Old 02-27-2004, 05:17 PM   #1
Rickyh
Member#: 40453
Default closed loop/open loop questions
At what point does the ecu switch from closed to open loop?
Rickyh is offline   Reply With Quote
Old 02-27-2004, 05:43 PM   #2
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
What year? What Car? WRX or STi?
2002-2003 WRX - 63% TPS or 5000 rpm (Their are also another set of parameters such as coolant temp, load, but for the most part the above is correct)
2004 WRX - Same, but with delay.
STi - Complex set of parameters. Someone else can fill in the gaps because I don't know the real details
Why do you need to know?
mick_the_ginge is offline   Reply With Quote
Old 02-27-2004, 06:06 PM   #3
Rickyh
Member#: 40453
it is an 02 wrx. i want to know because i have read a few posts about people having trouble tuning when the car is in closed loop. I have an safc and have had no trouble with the ecu learning around the settings that i have, but i just wanted to know for future reference. thanx.
What does closed loop/open loop mean? FuJi K Newbies & FAQs 8 08-12-2014 08:59 PM
how the ecu works...closed loop...open loop? IllNastyImpreza Engine Management & Tuning 13 11-26-2005 05:06 PM
Closed loop / open loop controlled by throttle position sensor? boxxxer Engine Management & Tuning 9 05-16-2005 12:12 PM
Can anyone explain the 04-05 closed loop/open loop lean cond.? boxxxer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-11-2005 09:00 PM
Closed loop - open loop switching Ahzlon Normally Aspirated Powertrain 5 04-22-2004 04:14 PM
