Welcome to the North American Subaru Impreza Owners Club Sunday November 22, 2009
Old 03-02-2004, 04:32 AM   #1
bwco
Member#: 44137
00 No Subie
Default @ Need a doctor here (pic inside)
I need some quick specialists' opinion here.
my question : Is my car safe ? Lean/Rich question
I have:
1)Zerosport exhaust manifold and up-pipe (lean side)
2)PWR top mount intercooler (don't know if it does anything to lean/rich ratio)
3) AEM CAI (lean)
4) Sard fuel regulator
5) Stock BOV (good stuff eh)
6) Samco intercooler hoses
7) JDM STi intake manifold ( same as stock except red)
Well, these are basically the things that I can think of that relate to lean/rich ratio.
Am I running extremely dangerous with the AEM CAI? How to correct this ? play with the sard fuel regulator?
I know I can simply remove the CAI. But just thought i can give it some hope for not removing it
here an old pic....
bwco is offline   Reply With Quote
Old 03-02-2004, 04:35 AM   #2
Uncle Scotty
Member#: 16200
tic- toc
the countdown has started
Guessing your mixture is like gussing the Lotto numbers.....good luck.
The ONLY way to know is with a wideband O2 sensor.
Poke and hope 'aint gonna cut it...
Old 03-02-2004, 04:35 AM   #3
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
The cold air wont make you lean as much as it will do funny things to the maf...
What gauges do you have? Why not get your self a reflash; like the cobb stage one?
Old 03-02-2004, 06:24 AM   #4
bwco
Member#: 44137
00 No Subie
Hi uncle, I know, but I am looking for some insights from people like you guys to tell me if i needa do something before I blow my engine.
So, wideband O2 sensor it is ! Thanks ! I'll search around for that.
Old 03-02-2004, 06:25 AM   #5
bwco
Member#: 44137
00 No Subie
what gauages? I don't have A/F !!
I've got boost, volt, oil temp from OEM subaru.
SHould i get something else? please suggest
So, once I got a reflash, the ECU will take care of everything? and I don't have to guess everything in my head?
Thanks
Old 03-02-2004, 06:42 AM   #6
totoherbs
Member#: 7321
.... 122 IggPoints
No... a reflash will just open up some power.... im not sure what you mean by guess in you head.
Get rid of the vold and get an a/f....
Old 03-02-2004, 09:08 AM   #7
Vortechcoupe
Member#: 33262
E36 M3
93 notch, X3
a cheap autometer or other a/f gauge won't be worth it. You have to get a wideband for tuning/checking.
Justin C
Vortechcoupe is offline   Reply With Quote
Old 03-02-2004, 09:08 AM   #8
Bolster
Member#: 22290
2002 WRB WRX Wagon
& 1995 L Coupe FTW!
Chuch the AEM intake. You'll never get consistent airflow meter readings which makes it just about impossible to tune with. On a stock car (no mods except maybe just the CAI) you probably run rich enough for the leaning out not to be so dangerous. I've seen 2 cars that have been killed by this intake.
Bolster is offline   Reply With Quote
Old 03-02-2004, 09:34 AM   #9
2MANYCARS
Member#: 24046
2007 STi, EVO, M6
E55, ML63, & Old 02 WRX.
Is your fuel pressure regulator adjustable? If so, pump up the fuel psi a bit if you don't have access to a wideband o2 sensor "stick". Good luck.
2MANYCARS is offline   Reply With Quote
Old 03-02-2004, 11:21 AM   #10
Blitz04
Member#: 28099
05 CLK320
is sti intake manifold exactly same as wrx's?
Blitz04 is offline   Reply With Quote
Old 03-02-2004, 02:30 PM   #11
Happy_Days
Member#: 35049
2009 Ford Mustang GT
Brenspeed Tune,4.10 Gears
Everything seems fine IMHO except for the CAI. I would also recommend engine management like someone else did.
Happy_Days is offline   Reply With Quote
Old 03-03-2004, 01:37 AM   #12
bwco
Member#: 44137
00 No Subie
Yup, thanks !
I'm waiting for a proper reflash distributor that knows their ***** here, otherwise, I won't trust anyone locally. U know, we're from the same place.
I'll definately throw the AEM out !
>> I have the sard fuel regulator, which is adjustable, it's running consistently at 43 psi all the time
>> I'll see where I can dig up a wide band O2 sensor tool
I'm not looking for more power, I"m looking for "save engine"
So, I will be safe boosting the car back to 1 bar after reinstalling the stock airbox? I'm running 0.6bar all year long. Sometimes 0.8bar.
Old 03-03-2004, 01:38 AM   #13
bwco
Member#: 44137
00 No Subie
it's the same for 02-03 , except the red color ....
Old 03-03-2004, 01:39 AM   #14
Uncle Scotty
Member#: 16200
tic- toc
You want fuel pressure to rise as boost pressure increases....the FPR is dangerous for you to use to keep pressure from rising as boost increases.
Please take some time to learn about your car before you blow it up.
Old 03-03-2004, 03:55 AM   #15
bwco
Member#: 44137
00 No Subie
sorry, gotta rephrase, whenever I pop open the hood, the fuel pressure indicator shows 43 psi all the time at idle, since the fuel pressure indicator was installed under the hood (by a local shop), so i said it's 43psi all the time, I've check and see if my FPR is a raising rate regulator or not. I hope it is !
Old 03-03-2004, 04:07 AM   #16
Uncle Scotty
Member#: 16200
tic- toc
Yeah...sorry if I sound like an ass....'cuz I am sometimes....
Anyway...this is one reason I personally think a fuel pressure gauge mounted where it can not be seen under boost is a waste.
Knowing idle FP is good, but knowing FP isn't dropping off under boost is much better.
Old 03-03-2004, 09:35 AM   #17
2MANYCARS
Member#: 24046
2007 STi, EVO, M6
Your fuel pressure under idle seems fine, just a note, under boost, depends on your mods, you should be in the 50+psi range. I got a fuel pressure gauge in the cabin, mine goes over 60psi, but then, I got more mods.
Old 03-03-2004, 02:41 PM   #18
bwco
Member#: 44137
00 No Subie
Thanks, so at least i know my engine won't lean out at idle !
Old 03-04-2004, 12:36 PM   #19
shields102
Member#: 9598
02 wrx
white
You say you wat to "save engine". Its as easy as removeing the cai. You will spend more $$$ on having a tuner check the mix with a wideband then you spent on the aem.
shields102 is offline   Reply With Quote
Old 03-04-2004, 10:16 PM   #20
batmanalan
Member#: 37583
wb o2
batmanalan is offline   Reply With Quote
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 12:48 PM.
