Old 11-24-2000, 11:07 AM   #1
Rich L
Member#: 961
1999 RS-Tw/ CobraMAF
Custom Rallispec kit/IC#1
Question Has anyone tested 0-60 times with only FWD??
I know the auto trannies have a fuse to make them FWD... has anyone ever experimented with times?
Im just curious to see how much (if any) the AWD slows the car down.
Rich L is offline
Old 11-24-2000, 11:16 AM   #2
CRZ_MSL
Member#: 1610
Post
Unless you plan on buying a new transmission, DON'T DO THIS.
There is a reason the FWD is activated by popping the hood and moving a fuse, and not just an inside switch.
CRZ_MSL is offline
Old 11-24-2000, 11:16 AM   #3
spt_impreza
Member#: 3004
Post
slows down, ummm no......awd would have little to no wheelspin and therefor would accelerate faster!!! fwd would spin and loose traction which = slower acceleration
spt_impreza is offline
Old 11-24-2000, 11:43 AM   #4
Rich L
Member#: 961
Post
spt_impreza,
Your right about traction/wheelspin and AWD. But generally speaking... some performance WILL be loss with AWD due to friction in the drivetrain. With dry conditions (like on a track) and 2 identical cars (1 w/ FWD and 1w/ AWD) the FWD should be faster.
Rich L is offline
Old 11-24-2000, 06:56 PM   #5
socal2.2
Member#: 2428
Question
I thought that the autos run in Front wheel drive most of the time,and switch to AWD when needed?
socal2.2 is offline
Old 11-24-2000, 07:41 PM   #6
Memnoch
Guest
Member#:
Post
Well the car's still AWD. It just transfers 90% of the power being sent to the front wheels. So it behaves like a FWD. So the car doesn't switch between being AWD and FWD, it only switches the amount of power being sent.
But when you use the fuse to make it FWD you're electronically forcing it to only use the front wheels, which it wasn't meant to do.
Does anybody know if the VC would still heat up in this mode? Being that two wheels are getting all the power?
[This message has been edited by Memnoch (edited November 24, 2000).]
Old 11-24-2000, 07:43 PM   #7
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Post
If im not mistaken the autos use a 90/10 split and the manuals a 50/50.
It is definatly not good to use your fwd fuse, it is only there if you have to tow your car.
Its all in the owners manual.
Jay McDade
MY00 BRP RS
auto tech
munkis is offline
Old 11-24-2000, 08:58 PM   #8
glenstiles
Member#: 2827
2002 WRX wagon
Silver, baby, silver
Post
I believe that the SVX auto tranny is 50/50 at rest, and shifts to 90/10 upon reaching cruising speed- and using the FWD only mode may overstress something if pushed hard.
Glen
glenstiles is offline
Old 11-25-2000, 12:45 AM   #9
slim speedy
Member#: 2254
1992 Sentra SE-R
1999 Infiniti G20
Post
The owners manual says bad things will happen if you run the car in FWD so I am not going to try it. Either way(FWD/AWD) the automatic will still be slower than the manual.
slim speedy is offline
Old 11-25-2000, 03:16 PM   #10
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Post
I think that it wouldn't give you much of an advantage because the AWD system is still there, it still has greater drivetrain mass. Just not spinning the rears. So its basically lugging around an AWD system for nothing.
garface is offline
HTML code is On
0-60 times with gtech spiralsmurf Southern California Impreza Club Forum -- SCIC 3 04-19-2002 02:13 PM
gt wagon 0-60 times vs rs sedan 0-60 times iceman Legacy Forum 0 11-11-2000 08:48 PM
Has anyone tested 0-60mph? Tekken General Forum Archive 5 10-04-2000 02:35 PM
0-60 times for people with turbos DrBuzzad Technical Forum Archive 0 06-09-2000 04:57 PM
