Old 02-27-2004, 06:28 PM   #1
Lobbyist
Member#: 26836
Default new install - help me!!!
So I got my bonus this week and I've been looking to upgrade my car audio in my WRX. I bought it used and the owner had some stuff done to it. The sub is blown I believe, it was an Image Dynamics 12" in a small sealed box. The sub amp is an Eclipse 33230. Then he hooked he factory upgraded speakers to a Carver M-240 amp with the factory headunit.
I'm pretty set on the Alpine 9815 since I can get one for about $350. I'm going to keep the Eclipse amp for the sub and replace everything else. For the sub, I used to have a JBL 10" sub in a ported tube, and it was plenty loud for me. I'm pretty sure I want to go with a 10" sub in a ported enclosure since I listen mostly to rock/alternative. Do I have this right?
For the front speakers I want 6.5" components and coaxials for the rear fills. Lay your advice and wisdom on me now before I let my bonus check burn a hole in my pocket.
Lobbyist is offline   Reply With Quote
Old 02-27-2004, 06:47 PM   #2
Legacy
Member#: 10188
2007 Forester XT
Replace the sub, ID makes excellent subs. Then, replace the sub amp, Eclipse amps aren't exactly known for power , I"m willing to bet the reason the sub blew was from a clipped signal by driving the amp past its limits. I run 2 12 IDQ subs myself and they have performed flawlessly, I'm also feeding them the power they need.
THe 9815 is a great deck, I bought mine last summer.
Legacy is offline   Reply With Quote
Old 02-28-2004, 01:47 PM   #3
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Hay,
If you look at some of the other posts, you'll see one who has a single 10" in a WRX specific box that fits in the left corner of the trunk....very nice..... any sub will do really some are better than others ofcourse....for rock/alt. styles of music you prolly be better off with a sealed box, they give a tighter response and are more forgiving when driven hard....they are usualy smaller as well
Components and co-axis are the way to go for mid/high. I wouldn't worry alot about powering the rears with an amp, they could run from the HU and you could use more power on the fronts that way.......
All-in-all sounds good..!!
Good luck, good sounds,
AaRoN
Learning view after header install, help me tune for them please. OUScooby Open Source Reflashes 18 01-10-2011 02:22 PM
Screwed Up Diff Protector Install, Help Me Get Moving Again williaty Transmission (AT/MT) & Driveline 2 02-01-2007 11:36 PM
NTAC installation... help me out sneeky Car Audio, Video & Security 1 10-08-2004 03:55 PM
I need a new hood... Help me Cardwizz Mid Atlantic Impreza Club -- MAIC 6 04-22-2003 10:02 PM
Weird noises after install...Help Me Out Here wrx182 Transmission (AT/MT) & Driveline 8 11-14-2001 01:12 AM
