Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 03-03-2004, 03:42 PM   #1
Kingpin
Vendor
Vendor Sales Rating: (36)
Member#: 41252
Twin 2005 600WHP
FormulaD/TimeAttack Sti's
Default New turbo options
Testing is complete of some new low cost turbo options for the WRX and STI.
Option 1:
Part# 3018
Brand new IHI VF30 turbo with upgraded 630CFM compressor wheel. Compressor wheel is the exact same as used in the PE1818 and PE1820. This turbo is the same as the PE1818 but is non ball bearing. You are getting a brand new VF30 in the IHI box with the upgraded compressor which is the same as used in the PE turbo.
$1020
This turbo is available with a Clipped Exhaust turbine wheel for more exhaust flow. A slight increase in lag will be seen but a drastic decrease in exhaust back pressure for more top end power. Drag racers or nitrous users should consider the clipped wheel. 300-400 rpm worth of lag increase for an additional 20-25whp up top.
3018 with Clipped wheel
$1100
Option 2:
Part# 3418
Brand new IHI VF34 turbo with upgraded 630CFM compressor wheel. Compressor wheel is the exact same as used in the PE1818 and PE1820. This turbo is the same as the PE1818 in parts make up. You are getting a brand new VF34 in the IHI box with the upgraded compressor.
$1140
Option 3:
Part# 2220
Brand new IHI VF22 turbo with upgraded 630CFM compressor wheel. Compressor wheel is the exact same as used in the PE1818 and PE1820. This turbo is the same as the PE1820 in parts make up. You are getting a brand new VF22 in the IHI box with the upgraded compressor.
$1060
All three turbos are ready to ship. If sales demand increases a wait time fo 3 days on each turbo after stock is depleted will result. All three turbos have been tested. Since they use the same exact compressor wheel, housings and parts make up as the PE turbos perforformance is the same in most respects. Another cheaper option for bolt on turbos with no guess work about the performance. If you have a 22, 30 or 34 now and would like it upgraded that cost is $299 per turbo and turn around time is 2-3 days in most cases.
Call or email for more information.
Kingpin is offline
Old 03-03-2004, 03:45 PM   #2
Soon2Bgreat
Member Sales Rating: (7)
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
Hot damn, my turbo plans may have changed, lol. Talk about bang for buck, nice.
Soon2Bgreat is offline
Old 03-03-2004, 04:08 PM   #3
Enigma76
Member#: 37247
2004 WRX
Platinum Silver
got any dyno plots, like before/after the compressor changes? how does the exhaust side compare between the IHIs and the PEs?
Enigma76 is offline
Old 03-03-2004, 04:12 PM   #4
serious
Member Sales Rating: (14)
Member#: 22879
Off topic, but do you have a r180 for the jdm sti 6mt w/ 3.9 ratio?
Where is all the jdm goodies on your website anyway?!!
Shoot me a price at brent2401@yahoo.com
serious is offline
Old 03-03-2004, 04:15 PM   #5
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
Enigma76-Dyno Plots to be posted shortly
serious-We have 2 Version 7's coming in this week and are adding all the JDM take off peices to the website currently. Thanks.
Kingpin is offline
Old 03-03-2004, 04:19 PM   #6
Enigma76
Member#: 37247
2004 WRX
Platinum Silver
excellent indeed kingpin, very nice alternatives here. hopefully the dyno plots turn out to be...fun
Enigma76 is offline
Old 03-03-2004, 04:52 PM   #7
03WRXMA
Member#: 35081
2012 WRX
Bump^ for some dyno plots also
03WRXMA is offline
Old 03-03-2004, 04:55 PM   #8
dwx
Member Sales Rating: (4)
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
I have what I think is one of the VF34 ones with the PE-style compressor. Basically I bought the turbo about 4 months ago as a VF34 off Ebay and it turned out not to be a VF34, but it was identical to the PE1818. It had no markings on it at all but it came in a IHI box. I thought maybe it fell off a truck or something, the company I bought it from was not a company that sold Subaru parts. Anyways, with supporting mods and tuning I made 340whp/340ft-lbs on Cobb's Mustang dyno at 17psi and about 11.25:1 AFRs. I get full boost by around 3000 rpm with the turbo. This is on a EJ257 w/V8 heads.
dwx is offline
Old 03-03-2004, 04:56 PM   #9
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
Enigma76-Keep in mind the turbos use the exact same parts as the PE turbos so performance is the same.
Thanks.
Kingpin is offline
Old 03-03-2004, 04:57 PM   #10
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
DWX-nice numbers man. Sounds like your turbo spools fast on that 2.5.
Kingpin is offline
Old 03-03-2004, 07:01 PM   #11
Enigma76
Member#: 37247
2004 WRX
Platinum Silver
im alittle confused then, if they use the exact same parts, they are basically a PE 1818/20 in IHI shell? so its basically like getting one of the PEs but for alot cheaper?
Enigma76 is offline
Old 03-03-2004, 07:07 PM   #12
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
Bingo. Actually the PE turbo use the IHI housings any way. But yeah you got it.
Kingpin is offline
Old 03-03-2004, 07:11 PM   #13
03WRXMA
Member#: 35081
2012 WRX
So only $299 to get my 22 upgraded to what is basically a 1820?
Dont the PE turbos have a different wastegate?
03WRXMA is offline
Old 03-03-2004, 07:14 PM   #14
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
Basically they have cut open the stock wastgate, I believe, and stuck a new spring in there and then clamped it back together. I know that various springs are available. And yes $299 for the upgrade. Thanks.
Kingpin is offline
Old 03-03-2004, 07:16 PM   #15
cronic
Member Sales Rating: (3)
Member#: 9749
The pe that is pictured has the optional separative wastegate which allows you to swap out for heavier springs.. I am 99% sure you can get one and add it to one of these IHI's.. Mike this is an awesome thing ya got here, just wich i already didnt have an 1820..
I am sure Mike can get you one from PE, i think they are like 70-80 give or take if my memory serves me..
Dave
cronic is online now
Old 03-03-2004, 07:19 PM   #16
03WRXMA
Member#: 35081
2012 WRX
cronic,
what WG spring are you running, and what was it stock if you changed it?
-Dave N.
03WRXMA is offline
Old 03-03-2004, 07:20 PM   #17
spiralsmurf
Member Sales Rating: (31)
Member#: 16085
2005 STi
Does it come with an upgraded wastegate?
Are you guys modifying the IHI turbos or does ihi sell them this way.
spiralsmurf is offline
Old 03-03-2004, 07:37 PM   #18
odin1
Member Sales Rating: (1)
Member#: 29362
2008 2008 sti
stage 2
I thought the housings on the pe 1820were a lot larger than vf22 housings-Help me here Mike. Also to perform the mod on an existing vf22-mine-do u machine the housing to accept the larger wheel? Are the exhaust wheels on the vf22 and pe1820 identical? Very interested- I have a deadbolt p&p vf22 w/ corner clipped exhaust wheel-so by doing this mod, I have an pe1820? thnx.
odin1 is offline
Old 03-03-2004, 08:11 PM   #19
cronic
Member#: 9749
I have the 14psi spring i believe.. I also have a 19psi spring sitting here waiting to go in..
Odin1.. The pe1820 and vf22 use the p20 exhaust housing, the pe1818 uses the smaller p18.. I believe the comp housings are all RX6.. I think the new pe's use the same vf30 comp housing which they just enlarge a bit..
Mike sorry to jump on you thread but i am bored..
D-
Old 03-03-2004, 08:26 PM   #20
Enigma76
Member#: 37247
2004 WRX
Platinum Silver
ya i forgot the vf3x use the p18 housing, same as the pe1818, and the 22 uses the p20, same as the 1820.
http://forums.nasioc.com/forums/show...hreadid=511845
refer to that thread for flow rates of the IHIs vs the PEs @ diff PSI.
Enigma76 is offline
Old 03-04-2004, 03:00 AM   #21
odin1
Member#: 29362
2008 2008 sti
stage 2
D-
Thnx man. So the turbine wheels on vf22 and pe1820 are the same-just compressor wheel on 1820 is larger? tia.
odin1 is offline
Old 03-04-2004, 01:08 PM   #22
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
Dave
We dont offer the seprative Actuator with these turbos. You get the same actuator that comes with the turbo. 8-10 psi. If you need more we can certainly upgrade the actuator to an adjustable one with higher pressure... that will be an additional charge though. let me look into that...
The Kit from PE is around $80 but all you get is a spring and the clamp. You must cut your cant open to install the spring. I know about 5 people that have tried this, cut the rubber diaphram and been up the creek without a paddle.... You cant buy just the IHI actuator so good luck if that happens. PE does offer the entire unit but I am not sure of the price.
Kingpin is offline
Old 03-04-2004, 01:10 PM   #23
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
D-
Correct on the turbine housings. 1820 uses P20, 1818 uses P18. VF22 uses P20, VF30/34 uses P18.
Old PE turbos used the RX6 comp housing. New ones use the VF30 style Comp housing because the RX6 ones are no longer available. The turbos we sell use the VF30 style housing for the same reason.
Kingpin is offline
Old 03-04-2004, 01:11 PM   #24
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
Yes
Thanks.
Kingpin is offline
Old 03-04-2004, 01:12 PM   #25
cronic
Member#: 9749
Yea.. i got a bit confused with the RX6.. Is there anything that can be done to the 1820 to make it a little larger or is that about maxed out? New Cartridge?
Dave-
Closed Thread
New Turbo Options? Daveyz328 Normally Aspirated Powertrain 3 01-05-2009 06:05 AM
New injector option for turbo 2.5RS DeatschWerks Normally Aspirated with bolt-on Forced Induction Powertrain 16 01-08-2007 09:50 PM
Options for this new turbo M3GTR Factory 2.0L Turbo Powertrain 13 12-06-2003 03:19 PM
MY99 turbo options kastle Normally Aspirated Powertrain 3 01-25-2001 12:42 AM
new Sti options for the New Impreza Reiflex General Forum Archive 9 12-22-2000 12:27 AM
Message Board Statistics All times are GMT -4. The time now is 01:34 PM.
