Old 03-03-2004, 01:40 AM   #1
soxx
Member#: 56459
2003 WRX Sedan
Question US '98 EJ22E...Phase I or II? interference??
I recently bought a MY1998 Impreza L sedan with the EJ22E 2.2l engine. Is this a "phase I" or "phase II" engine, and if the timing belt breaks is there any chance of valve damage?
Thank you!
-soxx
soxx is offline   Reply With Quote
Old 10-21-2012, 11:09 PM   #2
RallyImprezive
Member#: 5476
2007 WRX UGM
2010 FXT
It would seem that this motor exhibits qualities of both Phase I and II. My understanding is that it fits more appropriately in the Phase I category due to the placement of the thrust bearings, and rocker roller cam followers with screw-type valve lash adjustment. It does, however, have the single exhaust port which is more like the Phase II.
Yes, I am responding 8 years later. This is because I use the search function
RallyImprezive is offline   Reply With Quote
Old 10-22-2012, 02:34 PM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
screw type valve adjustment is phase II and was not released until 1999...
Old 10-22-2012, 07:39 PM   #4
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
Oh man, soxx is going to be so confused when he reads that reply.
Old 10-23-2012, 12:32 AM   #5
GEE-OTTO
Member#: 201277
2009 Legacy GT
Thank you!
-soxx
EJ22E for the 98 year is still a P1 engine so there is still clearance btwn the valves and the piston in teh event of a belt failure.
GEE-OTTO is offline   Reply With Quote
Old 10-23-2012, 01:28 PM   #6
ManualOverAuto
Member#: 304662
2001 Impreza L coupe
Sedona red Pearl
I found this:
http://ej22.com/
I've read this somewhere else too, but not sure the info is correct.
I think starting in 97 the clearance was eliminated, but they were still phase 1.
So OP, of my info is correct, you have a phase 1 motor, but if the timing belt breaks the valves would still get trashed.
ManualOverAuto is offline   Reply With Quote
ej22 phase I head gasket vrs phase II alejo Normally Aspirated Powertrain 3 04-03-2009 12:59 PM
99 2.2 heads -- Phase I or II ?????? opious Normally Aspirated Powertrain 10 01-17-2006 04:46 AM
Older ej22 to ej25 Phase 1 or Phase 2? Which one? d4d4d4d4 Subaru Conversions 15 12-24-2003 02:10 AM
What block is better for a "build up engine" Phase I or II?? wighti Normally Aspirated with bolt-on Forced Induction Powertrain 13 08-10-2002 08:14 PM
Phase I or II?? etam Legacy Forum 2 10-21-2000 07:40 PM
