Old 03-02-2004, 07:41 PM   #1
meshuggah
Member#: 8578
Default Help With Defi VSD Basis on 02 wrx
I got a Defi VSD basis, I've hooked everything up and it doesn't come on.
( RED ) I Put the IGN which is 12v on, to A5 (B134) which is ignition switch. I also tried D2 (B137)
( GREEN ) I have the speed hooked up to A1 (B134) which is Vehicle Speed.
( BLUE ) I have TA which is engine revolutions to C9 (B136) Engine Speed (RPM)
( BLACK ) which is GND, I have hooked up to A22 (B134) which labeled as Ground Power Supply.
I checked all the connections to make sure they are tight, and they are. Any suggestions?
--Geoff
meshuggah is offline   Reply With Quote
Old 03-03-2004, 12:02 AM   #2
CreoWRX
Member#: 19024
2016 F80 M3
Alpine White
Try grounding directly to the chassis?
-Mike-
CreoWRX is offline   Reply With Quote
Old 03-03-2004, 12:19 AM   #3
meshuggah
Member#: 8578
Thats a good idea, acutally tommorw/today which ever it may be, I'll proably try and connect the power and ground straight to the battery and see if it powers on. But i'll try checking the ground first.
--Geoff
Help with Perrin FMIC install on 02 failsafe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 08-10-2012 03:51 AM
Need help with top end power on stock WRX HELPr Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 08-12-2009 03:47 PM
Help with removing side skirts on '06 WRX wagon alotas123 Interior & Exterior Modification 3 07-24-2006 03:17 PM
Statemeet Winnings: Defi VSD Basis (or is it) totald Texas Impreza Club Forum -- TXIC 3 03-14-2005 02:14 AM
Help With Kick up HP's on '04 WRX.... grabbit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-15-2003 08:47 PM
