Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 03-02-2004, 09:21 PM   #1
wadejg
Member#: 41649
2004 Forester XTi
Angry Erratic FXT idle
I've got a 2004 Forester XT with 13000 miles on the odo. I just got the car back from having the rear differential replaced. I noticed that the idle seemed even rougher than before...and it was never particularly smooth. When warm, at idle, the tach will fluctuated every 5-10 seconds between 500-1000 RPM. And every once in a while it will actually stumble and go down to about 250RPM and almost stall out, with a bit of a shudder. The idle is erratic enough it will actually jangle the keys in my ignition at a stop. It does not just correspond to the AC compressor cycling.
I can't say for sure that it changed right after the rear diff was replaced but it seems like it to me...but my wife disagrees...she said it was just as bad before the service.
I'm obviously back to have it serviced...I've owned the car for 6 months and I'll already have had three days in the shop with four service trips so while I love the car I'm not enthused about Subaru reliability and can't see myself getting another one. :x I hate to think about what will happen if I start modding the car like I want to...the dealer will say everything is a mod problem.
Anybody out there with an erratic idle on a new XT?
Regards,
Justin Wade
2004 FXT
wadejg is offline   Reply With Quote
Old 03-03-2004, 12:23 AM   #2
swingkid
Member#: 47949
04 Forester XT
Porsche 914 w. suby six
I have the same problem but not as severe. My xt definatly wiggles more than any other car I've been in. I haven't had the keys actually jingle, but its enough to make you dizzy if you're reading a newspaper. You can actually see the car wiggling from outside. I just tell passengers it has a hot cam. The dealer claims the eratic idle is normal because it has heavy pistons. If this were the reason (I really doubt it is), the idle should be consistantly lumpy. At least it was documented with the dealership incase I have problems later. Ive owned several Porsche and Subaru flat fours, sixes and turbos, never had such an embarrasing idle.
swingkid is offline   Reply With Quote
Old 03-03-2004, 03:46 AM   #3
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Do a proper ECU reset.
Old 03-03-2004, 09:16 PM   #4
Black Blur
Member#: 47253
2004 Forester XT
Java Black
Even with the radio off, at idle, my FXT is so smooth, sometimes I can't even tell it is running.
Kostamojen is right; ECU reset for starters.
Courtesy of "Fast Lane" in Maine:
"The easiest way to reset the ecu is to disconnect
the cable from the negative battery terminal and
then press/hold the brake pedal for approximately
20 seconds. Reconnect the cable and you are good to go."
Black Blur is offline   Reply With Quote
Old 03-04-2004, 01:52 AM   #5
Caddy Daddy
Member#: 11070
2004 SG9, Audi S8
Ducati ST2, BMW R100/7
doesnt seem sound to me. our FXT, when at idle at a stoplight, will ever-so-slightly develop a harmonic vibration that can be felt, but it is very faint. the rpms do not fluctuate. the car does not heave or die. it just slightly vibrates enough that if you paid close attention you would notice it. i attribute it to motor mounts or bushings with slack somewhere.
nothing like what youre experiencing. start keeping a detailed log of whats happening to the car, and definetly get that serviced at the dealer
what does an ECU reset do?
Caddy Daddy is offline   Reply With Quote
Old 03-04-2004, 09:14 AM   #6
Corkfish
Member#: 39503
The boxer design naturally has a slight side to side idle. If it's severe, start with the easiest things first. Water in the gas?
Corkfish is offline   Reply With Quote
Old 03-16-2004, 11:28 PM   #7
wadejg
Member#: 41649
2004 Forester XTi
As an update. I didn't take the car in for service right away not because I didn't think I needed to but because I just didn't have time. After driving it for about 1 week and about 1 tank of gas the idle had resolved and is perhaps better than before.
If I were to guess, the ECU got reset at the dealer when the rear diff. was replaced and the ECU seemed to run pretty poorly before it "relearned." I'm still not enthused about my reliability but at least my rear diff no longer whines/makes a burning smell, and my car doesn't rock like drunken water buffalo at idle.
Anybody else out there with a really rough idle following an ECU reset?
Regards,
Justin Wade
2004 FXT
Old 03-17-2004, 02:47 AM   #8
Caddy Daddy
Member#: 11070
2004 SG9, Audi S8
you took in consideration a bad batch of fuel?
Old 03-17-2004, 10:23 AM   #9
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
OK guys....We have an STi in the shop right now thats doing the same thing....No codes, no lights...However it looks like a bad Front 02 sensor...Disconnect the front 02 and see if the idle smooths out.....if it does...its bad...
Hope that helps
Bill
04 fxt idle/acceleration, also cruise drifte Newbies & FAQs 7 01-13-2010 10:57 PM
Irratic Idle and Stalling Scoobie2.0 Newbies & FAQs 26 10-18-2009 01:07 PM
what to check for irratic idle and stalling? jacky599r Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 01-27-2009 01:05 PM
HELP !! irratic idle problem ??? Javi_LGT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 05-29-2008 10:45 PM
Irratic Idle Problem, Pressure from gas tank. pdigiacinto Legacy Forum 6 04-20-2004 08:22 PM
