Old 02-29-2004, 06:22 AM   #1
kami333
Member#: 22068
00 GF4, 00 GM6
93 GF2
Default Is my alternator dying?
Having major power issues recently. Right now my car keeps loosing power and dying on me while I drive. I'll start the car and start driving normally and after a while the lights will slowly get dim and the needles stop moving, then it'll refuse to give me power when I press the accelerator. If I pull over to the side and let it idle for a few minutes it'll go back to normal for another few miles before it starts showing the same problems. What do you think, the alternator? I had it looked at the dealer a few weeks ago and they told me the alternator was fine but the battery was dying so I got a new one but now it's doing the same thing.
Could an unhappy trans cause something like this? I think I might of messed up my 4eat when I was fooling around in some corn fields.
kami333 is offline   Reply With Quote
Old 02-29-2004, 09:16 PM   #2
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Alternators can be tricky sometimes. It may have been charging when the mechanic checked it, then other times it wouldn't charge. If you have a multimeter, test it. It should push 13-15 volts. If not, go to Advance Auto and get this tester. Link at bottom.
Also, does your battery light come near the speedometer? Check all your connections and grounds.
-Charles-
http://www.partsamerica.com/PartDeta...egoryCode=3020]Alternator/Batter Tester
ImprezaVA is offline   Reply With Quote
Is my alternator going out on me? Aspenbullet Electrical & Lighting 6 10-07-2009 12:38 AM
Where did my color red go? Is my monitor dying? Brad Pittiful Off-Topic 29 08-26-2009 08:13 PM
Is my alternator dead or is it something else? Jus Blaze Electrical & Lighting 4 09-22-2008 10:09 AM
Is my Engine Dying??? NYCshopper Normally Aspirated Powertrain 5 08-21-2003 04:14 PM
Why is my car dying on startup? TimCat Newbies & FAQs 16 03-13-2001 12:57 AM
