Old 02-25-2004, 06:07 PM   #1
subaruisme
Member#: 54123
02 WRX
Default gauge size of grounding wires
i recently replaced my ground wire from the battery to the bolt on
top of the starter with 2ga wire from streetwires. im just wondering if that is too big ( i know its overkill) or if you could get any negative effects with using a too large gauge of wire for grounding. Thanks
sim
subaruisme is offline   Reply With Quote
Old 02-25-2004, 06:12 PM   #2
cfvwtuner
Member#: 16474
1972 bug, 1977 Bug
NESIC TrackHoz member #23
I cant imagine that a larger than stock wire can cause any problems.
As long as the terminals are crimped on strong, you shouldnt have any problems.
cfvwtuner is offline   Reply With Quote
Old 02-25-2004, 06:24 PM   #3
subaruisme
Member#: 54123
02 WRX
i figured it would help more than cause any problems, just wanted another opinion on the matter. And i used a good hammer type wire crimper on those hefty ring terminals. turned out great.
Old 02-25-2004, 06:35 PM   #4
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
yea, its a little overkill, but perfectly fine.
Shane
www.paranoidfabrications.com
PARANOID56 is offline   Reply With Quote
Old 02-25-2004, 06:36 PM   #5
subaruisme
Member#: 54123
02 WRX
i appreciate the feedback thanks alot guys
AMS Small Battery kit requires extension of ground wire? blitzmr2 Brakes, Steering & Suspension 18 03-19-2009 09:06 AM
Location of ground wires? bendavi17 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-10-2008 10:48 PM
Utec ground wire gauge profound_wrx UTEC 8 02-22-2006 01:13 PM
K&N, grounding wires, OEM boost gauge, take a look batmanalan Private 'For Sale' Classifieds 0 10-30-2003 07:02 PM
