Old 03-02-2004, 07:47 PM   #1
munchie
Member#: 50660
2004 WRX
Post Rear sway bar and front sway bar? Or coilovers
I have been doing allot of searches on replacing the rear sway bar on an 04 WRX. I believe I have found out that replacing the rear sway bar with somthing stiffer, possibly a 20 mm will clear out the understeer problems. I have noticed allot of people are also replacing the front sway bar. Why would you do this? And if you do, what size do you get to not bring the understeer factor back in. I also saw another post where someone said they preferred leaving the stock sway bars in and just doing coilovers to get the correct feel. Any thoughts would be appreciated. Thanks.
Ryan
munchie is offline   Reply With Quote
Old 03-02-2004, 08:47 PM   #2
S.G.D
Member#: 36448
front sway reduces susepnsion deflection, and body roll making for less camber loss. but if you upgrade the front you will want to upgrade the rear to match. becuase even though the front does make a nice different, if it's mated to a rear 13mm bar your just furthering the problem our cars already have.
~SGD
S.G.D is offline   Reply With Quote
Old 03-02-2004, 10:17 PM   #3
del105
Member#: 43010
1974 2002tii
It all depends on what you are looking to achieve with your car.
del105 is offline   Reply With Quote
Old 03-02-2004, 10:26 PM   #4
Soontobe
Member#: 13432
00 SV650
a properly setup strut/spring/coilover setup will yield much better results then just front and rear sways.
Although, both together is good.
Soontobe is offline   Reply With Quote
Old 03-03-2004, 01:38 AM   #5
munchie
Member#: 50660
2004 WRX
Default Sway bar combos
If my objective was to reduce the body roll, and get rid of some or all of the understeer, what combo of front - rear sway should I use. Is it correct that having a larger sway in the rear than in the front is what reduces the understeer. Also, I hear having oversteer is dangerous for some. Is this just because it makes you feel you can take the corner faster compared to driving with understeer and you end up sliding the rear out, or is it due to loss of traction with having a stiffer sway set up?
Old 03-03-2004, 03:58 PM   #6
munchie
Member#: 50660
2004 WRX
Ok, found some answers, now it just looks like I need to know what combo to go with. If replacing front and rear sway, would going with a 20mm in front, and a 20mm to 24mm adjustable in rear sound good to get rid of body roll? What would the difference be in setting them both at 20, to having stock sways at 17mm, any?
Old 03-03-2004, 04:11 PM   #7
thesmokingman
Member#: 17751
FYI, swaybars will never get rid of body roll, especially with the WRX's high center of roll.
If you try to dial out body roll with swaybars, you only end up reducing your suspensions ability to articulate which means less independance.
I'd say a 20mm bar would balance things out well.
thesmokingman is offline   Reply With Quote
Old 03-03-2004, 05:03 PM   #8
rankink
Member#: 12901
2005 STi/95 VX
Pastelito Racing / SFSOC
Doesn't the stock WRX sedan already have a 20mm front and rear swaybar? Maybe you mean you want to upgrade to a 22mm front and the 20-24 rear adjustable.
K
rankink is offline   Reply With Quote
Endlinks hitting sway bar in rear? and front sway bar hitting tie rods? help! D Money Brakes, Steering & Suspension 11 04-02-2011 10:46 AM
FS: 06 sti steering rack, rear trailing arm, and front sway bar bushings nelli-son Suspension/Brakes/Handling 1 08-05-2008 09:35 PM
f/s socal perrin rear sway bar with mounts and front sway bars comes with all hardwar 949 Suspension/Brakes/Handling 6 01-07-2007 05:36 PM
2006 DMS 40mm Gold SUspension, STI front and rear Strut bars, Cusco front sway bar, zefv Suspension/Brakes/Handling 0 12-07-2006 10:18 AM
Sti and Wrx Rear Sway Bar Wrx Front Sway Bar snowcrzy Suspension/Brakes/Handling 5 10-13-2006 05:02 PM
