump. maybe a connector got dirty or the contact point is getting bad, but these are highly unlikely though, never hurt to check. oh yeah, what could wear is the fuel pump relay contact.
i don't it's the fuse as the pump would not have turned on at all.
vile is offline   Reply With Quote
Car starts but won't run - VIDEO! HELP! trilap5e Normally Aspirated Powertrain 5 09-26-2013 04:16 PM
Motor wont turn on need help ajg10730 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-01-2009 05:32 PM
Starts, but can't stay running.... Danny Boy Normally Aspirated Powertrain 22 12-26-2007 11:43 AM
Car cranks but wont start up!! 04subyrex Newbies & FAQs 19 10-15-2007 12:05 PM
