Old 02-27-2004, 05:53 PM   #1
sharky512345
Member#: 54314
2012 Legacy 2.5i
Grey
Default do cars with the steering wheel on the right...
on cars with the steering wheel on the right are the pedals switched too? is the gas on the left and the clutch on the right?
sharky512345 is offline   Reply With Quote
Old 02-27-2004, 05:53 PM   #2
imprezton
Member#: 22958
2011 Land Rover LR2
Gray
No. The gas pedal is closest to the door.
imprezton is offline   Reply With Quote
Old 02-27-2004, 05:54 PM   #3
sharky512345
Member#: 54314
2012 Legacy 2.5i
Grey
ok, because that would be really weird, i have been wondering this for a while
Old 02-27-2004, 05:57 PM   #4
imprezton
Member#: 22958
2011 Land Rover LR2
Gray
The only adjustment inside the car is shifting with your left hand.
If you're in Japan or a country where you drive on the left side, left and right turns are a far bigger adjustment than shifting.
Old 02-27-2004, 05:59 PM   #5
sharky512345
Member#: 54314
2012 Legacy 2.5i
Grey
ok, i dont even know why i asked this. im not going to any other countries or anything, just curious
Old 02-27-2004, 06:00 PM   #6
SubEd
Member#: 717
The rear-view mirror is different though, the images aren't reversed like on left-hand drives.
SubEd is offline   Reply With Quote
Old 02-27-2004, 06:02 PM   #7
imprezton
Member#: 22958
2011 Land Rover LR2
Gray
Old 02-27-2004, 06:07 PM   #8
wix
Member#: 29391
I have always wondered about the shifting in right hand drive cars. Is first gear up and to the right or up and to the left like on our cars?
wix is offline   Reply With Quote
Old 02-27-2004, 06:16 PM   #9
imprezton
Member#: 22958
2011 Land Rover LR2
Gray
IIRC correctly, the gear order is exactly the same. So in a RHD car, First would be away and up.
Old 02-27-2004, 06:21 PM   #10
Sharkbait
Member#: 37221
2012 Abarth
1984 Porsche 911
You are correct sir. Funny, when I moved here, I wondered the same things about left hand drive cars.
Sharkbait is offline   Reply With Quote
Old 02-27-2004, 06:23 PM   #11
Cujo31
Member#: 19843
2000 2.5 RS Sedan
Silverthorn Mettalic
Is it true the Speedometer and Tach sweep the other way also?!?
Cujo31 is offline   Reply With Quote
Old 02-27-2004, 06:24 PM   #12
YoungWilliams
Member#: 11311
Aren't the turn signal and wiper stalks reversed though (so the signal stalk is on the side nearest the door)? I thought I remembered that from Japan.
YoungWilliams is offline   Reply With Quote
Old 02-27-2004, 06:28 PM   #13
SubEd
Member#: 717
I almost died in my first day on Cyprus. You should look both ways before crossing, but sometimes we look left, take a step and then look right.
When I took that step, my friend slammed me in the chest knocking me backwards, as a car came flying by from the right.
Damn you, wrong-side drivers!
Old 02-27-2004, 06:28 PM   #14
imprezton
Member#: 22958
2011 Land Rover LR2
Gray
Good Lord my Mazda had a dash knob for the wipers. I don't remember where the turn signal stem was.
Old 02-27-2004, 06:30 PM   #15
WagonMonster
Member#: 3781
2002 Legacy GT Wagon
2009 Forester X Limited
When I lived in England, I drove, and you just get used to everything being reverse.
I actually had a harder time when I moved back to the states. Every time I went to shift gears, I punched the door!
WagonMonster is offline   Reply With Quote
Old 02-27-2004, 06:31 PM   #16
Sharkbait
Member#: 37221
2012 Abarth
1984 Porsche 911
Yep, my first car was a 1986 RX-7 - same thing with the dash knobs. I don't remember where the signal was either!
Old 02-27-2004, 06:32 PM   #17
Sharkbait
Member#: 37221
2012 Abarth
1984 Porsche 911
It's funny because it's true!!! I did the same thing. I think I might share you comment with the folks - they'll appreciate it!
Old 02-27-2004, 06:44 PM   #18
Unit 91
Member#: 15810
2007 Mazda Fastar
2009 Legacy
The shift pattern is the same, as mentioned. The pedal configuration is the same, as mentioned. The wiper and signal stalks are on the opposite sides.
I kept trying to check the rearview mirror and looking out the window. Adjusting the mirror was a bit odd also. Good times when a guy in a Porsche pulls up next to you and is the one doing the double take.
Unit 91 is offline   Reply With Quote
Old 02-27-2004, 06:54 PM   #19
A_Train
Member#: 34171
2007 G35S 6MT
2008 ML550
Yup. The shifting was easy to adjust to, but I must have put on the wipers 5 or 10 times meaning to put on the turn signals
A_Train is offline   Reply With Quote
Old 02-27-2004, 06:54 PM   #20
Unit 91
Member#: 15810
2007 Mazda Fastar
2009 Legacy
Yup, that's fun. Only the opposite.
Old 02-27-2004, 06:57 PM   #21
TurboXS (Pete)
Member#: 16704
We underprivileged people in the RHD world do suffer. In the case of cars designed in the RHD world the indicator stalk is on the right hand side (closest to the door) but often a car originally designed for LHD will just transplant the steering column so the indicator stalk is on the left hand side. The sales people tell us that the car has the controls in the European style, I call it cheap!
So imagine you are heading to a turn off. You need to use your left hand to change gears and use the indicator stalk, plus even use the handbrake. The right hand gets very bored.
The hardest thing I find is reversing. For some reason it doesn't feel right to look over the opposite shoulder in another country. The other thing that often catches you is that you keep going to the passenger door rather than the driver door.
The speedo and tacho do go in the opposite direction but only for cars in the Southern Hemisphere.
TurboXS (Pete) is offline   Reply With Quote
Old 02-27-2004, 07:08 PM   #22
bemani
Member#: 5673
02 bug eye, 05 LGT
When I was in Japan, I couldn't even ride a bike and stay on the correct side of the street. I'd be very afraid to drive over there :P
bemani is offline   Reply With Quote
Old 02-27-2004, 07:09 PM   #23
imprezton
Member#: 22958
2011 Land Rover LR2
Gray
Old 02-27-2004, 07:10 PM   #24
WagonMonster
Member#: 3781
Old 02-28-2004, 01:16 AM   #25
rkkwan
Member#: 5596
2010 Honda Fit Sport
Mounting points of the windshield wipers are also mirror image, so that you still get a larger wiped area on the driver's side. [Except the one-armed Mercedes.]
It's also a problem with some car stereo. The volume knob, which is the most often used, is now further away from the driver.
One nice thing is that the ignition is usually to the right of the driver. So, if you're outside the car, and just want to turn the key to "ON" to get radio or power, you don't need to reach all the way over the steering wheel.
I think that's about it. You guys have already mentioned most.
rkkwan is offline   Reply With Quote
How much vibration should I expect to feel on the steering wheel on a brand new car? statik213 Newbies & FAQs 21 09-14-2008 01:18 AM
What's with the steering wheel on older German locomotives? sir_wagon Off-Topic 33 06-03-2008 10:50 PM
2004 JDM STi steering wheel on a 93 GC car will the airbags fit? esper Subaru Conversions 1 12-21-2005 07:38 PM
I'm driving around a $40K car with a foot print on the side of it STiTuner South East Region Forum 50 08-11-2004 02:46 PM
What brand are the stock wheels on the Forester Scoobie Newbie Forester Forum 6 02-24-2003 12:55 AM
