Old 09-05-2000, 09:21 PM   #1
kAn9ArOo
Member#: 2294
Lightbulb Anyone know how to wire sidemarkers so they come on with the headlights?
ANYONE KNOW HOW TO WIRE SIDEMARKERS SO THEY COME ON WITH THE HEADLIGHTS/AND PARKING LIGHTS? THANX
-kAn9ArOo
kAn9ArOo is offline
Old 09-05-2000, 09:27 PM   #2
Impeza Rider
Guest
Member#:
Thumbs down
Relax...Not everyone has the electrical knowledge to help you out. You might have to wait a day or so before someone can answer your question. 7 hours usually isn't long enough to have a question answered about a mod that I'm pretty sure hasn't been done here (that I know of anyway).
Edit: I can't spell
Jim
00 RS Sedan Silver
[This message has been edited by Impeza Rider (edited September 05, 2000).]
Old 09-05-2000, 09:46 PM   #3
Imprezer
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
Post
Next time, do not use all caps, please.
Imprezer is offline
Old 09-05-2000, 10:49 PM   #4
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Let's see...
1 - http://www.impreza-rs.com/ubb-files/...ML/004385.html
2 - http://www.impreza-rs.com/ubb-files/...ML/012855.html
and 3 - this post.
Have some patience, man... I think there are only two people that have done this, and I don't think either of them are available (or going to) reply with instructions.
There is the possibility that you just shouldn't be messing with things that you don't understand, as well.
8Complex is offline
Old 09-05-2000, 10:55 PM   #5
Orbiter
Member#: 66
2002 Impreza WRX
Britney Edition
Post
i have this done on my car.. i believe i found the instructions on some VW board before. but im sure if u look around here you will find it!
Orbiter is offline
Old 09-05-2000, 11:05 PM   #6
Subu WEX
Member#: 1169
Post
This is probably one of the simplest light re-wiring projects you could undertake.
There's one question you should ask yourself: Why?
If instructions will stop you from typing with Caps lock on here you go:
Wire the positive connections from your parking lights and your headlights to your sidemarker's positive connection. If you're not sure which one this is take a test light, ground one side and touch the other one (with your sidemarkers on) to each of the wires, if you have light on your test light - success.
To find the parking light's + wire take the cover off from behind and under your steering wheel trace the wire as far as you can from the switch, splice, solder, wrap. (btw check that it has power when you work the switch.) To find the headlight + wire, do the same but follow it from the headlight switch on the side of the column.
Relax, be careful don't lick the wires.
Subu WEX is offline
Old 09-06-2000, 11:29 PM   #7
kAn9ArOo
Member#: 2294
Post
kAn9ArOo is offline
HTML code is On
Does anyone know how to wire up 440 volt 3 phase? bobturismo Off-Topic 6 04-23-2007 06:17 AM
Anyone know how to wire up a tach? epson1 Interior & Exterior Modification 19 08-23-2006 01:57 PM
Anyone know how to remove shift knob from boot on 05 WRX? maxpower_454 Interior & Exterior Modification 4 11-16-2005 02:54 PM
Anyone know how to wire RPM signal into TXS Tuner? wgknestrick Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 04-07-2004 10:59 AM
Anyone know how to wire a WRX / aftermarket Momo horn? makofoto Interior & Exterior Modification 4 02-20-2004 10:27 PM
