Old 02-24-2004, 06:14 PM   #1
vile
Member#: 32371
'02 t-rex wagon
platinum
Default whatta think 'bout this jack?
http://www.harborfreight.com/cpi/cta...emnumber=47246
it's light weight, low profile, and has the quick pump action. the only thing is, i've never heard of u.s. general brand or if this thing is going to work 5 yrs. down the road
anyone wanna show off their jacks? hehe
vile is offline   Reply With Quote
Old 02-24-2004, 06:40 PM   #2
UGotBoost?
Member#: 45735
2002 Impreza WRX
It's a jack... you put it under your car and it goes up...
UGotBoost? is offline   Reply With Quote
Old 02-24-2004, 06:42 PM   #3
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
I have heard mixed reviews of Harbor Freight stuff - some people seem to be ok with it, others think it's junk.
Lightweight might not be an issue for you if you keep the thing in the garage all the time, and just drag it around anyway...
I have the Sears Craftsman prof. 3.5 ton one (the black one with the large yellow cradle) - it has the one pump up feature, but is anything but lightweight.
Old 02-24-2004, 07:29 PM   #4
cnk
Member#: 10757
2013 BRZ Limited 6MT
I have it. . haven't had any problems. I needed a jack that was low profile and could fit under my lowered car. I believe there are some reviews of this jack in the Car Parts section as well.
Calvin
cnk is offline   Reply With Quote
Old 02-24-2004, 08:12 PM   #5
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
We have it on our rally team (Evo4) and it's our rear jack... it's pretty good overall but if you need to really jack it up, it doesn't go as high as others... 17" vs 19-21".
At snow drift, they're getting popular with other teams... cheap and effective.
I'll probably buy one for myself for my track events/autox... I love the lightweight of it vs 80-100lbs jack....
Robin
Robin2 is offline   Reply With Quote
Old 02-24-2004, 09:48 PM   #6
vile
Member#: 32371
'02 t-rex wagon
platinum
yeah, me too, that's why i wanted to ask here first. but it's good to see people have good things to say bout it.....i'm probably going to pick it up this weekend.
Old 02-26-2004, 10:21 PM   #7
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
The biggest difference I've seen between nice hydraulic jacks and cheap ones is how easy it is to control lowering.
With a good jack you can gently lower the car to the ground. With a cheap one often the smallest turn makes the car slam down onto the ground.
The description in the Harbor Freight catalog says it requires only half a turn to release hydraulic pressure. I don't know if that's an attempt to put a positive spin on this issue or not. Robin2, maybe you could advise us.
vrg3 is offline   Reply With Quote
Old 02-26-2004, 10:25 PM   #8
cnk
Member#: 10757
I have no problems letting the car down easily. It can be done with this jack without issue.
Calvin
Old 02-27-2004, 12:45 PM   #9
Julian
Member#: 1182
MY00 RS
BRP
I have better lowering control with my HF Al jack than with my 3-ton Sears (made in China) jack. The Sears jack is an on/off switch.
The only real issues with the HF jack are that bolts/nuts back out over time due to vibration. If you get your new jack and then loctite all the fasteners, it'll be just fine.
Oh, and add some grease to the area where the handle goes into the jack body. Makes turning it easier.
I bought one for the same reason as most, it's light, and the saddle is low. It fits under my 510, so I don't have to jack the car up high enough to fit the Sears jack.
Julian is offline   Reply With Quote
Old 02-27-2004, 03:04 PM   #10
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
No probs with it... considering sometimes we drop the rally car real fast if we're short on time during service..... but otherwise it's manageable...
I find it better than my regular 100lbs jack as the grip is excellent on the US General one....
Robin
Old 02-27-2004, 10:30 PM   #11
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Best jack for the money spent. My only complaint is that its got stuck a couple times when lifting to its maximum height when outside the vehicle. Bleeding it fixes this.
Old 02-29-2004, 11:21 AM   #12
Rickyh
Member#: 40453
Dude, go to sam's. they sell a 3.5 ton service jack for around 75 bux. I have used mine for around 3 years and 0 probs. it is heavy as hell, but the sucker lifts anything.
Rickyh is offline   Reply With Quote
Old 03-01-2004, 12:49 PM   #13
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
this jack is fine.
the knockdown handle makes it easy to chuck in the back of the car too.
ken
Old 03-01-2004, 10:08 PM   #14
ciper
Member#: 15543
90BJ Legacy LS ABS
"go to sam's. they sell a 3.5 ton service jack"
Yeah, and it ways 3.5 tons. The point is this jack can be carried with one hand
Old 03-02-2004, 12:15 AM   #15
wewu
Member#: 38767
get a AC Hydraulic jack, awesome jack for lowered cars. Cost me a arm and a leg, but it was the only jack I could use on the lowered e36 m3 I had. Check it out here:
http://www.ultimategarage.com/acjacks.html
wewu is offline   Reply With Quote
Old 03-04-2004, 02:43 PM   #16
HeyChris
Member#: 2234
2013 F-XT
Obsidian Black Pearl
If you get the jack from Harbor Freight... be sure you open the box and check the unit itself before leaving the store.
IF you see hydraulic fluid all over the cylinder, or any other parts. Get another box. Don't take that one. Once the main seal starts to leak. It's impossible to fix... outside of the manufacturer....
Chris.
- Yeah, lets make two trips to Harbor Freight.....
But the jack works fine for me. I leave it at my parents house so I can work on my car, with a lip, at their place. And its light enough my mom likes it too.
HeyChris is offline   Reply With Quote
What to go with a crazy set up!!!!!!! What do you think about this. siliversti06 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 07-21-2006 06:03 PM
What do you think about this? Szm426 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-09-2002 03:55 AM
What do you think about this? Szm426 Interior & Exterior Modification 2 02-26-2002 09:23 PM
what do you think about this auto people bratmantlz Transmission (AT/MT) & Driveline 3 09-10-2001 11:53 PM
What do you think about this set up w/o turbo kit? jwooman Normally Aspirated Powertrain 14 11-06-2000 07:23 AM
