Old 02-26-2004, 12:31 AM   #1
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
Default 2.5 shortblock mated to 1.8 heads, will they bolt up?
I am almost possitive from reading old posts that all ej- motors are interchange able, shortblocks and longblocks.....but if so....other questons.
possible cr? how would i figure that one, say i used a phase 2 from a 00 or 01 shortblock. i would rebuild the head as well, and possibly some porting of sorts, as the 1.8 heads flow not so well....
well anyways if anyone has done this, please chime in....
-mikey
mcu81 is offline   Reply With Quote
Old 02-26-2004, 01:21 AM   #2
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Thats not smartness
Old 02-26-2004, 01:48 AM   #3
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
qua?
Old 02-26-2004, 05:07 AM   #4
redwagon
Member#: 2181
2008 SpecB
Translation: The 1.8 heads aren't doing a great job of filling the cylinders at 1.8 liters, so how are they going to fill cylinders of 2.5 liters?
Not very well
redwagon is offline   Reply With Quote
Old 02-26-2004, 04:32 PM   #5
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
i know they dont flow the best but that can be changed , i just wanted to know if they would bolt up and estimated cr darnit!
-mikey
Old 02-26-2004, 04:33 PM   #6
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
also the 1.8 heads are from 95, dual port, thanks for info
Old 02-26-2004, 08:17 PM   #7
redwagon
Member#: 2181
2008 SpecB
Look up the spec on the valve sizes and then decide if it's going to be easy to get an EJ18 head to flow like a EJ25. While you're at it look at Kostamojen's thread on fitting EJ20 heads to the EJ25 block and see how the valves are placed on the EJ18 heads.
I'm repeating myself, so I'll **** after this: It's not worth it.
http://forums.nasioc.com/forums/show...highlight=EJ20
http://forums.nasioc.com/forums/show...hreadid=492724
Old 03-05-2004, 09:08 PM   #8
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
Default how bout ej22 heads ?
not worth it unless you have an extra ej25 sitting around and your legacy wagon needs a block...
will my ej25 from my 98 2.5rs fit on my 91 legacy ej22 heads?
I think they are the same heads as the 1.8 correct?
IllNastyImpreza is offline   Reply With Quote
Old 03-05-2004, 11:37 PM   #9
kay95
Member#: 45494
95 impreza L awd
green
yeah for the money your best bet is to swap block and heads from the 2.5 and bolt to the intake manifold as this should be the most inexpensive way to get power without rewiring
kay95 is offline   Reply With Quote
Will a Harbor Freight electric impact get the job done? THansenite Custom Fabrication, Welding & Tools 28 11-13-2010 12:53 AM
AT&T to data users: [Nelson] HA HA! [/Nelson] cucamelsmd15 Off-Topic 142 06-11-2010 01:08 PM
FS : (CNJ) Konig Afternurners 18x7.5 04.STI Tri-State Area Private Classifieds 8 06-04-2010 06:54 PM
stage 2 clutch jospgut Newbies & FAQs 13 06-02-2010 03:54 PM
will a sti 04 tranny, ds and rear diff fit a 2008 wrx? DJIMPREZA Transmission (AT/MT) & Driveline 1 06-02-2010 11:11 AM
