Old 03-01-2004, 02:26 PM   #1
Chewy-WRX
Member#: 19426
2002 WRX Black
I luv the Ice Gnomes....
Default Bass Blockers
I'm thinking about getting 6.5 component speakers for the front.
Rockford Fosgate - FNX 2614 6.5" 70w RMS Component
Should I use bass blockers? If so, what frequency?
Chewy-WRX is offline   Reply With Quote
Old 03-01-2004, 03:04 PM   #2
teiva-boy
Member#: 22825
Its not needed.
teiva-boy is offline   Reply With Quote
Old 03-01-2004, 05:19 PM   #3
mudshovel
Member#: 9019
2000 rs
brp
no components usually come with a crossover
mudshovel is offline   Reply With Quote
Old 03-01-2004, 06:12 PM   #4
teiva-boy
Member#: 22825
But not a "bassblocker" that blocks low frequencies from the woofer.
Old 03-01-2004, 06:16 PM   #5
Scobby29
Member#: 55268
2002 Wrx
Royal Blue
What kind of stereo do you have????
Scobby29 is offline   Reply With Quote
Old 03-01-2004, 08:12 PM   #6
redwagon
Member#: 2181
2008 SpecB
If you're just putting hu power to the comps they usually don't need them. If you are amplified you may find you can put more power to the comps if you cut the lower frequencies. Low frequencies require long excursion from the driver, so you may find the voice coil bottoming out. If you were using a subwoofer you'd normally have your comp set high-passed at 70 or 80hz.
redwagon is offline   Reply With Quote
Old 03-01-2004, 08:24 PM   #7
jhawkins
Member#: 55962
2004 WRX
San Remo Red
I'm just a dumb*** but I totally trust my shop - a wall full of trophies is good enough for me. When I first installed my Phoinix Gold / MB Quart system, I was getting some very annoying buzz from the driver's door just on certain, bass heavy songs. When I traded that car (02 Wagon) in Jan for my 04 sedan, I had the shop to switch out the old system. They installed the bass blockers at that time for no charge and it made all the difference! He said that if that didn't do the trick to come back & he'd try a different freq but no complaints. If you wish, I can check with him & let you know exactly what he did. You may be best off to wait & see if you need them depending on your system & musical tastes.
jhawkins is offline   Reply With Quote
Old 03-01-2004, 11:02 PM   #8
redwagon
Member#: 2181
2008 SpecB
If you have a subwoofer installed there's no need to drive the comps full range. Cross them at about 80hz and get better power handling. If you don't have a sub and don't plan on one, then you'll probably want to mat the door completely to kill the buzzing at the source. You'll greatly improve midbass response in the process. It's more time and effort than installing filters but it's your call.
Old 03-02-2004, 02:48 AM   #9
it8ezbngrn
Member#: 35590
Cheaper version is to get capacitors. Same thing, try 47 MFD and 100MFD. Try te 100 first it is a lower cut off 47 is probably to high.
Some decks have x overs built in.
it8ezbngrn is offline   Reply With Quote
Old 03-02-2004, 03:33 AM   #10
redwagon
Member#: 2181
2008 SpecB
Yes, good idea. The caps want to be rated 25V or higher. In this kind of application you can get away with bipolar electrolytics. Regular electrolytics (with + and - signs on them) will fail.
Old 03-02-2004, 11:08 AM   #11
Chewy-WRX
Member#: 19426
2002 WRX Black
I will be adding a sub.
Nothing is done yet... I'm just getting all the info before I start.
The comps will be powered by a RF Punch 301s or 201s. And eventually a seperate amp will power a sub.
So I guess I will use bass blockers... is there a type you guys would recommend?
Old 03-02-2004, 03:03 PM   #12
subster
Member#: 40847
2008 2000 2.5 RS
1995 SVX
On that subject, what are the bass-blockers that aren't crossovers that are just in-wire bassblockers? How much? Where to get? My door speakers get distorted from bass and I have a sub. I want to be able to have the bass turned up W/O the door speakers going all p*$$y on me.
subster is offline   Reply With Quote
Old 03-02-2004, 03:27 PM   #13
phillip
Member#: 56396
04 fxt
silvery red
Hi, I bought "my first suby" and thought I might put in my 2 cents. The product "bass blockers" is to my knowledge just a capacitor with a little bit of heat shrink wrapped on for good measure. As far as limiting the bass frequency in speakers goes, the best way is via a active crossover system. Unfortunately these are not cheap. So the second option would be a capacitor wired in series between the speaker leads and the speaker itself. If I am not fubbing the math you would need approximately 500 microfarads of capacitance to give you a roll off frequency of 80 hertz. This would allow for some bass but will minimize any speaker damage and maximize speaker efficiency. I would recommend buying the best caps you can get to help reduce the sound impairment inherent with this type of crossover.
links to capselectronix.com
phillip is offline   Reply With Quote
Old 03-02-2004, 03:29 PM   #14
subster
Member#: 40847
2008 2000 2.5 RS
1995 SVX
Old 03-02-2004, 08:03 PM   #15
dflock
Member#: 45776
Harrison Lab makes a good FMOD Crossover. You install these in your RCA cable before it reaches your amp.
http://www.partsexpress.com/pe/pshow...number=266-252
dflock is offline   Reply With Quote
Old 03-02-2004, 08:47 PM   #16
redwagon
Member#: 2181
2008 SpecB
I think these amps have a built-in crossover, so you're set. No need for bassblockers or fmods. Just set to high-pass at about 80hz
Old 03-03-2004, 02:17 AM   #17
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Yeah just set the HP filter on the amp to ~80hz and you'll be fine. Bass blockers are only useful if you don't feel comfortable putting a cap in series with the speaker wire yourself, your amp doesn't have a HP filter, and your headunit doesn't have a HP filter.
Old 03-03-2004, 02:36 AM   #18
firedust
Member#: 38795
2003 WRX
Sonic Yellow
yea i was gonna say...my head unit has different transfer functions for the output to the front speakers..i currently have them set at 200 HZ+ so i dont get any bass out of em..
firedust is offline   Reply With Quote
Old 03-03-2004, 03:51 AM   #19
redwagon
Member#: 2181
2008 SpecB
I'm pretty sure he has the oem deck
Old 03-03-2004, 08:32 AM   #20
Chewy-WRX
Member#: 19426
2002 WRX Black
Much thanks again everyone.
These specific speakers go down to 40hz... so is there a need to blocker any bass? Isn't 40hz mid-range? I thought 20hz is bass.
Old 03-03-2004, 09:06 AM   #21
redwagon
Member#: 2181
2008 SpecB
Heheheh. The specs always say they go real low. In truth, most 6.5" woofers you find in budget comp sets are very inefficient at low frequencies as they don't have the motor structure or suspension to handle much excursion. They make sound, but volume is way down. In the effort to produce low bass the midrange is muddied. The power handling of the speaker is also greatly reduced. It takes much more excursion to hit the low notes and once it's all used up the volume can up no further. Not only that, but the woofer cone is so busy bouncing back and forth between the plates it hasn't much hope of reproducing the midrange at the same time. Relieve the woofer of sub bass duties and the midrange sounds much sharper and cleaner. This is why people install dedicated midbass drivers.
Many comp sets will take well over their rated power if crossed at 80 or 90hz because you are pushing the thermal limits while skirting the mechanical limits.
A subwoofer does the job of playing the bottom two octaves so much better since it's cone diameter is much closer to the wavelengths it's reproducing. Let the sub play as high as you can get away with before you can tell it's in the trunk and only ask the comps to play down to that freq.
Typical definition is:
up to 80hz, sub bass
80hz to 320hz, midbass
bass blocker question Meat Supply Car Audio, Video & Security 7 01-09-2008 09:03 AM
Bass blockers for rear fill 286 Car Audio, Video & Security 5 10-10-2006 06:05 PM
Bass Enthusiasts, identify a bass for me! HolyCrikey Off-Topic 16 03-30-2005 06:01 PM
bass blockers or go into debt for a crossover? Handsdown Car Audio, Video & Security 8 01-19-2005 08:05 AM
bass and uhh...MORE BASS!! lightsurge North West Impreza Club Forum -- NWIC 8 11-27-2003 12:28 PM
