Old 03-04-2006, 03:40 PM   #26
awdlover
Member#: 91522
2005 Impreza 2.5 RS
Platinum Silver Metallic
Default Advance Auto has it: Part # FK335
Advance Auto parts carries an aftermarket ATF filter for the Subie. They call it an "ATC Transmission Filter Kit" and the part number is FK335. It costs $10.48. They also carry a few other brands that you can apparently order through their web site.
awdlover is offline   Reply With Quote
Old 03-05-2006, 12:03 AM   #27
ETomas
Member#: 109153
Default Drive Train question
Hello all! Some advise please.
2004 Impreza WRX turbo.
I have changed manual tranny fluid and rear diff fluid.
Is there any other fluid-type maintenance I'm missing?
I'm doing this myself to save on the outrageous cost of
having a shop/dealer do the work.
There's over 100, 000 K's on her how.
Anybody help?
Thanks
Erik Tomas Toronto
ETomas is offline   Reply With Quote
Old 03-05-2006, 02:04 AM   #28
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Flush brake fluid and replace with new fluid.
Drain coolant and replace with fresh coolant + Subaru Coolant Conditioner.
Not sure of mileage for power steering fluid.
Assume you've done oil/oil filter, air filter, PCV valve, fuel filter.
Old 03-05-2006, 11:39 AM   #29
ETomas
Member#: 109153
Default Thanks Armand
Appreciate the advise.
Yes, I have done all those things you've listed, and regularly, so I'm in good shape there.
So other than changing the tranny and rear diff fluids which I've done, is there anything else I need to replace in the AWD system now that we're passed 100 thousand K's?
Erik T Toronto
Old 03-05-2006, 03:48 PM   #30
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Maybe tires?
check out my.subaru.com
Old 03-06-2006, 10:34 PM   #31
ETomas
Member#: 109153
Tires have been replaced regularly.
I'm seeing other posts with warnings to replace the timing belt after
100 thousand K's. True?
Erik T Toronto
Old 03-07-2006, 11:24 AM   #32
carguy4
Member#: 58073
2002 impreza 2.5 ts
deep saphire blue
the change interval for timing belt is 168,000 km
my dealer told me to change it at 100,000 km anyway because subaru hadn<t changed anything since they used to recommend 96,000km but I am going to wait until 168,000 km
the same dealer also charges 197,00$CAN for just the belt when I can get one from www.1stsubaruparts.com for under 60,00$ US
most guys on this forum are waiting until over 100,000 miles so you should be fine until 168,000 km
carguy4 is offline   Reply With Quote
Old 03-07-2006, 11:34 PM   #33
97obw
Member#: 109426
97 OUTBACK
mud brown
its a complete sealed unit, ive heard it shouldent ever even need flushing
97obw is offline   Reply With Quote
transmission filter??? TDIpowered Legacy Forum 5 02-02-2007 01:38 AM
External automatic transmission filter on a 99 Legacy 2.2L puchma Transmission (AT/MT) & Driveline 2 11-10-2005 12:40 PM
Transmission Filter ForesterXT04 Forester Forum 28 07-09-2004 09:08 PM
Transmission Filters? Gravel Girl Southern California Impreza Club Forum -- SCIC 5 12-26-2003 04:10 AM
External transmission filter zensvx SVX Forum Archive 1 09-17-2000 08:06 PM
