Old 02-24-2004, 01:43 PM   #1
twotacosfor99cents
Member#: 14997
Default 2003 Outback dies while cruising on freeway/30-40mph?
I'm posting this for a friend -
His 2003 legacy outback has been having some problems, it suddenly dies on either the highway, or cruising at 30-40 mph..
the car will restart without a problem, and has no CEL codes.
The dealership looked at the car and found that there was nothing wrong with the car that they could see (in typical dealership fashion).
Any suggestions?
twotacosfor99cents is offline   Reply With Quote
Old 02-24-2004, 03:23 PM   #2
joubtt
Member#: 33901
04 04 STI
No AWD, Not interested
Hmmm, check battery connections, spark plugs, and the main electrical fuse(~60amps). You could also have someone scan it.
joubtt is offline   Reply With Quote
Old 02-24-2004, 05:20 PM   #3
MattDell
Member#: 16803
Same thing used to happen to me, and restarted without a problem and I had no CEL
My knee was hitting the key, and turning the car off.
-Matt
MattDell is offline   Reply With Quote
Grinding noise while slow, Vibration while on Freeway, Only front right wheel? HELP AjntOrnj Transmission (AT/MT) & Driveline 11 10-01-2009 10:10 PM
I was *this* close to being in a 30-40mph head-on collision. Cole Off-Topic 30 11-06-2008 12:34 PM
Hydra: Car died while cruising. Will not start again. BiggSean Other Engine Management 17 03-18-2008 10:53 AM
My bat died while running on idle???/;?/ Rallly2000 Electrical & Lighting 6 02-06-2008 04:27 PM
Stage 4 setup - CEL while cruising on highway Sausage Newbies & FAQs 7 07-14-2006 10:00 AM
