Old 02-25-2004, 02:17 AM   #1
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
Default Air Conditioning Removal
I know these threads never get taken seriously, but before you question removing the A/C, consider the fact that I've already decided to do it.
Having said that, how hard is it to remove my air conditioning? Do I need a professional shop to do anything, such as vent the freon? Anyone have instructions on how to do this?
whtlegacy is offline   Reply With Quote
Old 02-25-2004, 02:51 AM   #2
thechickencow
Member#: 16840
14 Outback
dwx vented his freon with the "my turboxs tmic rubs through the AC line and vents it all" method. That worked pretty well.
thechickencow is offline   Reply With Quote
Old 02-25-2004, 06:56 AM   #3
ellisnc
Member#: 4229
2003 S2000
Did someone say track day
Yes, just get a shop to reclaim the refrigerant for you and you're good to go. When you take the compressor out make sure you don't tip it around a lot since there is oil inside you don't want coming out.
Make sure you get all the lines, compressor, condenser, evaporator in the A/C unit under the instrument panel.
ellisnc is offline   Reply With Quote
Old 02-25-2004, 09:39 AM   #4
Chaste Automotive
Vendor
Member#: 44921
have a shop reclaim the rerigerant for you as stated above, disconnect lines and pull out your radiator the yo ucan remove the condensor and the compressor.
Chaste Automotive is offline   Reply With Quote
Old 02-25-2004, 10:54 AM   #5
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
Thanks for the replies. So I can just pretty much unhook anything related to the A/C and I don't have to block any lines off or anything? Does anyone have scoobymods-style directions for this?
Old 02-25-2004, 11:23 AM   #6
MNbiker
Member#: 18148
'08 WRX
Dark Gray
My Subaru Service Manuals have detailed instructions for removing all the various A/C components. Not that this necessarily helps you right now, but it demonstrates the value of having a set of Service Manuals.
The one thing the Service Manual can't help you with is what to do with the belt shroud and cable mount that no longer have a place to fasten to, once the A/C compressor is removed.
-Steve
p.s. I looked for a ScoobyMods-type write-up a while back, and couldn't find one.
MNbiker is offline   Reply With Quote
Old 02-25-2004, 11:44 AM   #7
Uber Wagon
Member#: 39600
2008 STi
Dark Grey Metallic
The only other things I would mention are that you can make the belt cover look pretty nice with a cerfeul dremel tool job, and it will mount up just fine with the one bolt and alignment pin. (See my engine bay pic here:
http://www.clubwrx.net/forums/showth...threadid=47951
Also, I made a block off plate where the hoses run through the fire wall into the evaporator. It was just a piece of aluminum with a rubber gasket behind it, and it bolts right in place. (Sorry no pic)
For the record I weighed everything I took off in at 22 lbs. (without the refrigerent).
-Nick
Uber Wagon is offline   Reply With Quote
Old 02-25-2004, 12:21 PM   #8
ellisnc
Member#: 4229
2003 S2000
-Nick
hehe, I just put a piece of aluminum tape over the hole... works fine.
Old 02-25-2004, 01:51 PM   #9
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
I just spoke with a few local shops who told me that the r134a refrigerant is ozone friendly and I could just vent it myself. I had a hard time believing them, but they assured me it was ok. Can I really just vent it myself?
Old 02-25-2004, 02:27 PM   #10
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
how much does it weigh?
AndyRoo is offline   Reply With Quote
Old 02-25-2004, 02:33 PM   #11
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
I've heard 20-35 lbs
Old 02-25-2004, 03:02 PM   #12
MNbiker
Member#: 18148
'08 WRX
Dark Gray
-Nick
Nick, a couple questions:
*what did you do with the throttle cable that's attached to the belt cover? It's hard to tell from the picture...
*Did you remove the evaporator & lines under the dash, or just block off the lines at the firewall?
Thx!
-Steve
Old 02-25-2004, 07:46 PM   #13
ellisnc
Member#: 4229
2003 S2000
Those are attached to the Evaporator... you can take it out just start digging.
Old 03-05-2004, 12:31 PM   #14
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
Well I've removed everything except the evaporator. I'm not really sure what to unbolt. I removed the glovebox but I don't know which piece is the evaporator. Anyone have a picture?
Old 03-05-2004, 12:52 PM   #15
Uber Wagon
Member#: 39600
2008 STi
Dark Grey Metallic
Thx!
-Steve
The STi is drive by wire, no throttle cables to worry about!
I didn't bother dealing with the evaporator and lines under the dash as the service manual indicated this was pretty involved to get to. I just made a block off plate with a piece of aluminum and gasket material. If I ever have the dash pulled apart for something else I might pull the evaporator then.
-Nick
Old 03-05-2004, 12:53 PM   #16
Uber Wagon
Member#: 39600
2008 STi
Dark Grey Metallic
I measured 22lbs without refirgerant.
Old 03-05-2004, 01:08 PM   #17
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
Here's a shot I just took - can anyone point me to the evaporator?
Old 03-05-2004, 01:22 PM   #18
MNbiker
Member#: 18148
'08 WRX
Dark Gray
It's on the back(firewall) side of the HVAC unit in the center of your picture. I haven't bothered to take the evaporator out yet, as the Service Manual indicates you need to take the HVAC unit completely out to get at it.
-Steve
p.s. I simply used some aluminum tape to seal off the lines at the firewall.
Old 03-05-2004, 01:25 PM   #19
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
hmmm, i may not worry about it at this point. any guesstimate on how much the evap weighs?
Old 03-05-2004, 03:07 PM   #20
kwh29
Member#: 22100
3005 lb. If you take it out your car will float away.
--Kevin H.
kwh29 is offline   Reply With Quote
Old 03-05-2004, 05:03 PM   #21
anders8
Member#: 26658
1 Love Grassroots
NASA Rally Sport FTW!
Naturally, this would be completely illegal. Illegal but not harmful to you or the environment. But illegal.
Buy one of the "AC charging kit" connector cables. Take your car to a large parking lot. Prop your hood open. Take the cap off your AC line. Attach your charging kit *without the can of coolant*. Put the other end in an empty peanut butter jar. Turn the knob. Coolant will start flowing out and immediatly evaporating.
1) The adapter cable will get very cold. That's why you're not just sticking a screw driver in the schrader valve.
2) Atomized oil will be coming out with the coolant in a fine mist. That's why you want to stand back. Don't breathe it. That's also why you don't want to do this in your garage.
3) The jar should catch most of the oil that comes out with the refridgerant. stuff a rag in there to keep as much atomized oil as possible from blowing out and making your whole engine bay greasy.
Anders
anders8 is offline   Reply With Quote
Old 03-05-2004, 05:15 PM   #22
ellisnc
Member#: 4229
2003 S2000
that's the blower and Recirculate/Fresh door box under there. You need to pull that out then to the left of that as you're looking at it you should be able to slide the evaporator out. I should have taken pictures of mine.
I think I posted a how to in the weight reduction thread in the Dress-Up forum
Old 03-05-2004, 05:53 PM   #23
Uber Wagon
Member#: 39600
2008 STi
Dark Grey Metallic
How much does the evaporator itself weigh? Is it worth tearing my car apart to get to?
Old 03-05-2004, 07:20 PM   #24
ellisnc
Member#: 4229
2003 S2000
If you're bored one day...
Old 03-07-2004, 02:03 AM   #25
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
I decided not to take the evaporator out for now and I've been driving my car with the A/C out the past couple of days. I've noticed that occasionally when I first start the car, I hear a fairly loud squeaking noise. I thought it was the v-belt on the crank/alternator but it looks like its the proper tension and its seated correctly. Could this have to do with my no longer having an A/C belt?
Fresh (hot) air versus air conditioning? foreSTir Texas Impreza Club Forum -- TXIC 37 08-06-2004 06:38 PM
Air Conditioning weight removal. Corey Normally Aspirated Powertrain 15 05-07-2004 04:24 AM
Air Conditioning Removal legacyej22 Normally Aspirated Powertrain 5 10-27-2002 02:13 AM
Remove air conditioning? HudsoN456 Normally Aspirated Powertrain 11 03-26-2002 01:14 AM
('93-'01) Air conditioning question... Rally-RS Impreza Forum 0 06-03-2001 12:34 AM
