Old 11-25-2000, 07:34 PM   #1
MrSube2pt5
Member#: 985
Post What's the power output of the new H6?
Does anyone know exactly? Also, how much heavier is it than the EJ25?
justin
MrSube2pt5 is offline
Old 11-25-2000, 07:41 PM   #2
fellfrosch7
Member#: 2389
'98 Impreza L Wagon
'90 Talon TSi AWD
Post
212 HP @ 6000 RPM
210 lb-ft @ 4400 RPM
I'm not sure of the weight.. it's also listed as 20/27 MPG, in the 4-speed automatic.
fellfrosch7 is offline
Old 11-25-2000, 10:44 PM   #3
MrSube2pt5
Member#: 985
Post
Thanks. It's not at all available in a 5 speed? It would an interesting swap given it's not significantly heavier.
justin
Old 11-25-2000, 10:52 PM   #4
cvalle-sd
Member#: 420
2001 Cr-V
Post
The main issues (beside it probably costing 5-7 grand), are that the whole thing is .8" longer - not much, but it makes thing a little tight up front, it doesn't have a flywheel yet, as it's tuned up to the TC to save weight, and - as the ECU has to communicate with the TCU, you couldn't just pull it out and drop it in an rs - there are no ECUs for H6es that ran in a 5-speed (never happened) - although maybe the SVX/RS hybrid guy could tell you how. I thin it's definitely do-able, but you might want to think about splashing out for a TECII to go with it - and a custom flywheel. Sounds like more trouble and expense than turbo, but with a definite upside in terms of durability.
cvalle-sd is offline
Old 11-25-2000, 11:06 PM   #5
XT6Wagon
Member#: 524
04 STi
Post
Ok, the problems I forsee with the swap are not due to length. Think of the hoodline of the impreza and the fact that the top part of the motor will extend furthur forward where the hood hight is much lower.
Also no automatic I have seen uses a flywheel as there is no need. They use a flex plate which at least on the older subarus was able to switch to a flywheel with no other modifications to the motor.
Personaly I would use a EJ motor in the impreza and leave the H6 to the legacy, outback, and Forester where they have the underhood room to use it effectively.
Also don;t forget that the EJ will ALWAYS have more performace parts avalible for it.
XT6Wagon is offline
HTML code is On
Theoretical power output of a td04 Dubstar112 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 20 02-10-2010 04:23 PM
Power output of stock stereo?Direct speaker replacement options? MaestroB Car Audio, Video & Security 8 10-01-2006 02:18 PM
What has 1/8 the CO2 output of a scooter? 1 Lucky Texan Off-Topic 10 08-10-2006 05:55 PM
What's the output of the USDM STi fuel pump? BIGSKYWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-20-2004 08:25 PM
what is the output of the 02WRX factory MAF sensor? nhluhr Engine Management & Tuning 0 10-04-2003 08:37 PM
