Old 03-01-2004, 02:32 PM   #1
semabe
Member#: 46282
2011 STI Limited
Pearlescent Eggplant
Default Very cold weather Clutch issue
This may have been covered here before but I couldn't find the thread. I have a 2004 WRX. When I am in weather below say 25 degrees, and the car sits for a few hours, the clutch goes soft and the car doesn't shift into gear correctly and the clutch feels weird until about 15-30 minutes of warm up time. This is the only manual trans car I have driven with this problem. Is this common to cold weather Subaru's or do I have a correctable issue? The trans shifts funny too in cold weather but that's understandable...I need synthetic.
semabe is offline   Reply With Quote
Old 03-01-2004, 10:48 PM   #2
Scoobie Steve
Member#: 2289
1998 11.87@112mph
Subaru L Ver 6 STi Type R
I have noticed this with my STi swap. When its cold out I have way too much free play, but when its warm all is good. I dont know what causes it. Bleeding the system couldnt hurt.
Scoobie Steve is offline   Reply With Quote
Old 03-03-2004, 06:25 PM   #3
lettucemanatee
Member#: 32493
2002 Impreza WRX
rock chipped blue
i experimented with 'double clutching' on upshifts. basically clutching in, shifting to neutral, releasing clutch, depressing clutch again, shifting up a gear, and releasing clutch. no where in there do i blip the throttle. i find it finds gear a lot smoother from 1-2 and from 2-3.
lettucemanatee is offline   Reply With Quote
Old 03-03-2004, 09:09 PM   #4
semabe
Member#: 46282
2011 STI Limited
I think it's more along the line of the clutch pressure not being high enough in the cold. I wonder if different fluid would help?
Old 03-04-2004, 03:24 PM   #5
Focus4
Member#: 20107
2004 STi
when its cold out <40, i can't downshift into 2nd gear w/o double clutching for at least 20 mins of driving. The shifter feeling funny is normal, it actully feels better for me because the shifter won't grind. When it gets real cold ( - 10) the shifter is like an ice block and barely moves, then turn the car on and it sounds like its going to explod... scary...
Focus4 is offline   Reply With Quote
Forged Pistons and very cold weather BigRigger Built Motor Discussion 14 03-29-2011 11:06 AM
Hot weather vs Warm Weather vs Cold Weather - RPM issue. SausageCat Factory 2.0L Turbo Powertrain 7 09-01-2009 08:51 PM
Car falls on its face in very cold weather? CKxx UTEC 11 02-04-2009 01:26 PM
Running Cobb maps with very cold weather ST3 AccessPort 11 10-19-2006 08:41 AM
"Cylinder #2 misfire" in very cold weather - anyone else see this problem? Patrick Olsen Normally Aspirated Powertrain 20 02-14-2002 07:31 PM
Message Board Statistics All times are GMT -4. The time now is 02:48 AM.
