Old 02-25-2004, 12:37 PM   #1
Ging
Member#: 3258
2000 Impreza TS
Default Driving w/o Rear Oxygen sensor?
What would driving w/o the Rear O2 sensor do? Is the ECU smart enough to compensate. I'm guessing gas millage would suffer.
Thanks.
Ging is offline   Reply With Quote
Old 02-25-2004, 01:13 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
The ECU was never designed to compensate for broken/failing sensors, nevermind missing sensors.
Brian
Old 02-25-2004, 01:56 PM   #3
Ging
Member#: 3258
2000 Impreza TS
I'm assuming then that with the rear sensor being completely broken, that your car would just drive really poopy then?
Old 02-26-2004, 10:20 PM   #4
iceNine
Member#: 12170
2002 WRX Sedan
Platnum Silver Metallic
As far as I know the rear sensor is only there to monitor cat efficiency. If it were broken or missing then you would get a CEL but I don't think that your car would run badly. Now if the front O2 sensor was bad that would cause problems since the ECU uses that to determine fuel mixture and other things. Many people with catless exhausts run without the rear O2 sensor or with CEL fixes without any drivability problems.
Dale
iceNine is offline   Reply With Quote
Old 02-26-2004, 10:24 PM   #5
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
Yeah, in my experience a missing or malfunctioning rear oxygen sensor doesn't affect drivability. Brian's right that the ECU isn't meant to compensate for failing sensors but Dale's right that the rear oxygen sensor doesn't affect how the ECU behaves (other than the potential for trouble codes).
vrg3 is offline   Reply With Quote
2007 STi Rear Oxygen Sensor ( O2 Sensor ) Nitro Don Engine/Power/Exhaust 3 02-19-2009 11:49 AM
driving around without rear oxygen sensor ihavebettersound Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 07-26-2006 02:15 PM
Rear Oxygen Sensor for Link? cpu77 Normally Aspirated with bolt-on Forced Induction Powertrain 15 04-11-2003 09:49 AM
W/B Rear Oxygen Sensor feropont Tri-State Area Forum 7 04-08-2003 01:29 AM
P0139 Rear oxygen sensor circuit slow response slin02 Mid West Subaru Owners Club Forum -- MWSOC 3 05-11-2002 02:32 AM
