Old 02-24-2004, 08:28 PM   #1
daveyboy
Member#: 35419
Default 17 psi on cobb stage 2 normal?
quick question:
I am hitting 17 psi of boost with my Cobb stage 2 91 octane map. My other mods are txs uppipe, stealth back, scorpion axle back, and K&N panel filter. I have been running this for a month or 2 and just now added an autometer carbon fiber mechanical boost gauge. I also live a 6000' and thought that I had read people indicating that you will not see as much boost at such a high elevation. I have not noticed any knocking or anything else detrimental. Although I believe my uppipe is leaking when the car is cold... .
daveyboy is online now   Reply With Quote
Old 02-24-2004, 11:53 PM   #2
WRXVII
Member#: 15854
VF34'd...
You are lucky... my car hits only 15psi....
WRXVII is offline   Reply With Quote
Old 02-25-2004, 04:11 AM   #3
Delicious Tuning
Member#: 1990
At higher elevations the ECU has already been calibrated to adjust the amount of air it will allow to flow through the system.
Though everyone needs to take into consideration that there are different variables that can change boost pressures from car to car. Here are some of them that the ECU has already defined and uses to adjust boost.
1. Intake Air Temp
2. Barametric Pressure
Also these adjust multiple parameters within the stock ECU itself, whcih in turn adjust other variables. It is a crazy system, btu works amazingly well.
Also a simple question what gear were you in for 15 PSI or 17 PSI? Where were you in the RPM's? Where you at full throttle?
There are so many questions of what the boost should actually be at, as the system is constantly changing to adjust for so many different variables. The ECU is very smart and harnessing that power takes a lot of time, effort, knowledge and understanding.
Sure pays to be a computer science engineer that tunes cars all day for a living.
Cheers,
Bill Knose
I-Speed USA
Delicious Tuning is offline   Reply With Quote
Old 02-25-2004, 10:46 AM   #4
daveyboy
Member#: 35419
I was hitting 17 psi at full-throttle in the upper rpm range and, if I remember correctly, in 2nd, 3rd, and 4th gears. I shifted pretty early out of 1st so I am not sure how much psi I would hit, and I started to run out of "test road" once in 5th gear.
Old 02-25-2004, 01:09 PM   #5
havoc
Member#: 7603
2002 Impreza WRX
wrb
I've seen as high as 18.3psi (in 4th) this winter in the colder weather. I'm sure it will return to the 16s when things warm up again.
havoc is offline   Reply With Quote
Old 02-25-2004, 02:19 PM   #6
clamdip
Member#: 18709
is your boost gauge accurate? maybe it's reading a bit high? i wouldn't say that it's normal, but since it's a well tuned ECU, then i guess 17psi isn't bad. how are your egt's? that would be a good sign if it's good or bad.
clamdip is offline   Reply With Quote
Old 02-25-2004, 08:36 PM   #7
daveyboy
Member#: 35419
Unfortunately, I do not have an egt gauge. I have held off buying one since I am running a pre-engineered reflash that still utilizes much of the stock ecu's safety settings--I am not sure if it is necessary.
Old 02-25-2004, 09:22 PM   #8
clamdip
Member#: 18709
true, however it's always good to know what's happening inside your engine. an EGT gauge will tell you exactly what's going on good or bad with your engine. let's just say that if your EGT's are high (around 900*C or higher) it would be bad to sustain boost levels around 17psi on the stock turbo. this could be an indication of the stocker being out of it's efficiency range therefore blowing hot air. well, it could all be just theoretical.
Old 02-26-2004, 05:58 AM   #9
Delicious Tuning
Member#: 1990
Agreed, though if the stock EGT is still in place, the highest the EGT's will read before a CEL is thrown is 892 degrees C. So if you still have it in there, you should be fine. IF you don not then it would be recommended to put the stock one back in or install a new one.
Cheers,
Bill Knose
I-Speed USA
www.i-speed.us
Old 02-26-2004, 04:05 PM   #10
digitalmethods
Member#: 33734
2002 used to be cool
02' Snow donkey FTL
In third and fourth I hit pretty high boost levels too. I also live in Mass which has been as cold as a witches ass lately. I think once the air warmes up again my boost will be hitting lower levels.
digitalmethods is offline   Reply With Quote
Old 02-27-2004, 03:41 PM   #11
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Cheers,
Bill Knose
I-Speed USA
Cheers to that... I always thought computer engineers make the best tuners
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 02-27-2004, 11:37 PM   #12
grozgon
Member#: 48109
2004 Subaru WRX
Isn't 17psi or more not safe for the stock turbo? I always thought 17psi was the max for the stock and it would cause problems to run it that high.
grozgon is offline   Reply With Quote
Old 02-28-2004, 12:04 AM   #13
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
The prodrive kit hits 18... an no its not a problem at peek of the powerband. If holding that to redline then yes, 16.5 is maxing out the stocker at redline....
Old 02-29-2004, 12:58 PM   #14
Happy_Days
Member#: 35049
2013 Nissan GTR
Super Silver
Default Re: 17 psi on cobb stage 2 normal?
quick question:
I live at sea level and i hit 17lbs, but only briefly. I'd say average 16.5lbs.
Happy_Days is offline   Reply With Quote
Old 03-01-2004, 03:25 PM   #15
The Professor
Member#: 23183
2002 Cobb StageIIWRX
WR Blue
16.5 was the highest I ever used to get. Just got the car back last Wed from 30k service and they reset the ECU, so while attempting to *ahem* "train" it on the freeway this past Sunday I recorded 17psi at WOT in 3rd or 4th gear. I guess it is re-learning and maybe I will lose this extra .5 of boost...although it's relearning with fresh plugs, tune, fuel filter, air filter and all of that. I seem to remember the car having brief moments of violent and sudden power when I first got the ECU also and that it calmed down slightly after about a tank of gas (200 miles or so).
Still does not seem like it should be possible since the ECU is electronically aiming for that 15.7 target. You would think a computer could get closer to 15.7 than 17.
Oh and innacurate gauges and differeing set ups (2 ways to install) could also account.
The Professor is offline   Reply With Quote
cobb downpipe install whistling noise? 17.5 psi on perrin stage 2 91 broncofangene AccessPort 17 07-27-2009 02:50 PM
Just hitting 14 psi on cobb stage 2 map instead of 16psi wrxgeneration Newbies & FAQs 19 04-13-2008 06:30 PM
17 PSI on cobb stage 2 mars636 Engine Management & Tuning 21 12-01-2005 06:01 PM
Is there a thread on Cobb Stage 2 vs. Prodrive Stage 3 Power Pack? casualsurfer Newbies & FAQs 4 05-03-2004 05:06 PM
12's on cobb stage 2 ? cre Proven Power Bragging 4 10-15-2003 10:15 AM
