Old 02-24-2004, 02:02 PM   #1
jetskizero
Member#: 13833
2002 Impreza WRX
Silver - Sold :(
Question TXS Stg4+FMIC Overboost P0244 (log included)
Car info: Standard TurboXS Stage 4 with FMIC, base Stg4FMIC map with boost values cut down to 190 max.
What kind of CLB values are folks using to keep their Stg 4 cars under the fuel cut/overboost? With the ABC 2 turns out, and a max CLB boost value of 190 I'm still logging over 20psi. I've been tripping the check engine P0244 code.
Question is: If I'm not knocking should I raise the overboost threshold or back off the CLB even further? Is there some increment that equates to about 1 psi? (100, 50?)
Thanks!
4975 +13.3 4.4 98 80 00 rich +18.0 100.0 +19.2 -5.5 190.00 4.2
5208 +17.0 4.5 98 90 00 rich +18.9 100.0 +18.8 -4.9 190.00 4.2
5224 +18.6 4.5 98 100 00 rich +17.1 100.0 +18.0 -5.0 190.00 4.3
5299 +19.2 4.5 98 90 00 rich +17.7 100.0 +19.2 -4.8 190.00 4.3
5359 +19.8 4.6 98 90 00 rich +18.3 100.0 +19.6 -4.8 190.00 4.3
5509 +20.0 4.6 98 100 00 rich +18.8 100.0 +19.0 -5.1 190.00 4.3
5630 +20.0 4.6 98 100 00 rich +19.1 100.0 +19.0 -5.1 190.00 4.4
5737 +20.6 4.6 98 100 00 rich +20.2 100.0 +19.0 -5.0 190.00 4.4
5817 +20.2 4.7 98 90 00 rich +19.5 100.0 +21.0 -5.1 190.00 4.4
5931 +19.4 4.7 98 90 00 rich +20.3 100.0 +21.0 -5.1 190.00 4.4
6016 +19.4 4.6 100 90 00 rich +20.9 100.0 +21.0 -5.1 190.00 4.4
6265 +19.0 4.7 98 90 00 rich +21.0 100.0 +21.0 -5.1 190.00 4.4
6172 +19.0 4.7 98 90 00 rich +24.9 100.0 +21.0 -5.1 190.00 4.4
6361 +18.6 4.7 98 90 00 rich +25.5 100.0 +21.0 -5.1 190.00 4.4
6373 +18.4 4.7 98 90 00 rich +25.6 100.0 +21.0 -5.1 190.00 4.5
6535 +18.6 4.7 100 90 00 rich +26.3 100.0 +21.0 -5.1 190.00 4.4
6600 +18.4 4.7 98 90 00 rich +27.0 100.0 +21.0 -5.1 190.00 4.5
6680 +18.4 4.7 98 90 00 rich +27.2 100.0 +21.0 -5.1 190.00 4.4
6720 +18.8 4.7 98 90 00 rich +27.9 100.0 +21.0 -5.1 190.00 4.4
jetskizero is offline   Reply With Quote
Old 02-24-2004, 02:13 PM   #2
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Turn your ABC down a turn. That should help.
Is it just me or are you maxing your STi injectors really easily. Go get a tune.
mbiker97 is offline   Reply With Quote
Old 02-24-2004, 03:53 PM   #3
hippy
Member#: 36528
2002 Impreza Wrx
You're car looks like it's movin a TON of air... What kinda turbo do you have on that thing? What kinda intake? What's your gain set to? Does closing the abc or lowering the boost number actually lower the boost any more then that at that rpm? Is it just me, or is your injector duty cycle 100% from 4900rpm on?
Old 02-24-2004, 04:05 PM   #4
03WRXMA
Member#: 35081
2012 WRX
Since TXS says to block fill 200 into the CLB map, and your using less, I would agree and say that your ABC is out too far as mentioned above.
Also that IDC would scare the crap out of me
-Dave
03WRXMA is offline   Reply With Quote
Old 02-24-2004, 05:04 PM   #5
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Either you have a huge turbo or your MAF sensor is screwed up. That's some serious air!
Just checking, are you sure you are running cloced loop boost control? You did turn it on right? Default is open loop boost. If so, what do you have the gain set to? 45 produces a ~2 psi spike, 48 almost nothing.
IDC's static, ho hum...... Wideband tune would be nice.
Calibrate your TPS as well please.
have fun
mick_the_ginge is offline   Reply With Quote
Old 02-24-2004, 05:23 PM   #6
powbmps
Member#: 27543
I have a similar situation (in regards to boost values). With a maximum boost value of 180 and the ABC out two turns, I get 21 psi. With one turn out I get 18 psi. This is with an 18g and 600cc injectors. Untuned I'm getting max idc's of about 85%.
Chris
powbmps is offline   Reply With Quote
Old 02-24-2004, 07:08 PM   #7
jetskizero
Member#: 13833
2002 Impreza WRX
Silver - Sold :(
LOL - yeah, no kidding about the tune!
Earlier in the week, I tried values at 260 with the ABC completely closed, but that yielded similar results. I wanted to see if the ABC bleeding off pressure would keep the ECU happier.
As far as the IDC's, my thought is that it's running pig rich, my greddy (semi-narrow-wide-whatever) A/F shows around 10:1. Even the base map says 10.9:1 in the comment.
Ok, so I'll
1) Call TXS to setup an appointment for a tune.
2) Lose a turn off the ABC (isn't that only good for 1/2PSI?) and re-log.
3) Drop another 40 off the CLB values (to 150) and re-log.
But again, if I'm not knocking, other than the way-too-high IDC's, that VF34 is spoolin'!
Thanks for the help too - it's always good to get some outside feedback.
Old 02-24-2004, 07:12 PM   #8
nmyeti
Member#: 4980
Default Re: TXS Stg4+FMIC Overboost P0244 (log included)
Thanks!
Any chance you forgot to change your parameters to "closed loop boost" when you uploaded the FMI map?
The symptoms point to that. If that's not the case then, you may have a waste-gate issue.
-Nathan
www.turboxs.com
nmyeti is offline   Reply With Quote
Old 02-24-2004, 07:17 PM   #9
nmyeti
Member#: 4980
Chris
The 18G from forced performance typically comes with a fairly stiff waste-gate spring. I suggest you try the following.
1. Run a single piece of vacuum/boost line from the nipple on the compressor cover to the waste-gate actuator. Run the car like this and check max boost. I bet you'll see results in the 18-20psi range as it sits.
2. Change the boost control special constant to "open loop boost"
3. Change your boost map to all "1"
Run the car as above and record the boost values. It should be the same or very close to the same as your waste-gate only boost. If it is higher, you have a leak in one of your boost lines.
If your boost is very high when only the waste-gate is in control, you can lengthen the waste-gate actuator rod to take some of the preload off the diaphragm. This should allow you to bring the boost down quite a bit. I'd set it at about 15psi.
Old 02-25-2004, 09:12 AM   #10
jetskizero
Member#: 13833
2002 Impreza WRX
Silver - Sold :(
FYI All - I verified last night that it is and was set to CLB. Also, the boost gain is at 50 (default) and hasn't been changed.
So, would it be a wastgate flow issue (needs to be ported)?
Or a solenoid problem?
Or the stock boost controller reacting too slow? Maybe it's time for an electronic (seperate from UTEC) boost controller?
Thanks again!
Old 02-25-2004, 10:47 PM   #11
nmyeti
Member#: 4980
Thanks again!
Try that and report back your results. With a VF30/34 you should get around 10psi. If you get more you'll need to look into a few other things. There are several causes of over-boost in the above conditions. What down-pipe are you running?
Report back on your findings and Iíll try to help you get this fixed.
-Nathan
www.turboxs.com
Old 02-26-2004, 12:27 AM   #12
MustGoFast
Member#: 33370
2002 Impreza WRX
Blue now w/ 6 fun flavors
remember the 2 turns out assumes a wasteate spring of a vf30/34.. W/ THE 18G and tougher wastegate spring the same settings are going to get you much greater boost.. I want to say the FP 18G came w/ a 14lb spring (memory but could be wrong).
MustGoFast is offline   Reply With Quote
Old 02-26-2004, 10:50 PM   #13
jetskizero
Member#: 13833
2002 Impreza WRX
Silver - Sold :(
There's definately something out of whack - I'll try the advice above and run a direct line from the compressor to the wastegate diaphram. Right now, I believe there is a "T" off the direct line from the compressor outlet to the wastegate actuator, off the "T" is a small section of hose then a "Y" adapter that splits the line - One to ABC, and 1 to Factory boost control solenoid.
Another thing I tried tonight on the way home was the the "valet" mode (switch 6), but it still produced well over 13psi - it also seemed like this map had the stock fuel, and not map 1 fuel, because I noticed this switch setting ran excessively high EGT's without much load on the motor. Due to the high EGT's I didn't push it much.
I also ran a map with CLB at 150 max, and peaked at 21.x psi. I'll post the log tomorrow around 10am. Funny thing is that with the boost friendly temperatures, it didn't knock at all... Yeah!
Oh, and I've got the TXS downpipe - of course
Thanks for the help!
Old 02-27-2004, 10:18 AM   #14
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
This might help us to find your problem too. Exactly what performance parts are you running? Anymore stage 4 doesn't mean stage 4.
Old 02-27-2004, 01:12 PM   #15
jetskizero
Member#: 13833
2002 Impreza WRX
Silver - Sold :(
As promised, here's a snippet from the 150 CLB log.
4734 +19.2 4.5 98 90 00 rich +13.1 99.0 +17.8 -5.2 150.00 4.2
4796 +20.2 4.5 98 100 00 rich +13.4 99.0 +17.1 -5.2 150.00 4.2
4789 +20.0 4.5 98 100 00 rich +13.3 99.0 +17.4 -5.3 150.00 4.2
4852 +20.0 4.5 98 100 00 rich +14.0 99.0 +17.5 -5.3 150.00 4.2
4866 +20.4 4.5 98 100 00 rich +14.8 99.0 +17.4 -5.2 150.00 4.2
4967 +20.4 4.4 98 100 00 rich +15.1 99.0 +17.6 -5.2 150.00 4.2
4997 +20.8 4.5 98 100 00 rich +15.0 99.0 +17.9 -5.2 150.00 4.3
5020 +21.0 4.5 98 100 00 rich +16.1 99.0 +18.0 -5.1 150.00 4.3
5058 +21.5 4.6 98 100 00 rich +17.3 99.0 +18.0 -5.0 150.00 4.3
5096 +20.8 4.6 98 100 00 rich +17.4 99.0 +18.0 -5.1 150.00 4.3
I'm going out to buy some vaccuum hose and I'll report back. Maybe it's just a bad factory wastegate solenoid.
I still can't believe it doesn't knock on 93 octane (thanks TurboXS default map!) - but I'll be buying all my gas from the same gas station from now on
Oh, as far as stg 4, it's got:
Injen intake cut short (like in the brochure pictures)
TXS DP, racepipe, Mid pipe, Blitz muffler
VF34
Vishnu Uppipe
Hyperflow (TXS) FMIC
UTEC (stg 4 base map, CLB, boost map lowered to 150 max, default timing and fuel)
NGK 1-step colder plugs
Sti injectors, Walbro fuel pump
(I think that's all that's relevant.)
Old 02-27-2004, 05:58 PM   #16
jetskizero
Member#: 13833
2002 Impreza WRX
Silver - Sold :(
Ok, so direct vaccuum hose from the compressor outlet nipple to the wastegate actuator on the turbo. Couldn't find open road to get a 3-4 gear pull, but 2nd gear still boosts like mad.
So, now we've isolated that it's a problem with either the actuator or the length of the actuator rod?
4816 +10.8 4.1 99 50 00 rich +19.4 75.0 +22.0 -5.8 150.00 3.8
4960 +11.3 4.1 98 60 00 rich +19.6 80.0 +21.9 -6.1 150.00 3.9
5159 +11.3 4.3 98 60 00 rich +20.3 88.0 +22.0 -6.0 150.00 4.0
5376 +11.9 4.3 98 60 00 rich +19.6 98.0 +22.0 -5.6 150.00 4.1
5574 +13.5 4.5 98 70 00 rich +21.5 99.0 +21.2 -5.5 150.00 4.3
5747 +14.9 4.6 98 90 00 rich +21.8 99.0 +20.7 -5.1 150.00 4.4
5952 +16.4 4.7 99 80 00 rich +22.0 99.0 +22.0 -5.4 150.00 4.4
6242 +17.6 4.7 98 80 00 rich +23.4 99.0 +22.0 -5.4 150.00 4.4
6397 +18.2 4.8 98 90 00 rich +26.2 99.0 +21.0 -5.1 150.00 4.5
6523 +17.8 4.7 98 90 00 rich +26.7 99.0 +21.0 -5.1 150.00 4.5
6930 +18.2 4.8 98 90 00 rich +27.5 99.0 +21.0 -5.1 150.00 4.5
6901 +17.2 3.6 16 00 00 13.8 +41.1 16.0 ECU. -6.6 LCM. 1.6
Old 02-27-2004, 06:24 PM   #17
jetskizero
Member#: 13833
2002 Impreza WRX
Silver - Sold :(
I noticed on the vf34 the wastegate actuator has a "B" stamped on it. The stock turbo actuator has a "U" stamped on it. Maybe the vf34 has too stiff of an actuator?
Could I swap the two actuators?
Old 02-27-2004, 07:07 PM   #18
lobelsteve
Member#: 31992
2007 STI
UGM
I could hear jetskizero on his way to buy the vacuum hose.
Any chance it's in the wiring? Just kidding. Hope this gets resolved soon.
lobelsteve is offline   Reply With Quote
Old 02-27-2004, 07:36 PM   #19
nmyeti
Member#: 4980
Yes. You have a waste-gate related problem. Either the actuator is not opening wide enough, or your waste gate isn't flowing enough at high RPMs (assuming it gets fully open).
-Nathan
www.turboxs.com
Old 02-27-2004, 07:38 PM   #20
nmyeti
Member#: 4980
I don't think they are interchangeable. The stock one is a Mitsubishi and the VF34 is an IHI turbocharger. I could be wrong on this, as Iíve never tried to swap the two.
-Nathan
www.turboxs.com
Old 02-28-2004, 05:58 AM   #21
lobelsteve
Member#: 31992
2007 STI
UGM
Hey Jeff,
Want to swap on a TD04 and send the VF34 to Deadbolt?
My garage is warm.
Old 02-29-2004, 12:47 PM   #22
jetskizero
Member#: 13833
2002 Impreza WRX
Silver - Sold :(
-Nathan
www.turboxs.com
You are correct sir. I checked them out last night.
So, probably the best option is to get someone (like Deadbolt maybe) to order/send me a new wastegate actuator?
There also doesn't seem to be too much sense in getting it tuned until I get this fixed. drat - foiled again.
Old 03-01-2004, 01:37 PM   #23
jetskizero
Member#: 13833
2002 Impreza WRX
Silver - Sold :(
Maybe it's time to bolt on an 18G - That would fix it.
UTEC Help knock problem ( MAP and Log included) AXA Engine Management & Tuning 7 06-06-2004 12:36 AM
stg4 is overboosting any ideas? kdogpenny1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-01-2004 03:22 PM
TXS stg4 Questions Big Turkey Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-13-2003 08:32 AM
TXS stg4 vs. Vishnu stg2 2nd2none Engine Management & Tuning 5 01-14-2003 12:11 PM
