Old 03-01-2004, 09:11 PM   #1
Bottom Feeder
Member#: 2808
Default Clutch judder: when does the warranty run out?
My 2.5RS has been showing symptoms of the dreaded Subaru clutch judder. I've really noticed how bad it's getting in the last few months. Problem is, it was three years old in October, and I'm beyond the 36k mark. I've been under the assumption that I'm SOL, and any clutch work will be coming out of my own pocket.
So I Carfaxed my car yesterday just for giggles, and it's telling me I have a drivetrain warrany on my car for 60 months or 60k miles. Well, that was news to me! Can I still go to my local Subaru dealer and have them check it out, and possibly replace it for no cost?
How many miles have some of you had on your cars and still had Subaru do warranty clutch work?
Bottom Feeder is offline   Reply With Quote
Old 03-02-2004, 03:50 PM   #2
Bottom Feeder
Member#: 2808
Old 03-02-2004, 05:56 PM   #3
boulder wrx
Member#: 19632
As i understand it, the 60,000 mile powertrain warranty only covers internally lubricated components (gearbox, engine, turbo, etc.).
The clutch is usually considered a "wear item" - like tires and brake pads.
You might luck out; I just had mine replaced under warranty, though I'm at 32,000 miles.
boulder wrx is offline   Reply With Quote
Old 03-02-2004, 06:19 PM   #4
Doughboy
Member#: 27398
2002 Impreza
i agree with the post above...i think the issue is covered under the 36k warranty.
if it's any consolation, my clutch shudder went away at about 30k miles.
Doughboy is offline   Reply With Quote
Old 03-02-2004, 09:17 PM   #5
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
3 years, 36k miles is correct.
Brian
Old 03-02-2004, 10:01 PM   #6
Bottom Feeder
Member#: 2808
Crap. Oh, well.
Thanks, gents.
Old 03-03-2004, 05:05 AM   #7
suburman
Member#: 22898
1995 Obs w/tbo 2.2
Blu/Wht
call 800-subaru3 and make a stink. but, if you are way over 36k, i doubt they'll help
suburman is offline   Reply With Quote
Old 03-03-2004, 02:35 PM   #8
Bottom Feeder
Member#: 2808
Nope. I'm not even at 38k yet. It's only been bad since 36k. Doesn't that figure, eh?
Old 03-03-2004, 10:35 PM   #9
Jon [in CT]
Member#: 2992
02 WRX Sedan
You can read NHTSA's crappy copy of the Clutch Judder TSB at http://www-odi.nhtsa.dot.gov/prepos/...01031-4238.pdf.
It seems to me that if it is determined that your flywheel must be replaced to fix the problem (per the TSB), then the flywheel replacement should be covered under the Powertrain Warranty. The addtional cost of replacing the clutch disc at the same time should be minimal.
I agree that, given your mileage, you should call 1-800-SUBARU3.
Jon [in CT] is offline   Reply With Quote
What should I have the dealer look at / replaced / etc before warranty runs out... jason2004STI Newbies & FAQs 3 07-10-2006 08:13 PM
When The Oil Runs Out... Switching to alternative fuel vehicles en masse? rogue Off-Topic 19 08-24-2003 12:15 AM
when does the new 2003 come out? Norman General Community 3 11-03-2002 03:36 PM
when does the new wrx come out? wrxkid88 Canada Region Forum 18 07-09-2002 03:28 AM
When does the 03 Wrx come out? zeromax News & Rumors 2 01-28-2002 08:09 PM
