Old 02-27-2004, 12:51 AM   #1
WrXsTeel
Member#: 19092
Default Should I bother with the 15k Dealer Service?
I'm about 1500 miles from 15k and the dealership has been hounding me through the mail to bring it in for the service.
Now from what it looks like in the manual... they just "inspect things" then change the oil and all the normal stuff.
Is this worth the $150 they want to charge me? I'm thinking the only thing that would be done is them draining my good moble 1 oil that I just put in it for dino oil....
WrXsTeel is offline   Reply With Quote
Old 02-27-2004, 05:30 AM   #2
jsmonet
Member#: 14190
2005 STi
white
air filter
oil
oil filter
make sure your car isn't falling apart, smoking, doing crack, and doesn't need brakes/pads.
top off your fluids. call it a day.
there, you've officially done your 15k service. the fun starts at 30k
jsmonet is offline   Reply With Quote
Old 02-27-2004, 09:03 AM   #3
Sublime5260
Member#: 30488
2006 Acura TL
Gray
I took mine in for 15k...all he did was an oil and filter change (i have an aftermarket air filter), he didnt even check the brakes...i dunno why
-Abhishek
Sublime5260 is offline   Reply With Quote
Old 02-27-2004, 09:13 AM   #4
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Air filter is optional at 15k; change it only if you are in a dusty area.
15k service should be just oil, filter, tire rotation, check fluids and operation of various items. $150 is way too much. Obviously don't dump the synthetic you just put in. While the wheels are off, check the brake lines, CV joints etc. for anything loose or damaged. Also check the inner sidewall of the tires and look at the treads carefully for embedded objects or unusual wear.
Mike Wevrick is offline   Reply With Quote
should I bother with sti springs??? wherethefmi North West Impreza Club Forum -- NWIC 22 07-19-2007 12:09 AM
Should I bother with the CA stage 2 map? jeebusm3 AccessPort 5 12-16-2006 12:12 AM
Should I bother with new springs? Lantec Brakes, Steering & Suspension 9 07-03-2005 10:38 AM
2000 2.5RS: Should I bother with an aftermarket clutch and flywheel? StankFootZ Transmission (AT/MT) & Driveline 4 06-10-2002 07:21 AM
should I bother with race gas Legacy GTR Normally Aspirated with bolt-on Forced Induction Powertrain 5 01-12-2002 01:36 AM
