Notices
Old 02-25-2004, 05:16 PM   #1
dingo dave
Member#: 33177
2000 Impreza RS coup
white
Default gas/suflur smell in cabin when i punch it.
Over the last month or so I have had a sulfury/gas smell inside the cabin. This only happens when I punch the gas from a stop and max out the RPMs until i hit about 70. If i stop and do it again, it won't be nearly as bad as it was the first time. In fact, it may be non-existent.
When i am driving the car at a normal rate there is no smell at all.
Any ideas.
dingo dave is offline   Reply With Quote
Old 02-25-2004, 05:27 PM   #2
skiteton
Member#: 53064
2011 Legacy 2.5i
2012 Acura TSX
I would think that may be normal...kind of "cleaning out" your engine of any deposits that accumulate while not running. But the fact that it gets into your cabin at speed is strange. Usually the engine bay airs out before it can get into your vents.
Have you tried this with and without the recirc'd air?
I know after Taco Bell, my cabin smells like gas. Weird!
skiteton is offline   Reply With Quote
Old 02-25-2004, 08:26 PM   #3
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
An overheated catalytic converter smells like that. Running WOT up some mountain roads around here for several minutes in our 2.2L Legacy wag results in that smell.
Old 02-25-2004, 08:44 PM   #4
Honkey3k
Member#: 53992
SOLD CGM 2005 2.5RS
35 PSI -- in my tires
stop farting?
Honkey3k is offline   Reply With Quote
Old 02-26-2004, 11:24 AM   #5
dingo dave
Member#: 33177
white
so by an overheated CC you mean a bad CC?
My dealer insists that if the CC is bad the CEL would come on in an instant.
Old 03-05-2004, 11:30 AM   #6
inurb
Member#: 53671
2001 GM6
The four door hater
I get that as well. If I accelerate abruptly the cabin will fill with sulfur smell. I am running on 87 octane and it hasn't done it ina while now so I wonder what the deal was?
Some people say upgrade your octane to 89 or higher, imo that's a waste of money., Someone said it could also be your 02 sensor or Catalyct converter. go get those two checked out if the stanky ass smell bothers you.
But just letting you know I have experienced that as well, so it could jus tbe normal.
Cheers
inurb is offline   Reply With Quote
Old 03-18-2004, 04:43 PM   #7
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
that is a known issue.
it has to do with the sulfur content of the gas and out CC's operating with imperfect o2 content for the cc to do its job 100%. The ecu tries to keep the a/f and consequently the exaust composistion such that the cc can do its job, but it can be off under wot i suppose.
the best fix I have done is to try different gas companies in your area. Sunoco gas in my area has the lowest sufur content that I have found. I get almost no egg smell when i run it.
Hitokiri is offline   Reply With Quote
Old 03-19-2004, 12:03 PM   #8
inurb
Member#: 53671
2001 GM6
The four door hater
Since I've switched to Sunoco I haven't had the sulfur smell happen again. I guess the Mobil brand gas was the culprit.
Fuel smell in cabin when turning on heater AlanTheWoo Service & Maintenance 2 03-07-2008 02:15 PM
Horrible Gas Mileage/Raw gas smell in cabin ScoobySnacker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-18-2007 07:14 PM
04 STI gas fumes smell in cabin... jdeyo6 Service & Maintenance 2 11-17-2007 01:15 PM
nasty gas fume smell in cabin of car Go_Rex_Go Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 12-09-2006 02:23 PM
Gas smell in cabin...not so much in engine bay? Jard Mid Atlantic Impreza Club -- MAIC 39 03-24-2006 11:51 AM
