Old 02-24-2004, 09:25 PM   #1
BlackSnake
Member#: 42850
WTB 04-07 STI
Roller/Blown Engine
Default Cobb Stage 2, with MBC?
I was wondering if i need to get a boost controler if i want to up it to 15.5psi, or did the cobb stage 2 reflash do that for me already?
BlackSnake is offline   Reply With Quote
Old 02-24-2004, 11:58 PM   #2
WRXVII
Member#: 15854
VF34'd...
you should be getting around 15-16psi depending on the weather and the gear. Some people say they get as high as 16.5psi although mine only gets around 15psi max.
Stage 2 reflash already programmed it for you.
WRXVII is offline   Reply With Quote
Old 02-25-2004, 12:16 AM   #3
BlackSnake
Member#: 42850
WTB 04-07 STI
Roller/Blown Engine
sweet
Old 02-25-2004, 03:52 AM   #4
Delicious Tuning
Member#: 1990
Just a quick note, also for those of you out there, do not add a boost controller (electronic or manual) to a relfash that was not tuned for it. In the end you could cause the car to run lean and then burn itself out. Bad bad bad...
This has happened with some of our friends that did not know better so we want to make things clear out there in Subaru world, of what can hurt the car that has a relfash.
With no reflash it is not as bad, as the car runs incredibly rich anyways, so leaning that out a little is not that big of a deal.
Cheers,
Bill Knose
I-Speed USA
Delicious Tuning is offline   Reply With Quote
cobb stage 2 with mbc? Doug02wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 02-28-2010 04:02 PM
Cobb Stage 2 with non-Cobb Turbo-Back Exhaust? whttiger25 Engine Management & Tuning 3 05-07-2005 10:13 AM
Cobb stage 2 with low boost problem... read this WRXVII Engine Management & Tuning 4 07-15-2004 03:06 AM
Vishnu stage 0 package or Cobb Stage 2 with TXS Stealthback and uppipe. OvRclockR Proven Power Bragging 0 10-02-2003 10:46 PM
Cobb stage 2 with vf30/injects/pump sndstream Engine Management & Tuning 3 08-13-2003 02:17 PM
