Old 03-01-2004, 11:42 PM   #1
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Default Another IAC question
My car (2002 WRX) bogs out under partial throttle, usually between 4 -5k. Originally I had a separate issue with the idle and cleaned the idle air control solenoid. It wasn't until after I did this that I threw a CEL involving the solenoid. But I have never thrown one since- that was probably over a month ago. But since then I have been having horrible problems with misfires in all cylinders, and as I mentioned, the car shudders when I accelerate, and I can't even seem to make it to higher boost. It just loses power once the shuddering starts. My AFRs don't seem out of wack under throttle, but when the car warms up they (AFRs) are up and down (at idle). The AFRs at idle go back and forth between 13 -15:1, like it's trying to stabilize, but can't quite do it. The RPMS fluctuate from 600 - 800. If I blip the gas pedal it straightens right out to 14.7:1. It doesn't fluctuate when I cold start it though.
I checked the plugs and inspected the coilpacks, everything seems to check out OK. No fouling or anything.
I read other posts and am a little confused. What would be more likely....IAC or front 02?
TyranosaurusWRX is offline   Reply With Quote
Old 03-02-2004, 07:18 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The IAC is out of the picture above idle, it certainly has no effect at 4-5K.
IAC Question rubyred88 Normally Aspirated Powertrain 0 02-21-2008 01:39 PM
Another, yes... another turbo question... o_O"... Liam Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 05-20-2007 12:06 AM
1.8/2.2 swappers: IAC questions rabbitnutz Subaru Conversions 7 12-23-2005 03:04 AM
Another Legacy Question. Tuning related. Lafora Legacy Forum 1 03-09-2001 11:34 AM
Another suspension question for the class gtguy Legacy Forum 3 11-06-2000 12:26 AM
