Old 03-03-2004, 03:05 PM   #1
NotFast
Member#: 10119
Default Spark plug replacement interval on 03 WRX?
Someone confirm this one, or at least agree or disagree with me.
Everything I've read says I need to swap my plugs at 30,000 miles. Right now I'm at 30k miles.
Monday I took my car into my new Subaru dealer who did not change them. I called them today because I was in a hurry, and the service advisor said that WRX "plugs are platinum and get changed at 60,000 miles. You only change the plugs at 30,000 if you're driving a non-WRX Impreza". I was going to do this work myself, but frankly don't have time to learn how and do it.
Help!
NotFast is offline   Reply With Quote
Old 03-03-2004, 04:49 PM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
it is indeed 60k on the platinum plugs
you are okay for now
Jamie
www.subiegal.com
Old 03-03-2004, 05:18 PM   #3
NotFast
Member#: 10119
Okay, then why does my.subaru.com list a plug change at 30k miles? If they set the maintenance schedule, then why are they incorrect?
So confused
Old 03-03-2004, 05:42 PM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
that's for non platinums...
take our "bit outdated" but near accurate list on allsbuaru.com
http://www.allsubaru.com/schedules.html
30k states:
Change spark plugs (2.5 L and SVX at 60,000 miles)
ya see the Phase I 2.5L's were DOHC, thus they were Platinum
(SVX's are also plats) - our list needs to be updated
WRX 2.0 would fall into this category - 60k
any subaru w/plat plugs are swapped at 60k
any non plats = 30k
Jamie
Old 03-03-2004, 06:18 PM   #5
Gunner
Member#: 36540
04 GGA
Cobb Stage 1 EQ Tuned
I also find out that my.subaru.com is inconsistent with the owner's manual. For instance, it recommends the first oil change to be at 3750 miles, instead of 3000 miles on the owner's manual. I refer to the owner's manual instead.
And yes, 60k for WRX plugs. They are platinum.
Gunner is offline   Reply With Quote
Old 03-04-2004, 10:47 AM   #6
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
Heh, they BETTER be platinum... Otherwise someone's goinna have some 'splainin' to do...
But yeah, 60k miles... I'm happy for that too because they're going to be a real biotch to get to...
Old 03-06-2004, 03:40 PM   #7
persianwrx
Member#: 51976
my car is at about 60 k right now! How much is it going to be to replace the spark plugs and what is the exact kind I should get?? I have an 02 wrx I'm also getting an uppipe and turboback exhaust I don't know if that makes a difference thanks for nay help
persianwrx is offline   Reply With Quote
Old 03-06-2004, 04:12 PM   #8
silvscorp
Member#: 28480
Stock spark is platinum. The recommanded maintenance interval is 60k miles. However, depends on your driving habbit, the gas you use and the kinds of modification on your car the change interval might vary. If you are running high boost then usually a coder plug is better, I am not sure how much it will wear out the stock ones. If you are pushing your car pretty hard constantly then I don't think keep that plug for 60k miles is a good idea.
I plan on chaning the plug like 40k or so. They are not that expensive after all and only takes me about 30 mins to change them.
silvscorp is offline   Reply With Quote
Replacing Spark Plugs - What else Compliments Spark Plug replacements? FIlters? jungleman Service & Maintenance 2 02-09-2009 03:45 PM
how much will this run me. replacment shocks on 03 wrx pulser9 Brakes, Steering & Suspension 2 05-16-2008 05:02 PM
What colder spark plugs to use on 06 wrx bl0wnb0xerbabiE Newbies & FAQs 9 09-04-2006 08:53 PM
I Just replaced my spark plugs and coolant on my WRX! zuczek Canada Region Forum 4 08-27-2004 10:16 PM
