Old 02-24-2004, 07:52 PM   #1
boysetsfire
Member#: 6218
2001 2.5rs-t
silverthorn metallic
Default Pump on windsheild washer bottle
I know little about electricty but how is that wired? On the clip that clips into the pump there are two wires. Is one power and the other ground? What i want to do is wire it into one of the tec's gpo's so that when im wide open throttle it turns the pump on.
-Marc
boysetsfire is offline   Reply With Quote
Old 02-24-2004, 08:10 PM   #2
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
yeah one is power and the other should be the ground...if my memory serves me correctly...just be sure to tap into it into simply the pump wiring, not the wiring from the button on the windshield wiper "arm"...because that will make the wipers go too
Old 02-24-2004, 08:16 PM   #3
boysetsfire
Member#: 6218
2001 2.5rs-t
I was just planning on cutting the clip off of the wire since i have to move the bottle anyways and the wires arent long enough. Then run a wiring to it straight through the tec. Does anyone know if that will work? Ive never used one of the gpo's but i was assuming i just run the wire from one of the gpo's to the positive lead on the pump then just ground the other lead? Does that sound right or am i way off? again i know next to nothing of electrical things.
Old 02-25-2004, 12:58 PM   #4
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
do you know what the tec's GPO outputlooks like?
Do you know how much power you need to drive the pump?
Would the GPO be able to provide enough power to run the pump?
cRayZee is offline   Reply With Quote
Old 02-25-2004, 01:01 PM   #5
boysetsfire
Member#: 6218
2001 2.5rs-t
no, no , and i was hoping. I need to take a look at the tec3's manual i guess before i start thinking of doing anything.
-Marc
Old 02-25-2004, 03:29 PM   #6
SubaFastR
Member#: 5786
I bought a used pump and will be adding it to my resivour. One for the Intercooler sprayer output on the Link, the other to my windshield.
SubaFastR is offline   Reply With Quote
Old 02-25-2004, 05:25 PM   #7
Andursun0013
Member#: 11616
1998 2.35RS-T
2006 Baja 2007 Leg. Wagon
kinda off topic, but does anybody know how much that little pump actually pumps, I want to move mine..I'm not sure where but I was wondering how much pressure/flow that little guy generates.
Kyle
Andursun0013 is offline   Reply With Quote
Old 02-26-2004, 10:33 AM   #8
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
what are you trying to do with this pump? intercooler spray or something???
latinskllz is offline   Reply With Quote
Old 02-26-2004, 01:36 PM   #9
boysetsfire
Member#: 6218
2001 2.5rs-t
yah.
-Marc
Old 02-26-2004, 02:49 PM   #10
Andursun0013
Member#: 11616
1998 2.35RS-T
well, right now it just won't fit in the same position because it gets in the way of my intercooler piping. Eventually I was going to do an intercooler sprayer or water injection
Kyle
Old 02-26-2004, 04:05 PM   #11
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
so you're wanting auto spray based on boost?
Old 02-26-2004, 05:08 PM   #12
boysetsfire
Member#: 6218
2001 2.5rs-t
Im not sure if you are talking to me or andursun but yes i want it to come on at full boost.
-Marc
Old 02-26-2004, 09:47 PM   #13
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
-Marc
do you have an auto switch? perhaps you can just use a relay and have the boost solenoid signal trigger the pump to open
Whats the best paint to use on my washer bottle??? madmax02 Interior & Exterior Modification 10 03-16-2009 04:59 PM
SMC Kit-Windsheild Washer Bottle Cards2323 Water/Methanol Injection, Nitrous & Intercooler Cooling 5 03-16-2008 02:46 PM
4L Exalto washer bottle + 12v pump kit? AcquaCow Water/Methanol Injection, Nitrous & Intercooler Cooling 5 03-22-2007 02:41 PM
95-present legacy,impreza,forestor, double pump washer bottle HomeSlice Private 'Wanted' Classifieds 0 04-21-2004 10:11 PM
impreza legacy forester double pump washer bottle with working pumps HomeSlice Private 'Wanted' Classifieds 0 04-19-2004 10:15 PM
