Old 02-26-2004, 05:52 PM   #1
AjIsDope
Member#: 32660
Exclamation Help! Car wont go into gear when started!
For some reason I cannot get my car to go into gear after I start it. It will when the car is off though. I drove very slowly last night after work (bad weather) so it was not abused at all. It feels like my clutch does not engage, or so I think.
Help?
EDIT: Works now. ***?
AjIsDope is offline   Reply With Quote
Old 02-26-2004, 07:08 PM   #2
kaos200
Member#: 2692
clutch was not DISengaging....
so the input shaft and synchros were still being spun, so they wouldnt let you select a gear...
try adjusting the pedal, if that doesnt work or it keeps reoccuring you have another problem somewhere in there (old/dead clutch or the like)
kaos200 is online now   Reply With Quote
Old 02-26-2004, 08:24 PM   #3
AjIsDope
Member#: 32660
The tow truck driver put it into reverse then turned the car on. For some reason that did it. Problem gone. I only have 14k miles on the car.
Old 02-27-2004, 01:18 AM   #4
sonicowrx03
Member#: 41566
Mi problem is the opposite. When I red line my engine while in gear sometimes it gets stuck in that gear and I can not changes gears at all.
The only solution that I found to my problem is to keep moving/rolling in that gear to a parking lot and turn off the engine. Let it cool down for about 5 minutes and move the stick shift around with the engine shut off. You should be able to free up the gear.
This had happened to me about 4 times. The first time I was scared until I saw one thread in this forum. It this does happens to you, calm down and do what I say and you should be ok, don't call the tower truck !!
sonicowrx03 is offline   Reply With Quote
Old 02-27-2004, 01:49 AM   #5
AjIsDope
Member#: 32660
At least the tow truck was from the Subaru Roadside Assistance so it was free. I think I'll check my trans fluid level as I have heard they have been low coming from the factory.
*cough*changetobetterfluid*cough*
Old 02-27-2004, 04:40 AM   #6
kaos200
Member#: 2692
now that you mentioned fluid, check your clutch fluid, if its low, or if there is air in the line, that can cause it as well....
Old 02-27-2004, 07:10 PM   #7
AjIsDope
Member#: 32660
Where do you check that? (I feel like a n00b )
Old 02-28-2004, 05:12 AM   #8
kaos200
Member#: 2692
just next to the brake booster/master cylinder, a small container with a yellow cap... it has markings on it high and low...
Old 02-28-2004, 03:59 PM   #9
AjIsDope
Member#: 32660
I found 2 things:
1. There was some gunk floating in the clutch fluid. The level was fine though.
2. My tranny fluid was on L when the car was cold. How much should I buy? Two quarts?
I guess I can either bleed the clutch myself or take it to the dealer (still under warranty)
Old 02-29-2004, 04:55 PM   #10
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Get the clutch fluid replaced.
Also have them check the adjustments for the clutch. You should not have this problem on a new car.
Old 02-29-2004, 05:45 PM   #11
AjIsDope
Member#: 32660
Yeah this is weird isn't it? The car only had 7 miles on it when I bought it and has 14k now.
Old 03-01-2004, 02:59 PM   #12
AjIsDope
Member#: 32660
Another prob that might contribute is the trans fluid level. When the car is cold, the level was at L. When the car was warm, the car was at F. So...I'm guessing that there is enough in there, but I'm not sure. Can anyone confirm this?
Old 03-07-2004, 05:45 PM   #13
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Your level sounds fine.
Any followup??
Old 03-07-2004, 05:59 PM   #14
AjIsDope
Member#: 32660
My tranny fluid is fine. A member on another site gave me a link to a TSB regarding this exact situation: http://www.scoobymods.com/forums/sho...?threadid=2041
I think I'll let the dealer fix this one.
Old 11-13-2009, 10:04 AM   #15
stroker_
Member#: 229861
Hi anyone had this problem? Mine's an '06 sti, and I had this happening to me a few times these couple of days.
What's causing this problem?? I noticed, whenever after I reversed parked the car, I couldn't engage any gears. I had to engage it while the engine's switched off and start it with the clutch depressed. The car will lounge forward slightly doing so. After this, the gears will be working fine—till the next parking.
I'm using a carbon twin plate clutch currently that had been replaced just a few weeks back. I hadn't done any track session with the new clutch. And it was working fine untill now.
Will it have any side effect or repercussions? Thanks lots for any help!!
stroker_ is offline   Reply With Quote
Old 11-13-2009, 10:30 AM   #16
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Fill out your profile!
competition clutch installed< car wont go into gear Headstart101 Transmission (AT/MT) & Driveline 16 05-14-2009 10:22 PM
car wont go into gear living4surf Transmission (AT/MT) & Driveline 9 10-13-2007 01:42 PM
Car Wont go into gear 04.STI Transmission (AT/MT) & Driveline 3 08-04-2007 10:41 AM
Help, car won't go into gear with cable clutch! yebokmj Transmission (AT/MT) & Driveline 6 10-04-2004 11:23 AM
need help, car wont go into gears DangeRS Transmission (AT/MT) & Driveline 0 02-12-2003 10:08 PM
Message Board Statistics All times are GMT -4. The time now is 02:27 PM.
