Southern California Impreza Club
Go Back   NASIOC > NASIOC Chapters > Southern California Impreza Club Forum -- SCIC
Old 03-01-2004, 02:42 PM   #1
Dynamispeed
Vendor
Member#: 51291
Exclamation *ATTN* Safety issue when using CUSCO rear swaybar on a STI. Please read!!
To anyone using a CUSCO adjustable rear sway bar or their STI (wrx is perfectly fine):
Please be aware that the swaybar can interfere with the lower lateral link and BEND your endlinks. If this happens during a high speed corner it could have disasterous results, as your swaybar will bind your suspension. Luckily we found this out over a speed bump rather than a freeway on ramp or mountain road.
The problem is that the STI endlinks allow hoizontal and vertical play of the swaybar. The cusco bar has no lateral stops so the swaybar can hit the tire. That is the least of the problems. The lever arms are too short and allow the ends of the bar to "toggle"(loud clunk) to the BOTTOM of the lateral link. This effectively lets the swaybar COMPRESS your suspension on one side.
In order to run this setup safely you need endlinks w\ a SOLID bushing on one side (bottom that bolts to the lateral link), and the links also should be adjustable(WRX links will not work). As far as I know there isn't one available. Perrin has one that will be available in a few weeks. The Poltec STI links may work, but still allow too much lateral movement.
I will be working to get a solution to this problem in the next couple days.
Happy motoring,
Ashley
Dynamispeed
Dynamispeed is offline   Reply With Quote
Old 03-01-2004, 03:04 PM   #2
Coati
Member#: 9106
2015 FXT - DGM
2008 STI - Aspen White
So that would be why everyone in the suspension forum with an STi was breaking their endlinks with adjustable rear bars over the last several months...
Coati is offline   Reply With Quote
Old 03-01-2004, 03:08 PM   #3
Dynamispeed
Vendor
Member#: 51291
yes.. I saw that too. I know people have bought them locally and I dont want to see anyone fly off the road because of a poorly developed and tested part.
Old 03-01-2004, 03:24 PM   #5
Dynamispeed
Vendor
Member#: 51291
No im going to.
Old 03-01-2004, 10:14 PM   #6
Kwyjibo
Member#: 17851
2003 WRX
R.I.P. 7.27.2005
FYI, it happens on the 02/03 WRX as well.
I have a set of endlinks from Hairpin Racing. They are pillowball like the Perrins. What happened to me is that the sway bar "walked" over and pulled the bushing out of the endlink.
Hairpin re-installed the bushing for me, and machined me a collar kit that goes around the bar near the mounts that keeps it from moving over. A small hose clamp could possibly do the same thing
Ashley, you may want to post what i did above when you post about the sti thing too
Kwyjibo is offline   Reply With Quote
Old 03-01-2004, 10:39 PM   #7
vile
Member#: 32371
'02 t-rex wagon
platinum
i have not noticed this on my '02 wrx
vile is offline   Reply With Quote
Old 03-01-2004, 10:45 PM   #8
mlambert
Member#: 13831
Some swaybars seem to walk more than others. Ive been meaning to fix something around mine but every time I check it, its nice and even exactly where its supposed to be.
mlambert is offline   Reply With Quote
Old 03-01-2004, 10:46 PM   #9
mlambert
Member#: 13831
ps i love you ashley
Old 03-01-2004, 11:22 PM   #10
Tragic
Member#: 30843
2003 Impreza WRX
Sedona Red
i havent noticed this on my 03 either
-shane
Tragic is offline   Reply With Quote
Old 03-01-2004, 11:35 PM   #11
Dynamispeed
Vendor
Member#: 51291
This problem is in the STI only, as its lateral links and endlinks are different that a regular WRX.
You may get swaybar walk w\ endlinks that have spherical bearings. They allow too much movement of the bar if you bar does not have a flange on it to keep it from moving. This can happen in any WRX 02-present. It depends on what endlink\bar\bushing combo you use.
At least a moving swaybar does not have the potential to kill you.
Ashley
PS: I love you too Mike
Old 03-02-2004, 08:09 AM   #12
Chaste Automotive
Vendor
Member#: 44921
Ashley,
The stock sway bar does this as well, it is a fault with the end link design. We have had two STi some in with this problem, they also like to pop the bushings out of the mounts as well.
Chaste Automotive is offline   Reply With Quote
Old 03-02-2004, 10:33 AM   #13
Dynamispeed
Vendor
Member#: 51291
I can see the stock swaybar doing this too.
It is held pretty well (better than the cusco) by the stock bushings from lateral movement. I know a couple people that have had broken endlinks on the STOCK rear sway too.
Ashley
Old 03-02-2004, 02:39 PM   #14
VOLTRONN
Member#: 45071
you nev4r had me
you never had your car!
yeah i broke my driver side endlink a month ago. Im thinking of getting the progress sway bar or the perrin. Im going to pass on the cusco one for now.
VOLTRONN is offline   Reply With Quote
Old 03-02-2004, 03:13 PM   #15
Dynamispeed
Vendor
Member#: 51291
I'll be trying a progress bar on a STI soon. I should be a dealer for them shortly.
Ashley
Old 03-02-2004, 03:39 PM   #16
sherifx
Member#: 10780
---- BRZ
Galaxy Blue Silica
Ashley - any updates on this issue/solution. Us with the cusco rear swaybars are eagerly awaiting your update.
sherif
sherifx is offline   Reply With Quote
Old 03-02-2004, 05:08 PM   #17
Dynamispeed
Vendor
Member#: 51291
Adam from Z1 performance has e-mailed Cusco. Realistically, I don't know what they are going to do about it, or what they can do about it. I could be wrong, but I don't think they have a base of operations here. I'm going to be working w\ Ferdie from South Coast Subaru to at least develop a fix for this.
I think the problem can be solved w\ a set of endlinks that actually hold the ends of the swaybar.
Mabye Subaru can step up to the plate and revisit their endlink design for the STI. This problem has a potential to affect even a stock setup. Mabye they already have for the next model year... I guess we will wait and see.
I'll let you guys know any findings as they happen.
Regards,
Ashley
Dynamispeed
Old 03-02-2004, 07:03 PM   #18
sherifx
Member#: 10780
---- BRZ
Galaxy Blue Silica
I have an idea for a potential design, but I'm not sure if it would work. In my idea, there is still a weak point being the spherical bushing... hm
please keep us posted & thanks again
sherif
Old 03-02-2004, 07:18 PM   #19
Dynamispeed
Vendor
Member#: 51291
thats mine too. A spherical on top and a solid bushing on the bottom.
Old 03-03-2004, 01:31 PM   #20
Dynamispeed
Vendor
Member#: 51291
bump
Old 03-07-2004, 10:26 AM   #21
Julio
Member#: 6363
10 Sec. Club
Element - Crawford
So, any suggestion(s) besides the Cusco, or due to the endlinks design this is a "natural" issue no matter what rsb?
Julio is offline   Reply With Quote
Old 03-07-2004, 12:34 PM   #22
Member#: 67
1999 Outlasting
the competition.
We took a look at a car earlier this week and we feel that its not something we want to make a patch for. This is a serious problem that Cusco should take care of. Not with some aftermarket link. IMHO.
Tom
Old 03-07-2004, 09:52 PM   #23
h2o
Member#: 7946
94/9 MX-5/Fit
ZoomZoom/VTEC Kick'in Y0!
I snapped one of my stock endlink in half couple days ago. The car drives fine, except for a lot more bodyroll and I am waiting for the Poltec rear endlinks. I think all adjustable rear swaybars will bend stock endlinks, that's a design flaw IMHO.
h2o is offline   Reply With Quote
Old 03-07-2004, 11:41 PM   #24
Dynamispeed
Vendor
Member#: 51291
I installed some Poltec's this weekend. They seem to be working ok. I adjusted them longer for some added safety.
Regards,
Ashley
Old 03-08-2004, 12:03 AM   #25
mattjk
Member#: 16615
I ♥ my TE51
2009 Nissan 370z
I simple fix would be to affix a washer or weld a bead onto the swaybar so it doesn't walk. One on each side of the sway bar should do the trick.
See the bottom bar:
mattjk is offline   Reply With Quote
F/S SOCAL Cusco rear swaybar 05-07 sti team trucha racing Suspension/Brakes/Handling 8 06-08-2009 12:35 PM
wtb rear skirts for 05 sti please read!!!!! MRSTI28 Private 'Wanted' Classifieds 14 07-15-2008 02:37 PM
If you own COBB springs on 06 STI, please read TheSilverFox Brakes, Steering & Suspension 8 06-13-2007 05:50 PM
ATTN: Safety issue when using Cusco rear swaybar on a STI Dynamispeed Brakes, Steering & Suspension 181 05-11-2007 06:10 AM
Modified Stock Rear Swaybar on 04 STI Guam STI Brakes, Steering & Suspension 0 06-30-2005 01:42 AM
