Old 02-26-2004, 06:57 PM   #1
subenick
Member#: 48968
1999 impreza 2.5RS
Default domestic ej20 versus JDM ej20
hello,
i was wondering if anyone knew the major differences between a domestic wrx engine and a jdm one.... besides the obvious hp difference. im trying to decide which is more practical for a swap.
thanks
Nick
subenick is offline   Reply With Quote
Old 02-26-2004, 07:51 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
which jdm ej20
i can think of
3 falvors of ej20g
2 flavors of twin trubo
2 flavors of ej20k
several flavors of ej205
ej207
ej20J
i am missing a bunch still
Old 02-27-2004, 12:44 AM   #3
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
The newer wrx ej205 in japan have large ports, different tune... but ya what is the full motor code...?
Old 02-27-2004, 01:29 AM   #4
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
TD05 vs TD04 bigger turbo is jdm theres different heads on jdm vs usdm. I'm reallly tired so i can't give full detail on differences but jdm is better!
scobaru is offline   Reply With Quote
Old 02-27-2004, 05:10 PM   #5
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
Depends on the year, but just about every JDM engine has more powa.
Old 03-02-2004, 07:01 PM   #6
grnlantern1
Member#: 2589
1998 GC8 Do-Luck
Acadia Green Metallic
I have a 98 STI RA Conversion and I have stock everything except my Air Box and I have 221 horsepower at the wheels..My friends Stock 02 WRX only had 185 Horspower...with less RPM's to push...I like my JDM motor and most of the parts I can get from the Subie dealers here....Timing Belt is the same as a 98 2.5RS and I can use any EJ20T Clutch set up...It's all about how you want to do the install process...
Ron
grnlantern1 is offline   Reply With Quote
Old 03-02-2004, 07:05 PM   #7
custus
Member#: 39106
2001 2.5RSTi
Blue Ridge
I have a JDM STi V2 in my RS that is mostly stock (aftermarket JDM ecu) and I am putting down 244whp with a TD05H 16g. It feels real strong.
custus is offline   Reply With Quote
Old 03-02-2004, 08:29 PM   #8
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
custus,
I PM'd you some questions about your swap.
-Rob
rob is offline   Reply With Quote
Old 03-05-2004, 06:02 AM   #9
AlucardR
Member#: 54213
I'm thinking about JDM EJ20T engine into a 98/99 2.5RS... if these engines are put into our American cars....are any mechanics going to be able to work on them if needed?... and will they pass emissions? Would the smog parts off the 2.5 RS engine just bolt up to a JDM engine like that? Also will aftermarket upgrades say..for an 02 USDM WRX work on this engine? Yes i'm a noob
AlucardR is offline   Reply With Quote
Old 03-07-2004, 09:34 PM   #10
serious
Member#: 22879
Like the people above have stated it depends on which jdm engine you get; there are several different version. The usdm one is just that , one engine and all the same unless you compare the sti and the regular wrx.
jdm is not legal to install, but most states never check
usdm one is since it's from a us car
jdm is mostly the same as the usdm wrx and can usually find parts
udsm one is for sure easy to get parts for
For the easiest swap with the least amount of headaches get the usdm. If you know somebody that speaks japanese or lives there you're in luck.
Brent
serious is offline   Reply With Quote
Old 03-22-2004, 03:33 PM   #11
ChristophWRX
Member#: 19009
2005 M3/WRX by clark
silver/white
Will the EJ205 (JDM) version run off the WRX USDM Ecu?
cz
ChristophWRX is offline   Reply With Quote
Old 03-22-2004, 04:00 PM   #12
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
I wouldn't suggest a newbie doing or having an engine swap from a JDM platform... I would stick to the local ej20
HOK is offline   Reply With Quote
Old 03-22-2004, 05:08 PM   #13
totoherbs
Member#: 7321
.... 122 IggPoints
cz
Again I belive so, but the avcs might cause problems. And its only realy worth it if your motor is gone and this is cheep. Other wise you can pick up a sti motor for around $5k.
Old 03-22-2004, 06:48 PM   #14
ChristophWRX
Member#: 19009
silver/white
5k for sti engine...that is a little high, more so around 3500-4000k
this engine can be had for 500-800 if its the right one...
Thanks for the Help..
cz
Old 03-22-2004, 06:56 PM   #15
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
cz
It should but you will have a few CELs.
Guys have ran EJ207 with UDSM ECUs and been fine.
Need4Boost is offline   Reply With Quote
Old 03-22-2004, 07:00 PM   #16
totoherbs
Member#: 7321
.... 122 IggPoints
Kingpin 5k used, rallispec 10k new, lachute 5k... this is for a ver7 or 8 older blocks will be cheeper. You can get then a lot cheeper... but I dont trust ebay or no name shops. Only the names that have been around for a while and are good to thier customers.
is the the jdm ej20 the same as my ej20? Vinnyzwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-07-2010 03:16 PM
JDM EJ20 vs US EJ20? kyouhakuteki Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 08-08-2008 03:50 PM
03 USDM EJ20 -> 97 JDM EJ20 swap marksWRX03 Subaru Conversions 10 06-09-2004 09:13 AM
Differences between US EJ20 and JDM EJ20? Lee Chun Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-03-2004 09:35 PM
Using a usdm ej20 block with jdm ej20 bottom end, whats the block diffrence with sti Turbo Tin Can Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-02-2003 04:13 AM
